Hi Grumpy Mike, I have saved the image as a PNG file so should be able to veiw it, I did post the full sketch but not sure where it went so will try again ...
I did make a few mods to sketch and as posts above bodged the #Define pins to see if that works, BUT I think the problem may be in the Libraries as ther are these : ==
#include <Adafruit_MCP23X08.h>
#include <Adafruit_MCP23X17.h>
#include <Adafruit_MCP23XXX.h>
#include <wire.h>
So I am just about to just include the Adafruit MCP23X17.h and see if that is the problem ...
Full sketch below ...
#include <wire.h>
//4 Way Crossing Mimic LED Panel system
//Created 26th April 2022
//Updated 2nd May 2022
//Completed Define and Void Setup on 3rd May 2022
//Issue on Laptop and Adafruit Bused fine
//Adding Switch Case 1st June 2022
//Added 12 Switch Case 2nd June 2022
//Initial test Mimic LED's are selecting incorrect routes but pins are correct 2nd Nov 2022
//Arduino Nano Using MCP23017 chips .. 6 in total
//Pins Used on Arduino Nano
// Nano MCP23017
// SCL SCL
// SDA SDA
// GND VSS
// 5V VDD
// MCP23017 Address
// ADDR IC21 Addr 0x22
// ADDR IC22 Addr 0x23
// ADDR IC24 Addr 0x20
// ADDR IC23 Addr 0x21
// ADDR IC1 Addr 0x24
// ADDR IC2 Addr 0x25
//define Addresses
#define addr1 0x20
#define addr2 0x21
#define addr3 0x22
#define addr4 0x23
#define addr5 0x24
#define addr6 0x25
//Mimic Panel LED's in various blocks
//On Addr 0x22 and 0x23
#define P4AB 21 //Platform 4 Exit
#define P4ENT 22 //Platform 4 Entry
#define P18A 23 //Po#define 18 Middle Track
#define P18B 24 //Po#define 18 Outside Track
#define P3ENT 25 //Platform 3 Entry
#define UP2A 26 //Up Fast Track
#define CROSS7A 27 //Scissor 7 Crossing
#define CROSS6A 28 //Scissor 6 Crossing
#define L1ABC 1 //Track 1 Left LED ABC
#define R1AB 2 //Track 1 Right LED AB
#define L2AB 3 //Track 2 Left AB
#define L2C 27 //
#define R2ABC 4 //Track 2 Right ABC
#define R2D 26
#define L3ABC 5 //Track 3 Left ABC
#define R3AB 6 //Track 3 Right AB
#define L4AB 7 //Track 4 Left AB
#define L4C 25 //
#define L4D 23 //
#define R4AB 8 //Track 4 Right AB
#define R4C 24
#define L5ABC 21 //Track 5 Left ABC
#define R5A 22 //Track 5 Right A
#define P15ABC 1 //Reversing Loop Left to Right
#define P16ABC 2 //Reversing Loop Right to Left
//Sensor inputs for Entry
#define SEN1 21//on Addr 0x21
#define SEN2 22//
#define SEN3 23//
#define SEN4 24//
#define SEN5 25//
#define SEN6 26//
#define SEN7 27//
#define SEN8 28//
#define SEN9 1//
#define SEN10 2//
#define SEN11 3//
#define SEN12 4//
int SEN1state;
int SEN2state;
int SEN3state;
int SEN4state;
int SEN5state;
int SEN6state;
int SEN7state;
int SEN8state;
int SEN9state;
int SEN10state;
int SEN11state;
int SEN12state;
//Aspect Signals Entry to blocks
#define ASP1 21// on Addr 0x20
#define ASP2 22
#define ASP3 23
#define ASP4 24
#define ASP5 25
#define ASP6 26
#define ASP7 27
#define ASP8 28
//Aspect Direction Signals
#define DIR1 1//on Addr 0x20
#define DIR2 2
#define DIR3 3
#define DIR4 4
#define DIR5 5
#define DIR6 6
#define DIR7 7
#define DIR8 8
#define DIR9 8 //on Addr 0x21
//Po#define Button Inputs
//MCP23017 Address 0x25
#define SW1 1 //Po#define Button 1
#define SW2 2 //Po#define Button 2
#define SW3 3//Po#define Button 3
#define SW4 4//Po#define Button 4
#define SW5 5 //Po#define Button 5
#define SW6 6 //Po#define Button 6
#define SW7 7 //Po#define Button 7
#define SW8 8 //Po#define Button 8
int SW1state;
int SW2state;
int SW3state;
int SW4state;
int SW5state;
int SW6state;
int SW7state;
int SW8state;
//MCP23017 Address 0x24
#define SW9 1 //Po#define Button 9
#define SW10 2 //Po#define Button 10
#define SW11 3 //Po#define Button 11
#define SW12 4//Po#define Button 12
#define SW13 5//Po#define Button 13
#define SW14 6//Po#define Button 14
#define SW15 7//Po#define Button 15
#define SW16 8//Po#define Button 16
//MCP23017 Address 0x21
#define SW17 9//Po#define Button 17
#define SW18 10//Po#define Button 18
#define SW19 11//Po#define Button 19
//MCP23017 Address 0x23
#define SW20 8//Po#define Button 20
int SW9state;
int SW10state;
int SW11state;
int SW12state;
int SW13state;
int SW14state;
int SW15state;
int SW16state;
int SW17state;
int SW18state;
int SW19state;
int TR1LEDstate;
//Po#define Button Outputs
#define PSW1 21//Switching Track 1 Exit Platform 3 (2 on Darcy Board)
#define PSW2 22//Switching Track 2 Fast Up Line (1 on Darcy Board)
#define PSW3 23//Switching Track 3 Exit Fast Down Line (3 on Darcy Board)
#define PSW4 24//Switching Track 4 Exit Platform 2 (4 on Darcy Board)
#define PSW5 25//Switching Track 5 Exit Platform 1 (5 on Darcy Board)
#define PSW6 26//Point6
#define PSW7 27//Point7
#define PSW8 28//Point8
#define PSW9 21//Point9
#define PSW10 22//Point10
#define PSW11 23//Point11
#define PSW12 24//Point12
#define PSW13 25//Point13
#define PSW14 26//Point14
#define PSW15 27//Point15
#define PSW16 28//Point16
int PSW17 = 3;//Point 17 on Nano pin 3
int PSW18 = 4;//Point 18 on Nano Pin 4
int PSW19 = 5;//Point 19 on Nano Pin 5
int PSW20 = 6;//Point 20 on Nano Pin 6
//Track Detect LED's
//MCP23017 Address 0x22
#define TR1LED 7//Track 1 Indicator
#define TR2LED 6//Track 2 Indicator
#define TR3LED 5//Track 3 Indicator
#define TR4LED 4//Track 4 Indicator
#define TR5LED 3//Track 5 Indicator
int TR6LED = 7;//Track Sense LED on Nano
int TR7LED = 8;//Reversing Loop R to L
int TR8LED = 9;//Reversing Loop L to R
int TR9LED = 10;//spare
int TR10LED = 11;//spare
int TR11LED = 12;//spare
int TR12LED = 13;//spare
//MCP23017 objects to communicate with
Adafruit_MCP23X17 mcp1;
Adafruit_MCP23X17 mcp2;
Adafruit_MCP23X17 mcp3;
Adafruit_MCP23X17 mcp4;
Adafruit_MCP23X17 mcp5;
Adafruit_MCP23X17 mcp6;
//Check which Sensor is live
bool SEN1_in_use = false;
bool SEN2_in_use = false;
bool SEN3_in_use = false;
bool SEN4_in_use = false;
bool SEN5_in_use = false;
bool SEN6_in_use = false;
bool SEN7_in_use = false;
bool SEN8_in_use = false;
bool SEN9_in_use = false;
bool SEN10_in_use = false;
bool SEN11_in_use = false;
bool SEN12_in_use = false;
// Route states
enum RouteState { Idle, Active, Clearing };
RouteState route1_state = Idle;
RouteState route2_state = Idle;
RouteState route3_state = Idle;
RouteState route4_state = Idle;
RouteState route5_state = Idle;
RouteState route6_state = Idle;
RouteState route1A_state = Idle;
RouteState route2A_state = Idle;
RouteState route3A_state = Idle;
RouteState route4A_state = Idle;
RouteState route5A_state = Idle;
RouteState route6A_state = Idle;
Serial.println(" 4 Way crossing Control using 6 x MCP23017 ");
//init devices
if (!mcp1.begin_I2C(addr1)){
Serial.println("Cant initialise mcp23017 mcp1");
while (1);
if (!mcp2.begin_I2C(addr2)){
Serial.println("Cant initialise mcp23017 mcp2");
while (1);
if (!mcp3.begin_I2C(addr3)){
Serial.println("Cant initialise mcp23017 mcp3");
while (1);
if (!mcp4.begin_I2C(addr4)){
Serial.println("Cant initialise mcp23017 mcp4");
while (1);
if (!mcp5.begin_I2C(addr5)){
Serial.println("Cant initialise mcp23017 mcp5");
while (1);
if (!mcp6.begin_I2C(addr6)){
Serial.println("Cant initialise mcp23017 mcp6");
while (1);
Serial.println("All MCP's are working");
//Mimic LED Blocks setup Addr 0x22 and 0x23 mcp 3 & mcp4
//Also Blinks on second set of LED's as per List
mcp3.pinMode(P4AB,OUTPUT);// Pin 21 but blinking on R3AB on Pin 6
mcp3.pinMode(P4ENT,OUTPUT);// Pin 22 but Blinking on L4AB 0n Pin 7
mcp3.pinMode(P18A,OUTPUT);// Pin 23 but Blinking on R4AB on pin 8
mcp3.pinMode(P18B,OUTPUT);// Pin 24 but Blinking on L1ABC on Pin 1 XXX
mcp3.pinMode(P3ENT,OUTPUT);// Pin 25 but Blinking on R1AB Pin 2
mcp3.pinMode(UP2A,OUTPUT);// Pin 26 but Blinking on L2AB Pin 3
mcp3.pinMode(CROSS7A,OUTPUT);// Pin 27 but Blinking on R2ABC Pin 4
mcp3.pinMode(CROSS6A,OUTPUT);// Pin 28 but Blinking on L3ABC Pin 5
mcp3.pinMode(L1ABC,OUTPUT);// Pin 1 but Blinking on P4ENT Pin 22
mcp3.pinMode(R1AB,OUTPUT);// Pin 2 but Blinking on P18A Pin 23
mcp3.pinMode(L2AB,OUTPUT);// Pin 3 but Blinking on P18B Pin 24
mcp3.pinMode(R2ABC,OUTPUT);// Pin 4 but Blinking on P3ENT Pin 25
mcp3.pinMode(L3ABC,OUTPUT);// Pin 5 but Blinking on UP2A on Pin 26
mcp3.pinMode(R3AB,OUTPUT);// Pin 6 but Blinking on CROSS7A on Pin 27
mcp3.pinMode(L4AB,OUTPUT);// Pin 7 but Blinking on CROSS6A on Pin 28
mcp3.pinMode(R4AB,OUTPUT);// Pin 8 but Blinking on L1ABC on Pin 1 XXX
mcp4.pinMode(R2D,OUTPUT);// Pin 26 but blinking on TRLED5 on Pin 3
mcp4.pinMode(L2C,OUTPUT);// Pin 27 but Blinking on TRLED4 Pin 6
mcp4.pinMode(L4C,OUTPUT);// Pin 25 but nothing Blinking
mcp4.pinMode(L4D,OUTPUT);// Pin 23 but Blinking on R4AB on Pin 8
mcp4.pinMode(R4C,OUTPUT);// Pin 24 but blinking on P15ABC on Pin 1
mcp4.pinMode(L5ABC,OUTPUT);// Pin 21 but blinking on TR2LED on Pin 6
mcp4.pinMode(R5A,OUTPUT);// Pin 22 but blinking on TR1LED on Pin 7
mcp4.pinMode(P15ABC,OUTPUT);// Pin 1 But blinking on R5A on Pin 22
mcp4.pinMode(P16ABC,OUTPUT);// Pin 2 but blniking on L4D on Pin 23
//A Test blinking of LED banks
mcp3.digitalWrite(R4AB,LOW);
mcp3.digitalWrite(R4AB,HIGH);
Serial.print ("0x");
Serial.println (addr4,HEX);
Serial.print ("Pin ");
Serial.println (R4AB);
//Entry Sensors setup Addr 0x21 mcp2
mcp2.pinMode(SEN1,INPUT_PULLUP);
mcp2.pinMode(SEN2,INPUT_PULLUP);
mcp2.pinMode(SEN3,INPUT_PULLUP);
mcp2.pinMode(SEN4,INPUT_PULLUP);
mcp2.pinMode(SEN5,INPUT_PULLUP);
mcp2.pinMode(SEN6,INPUT_PULLUP);
mcp2.pinMode(SEN7,INPUT_PULLUP);
mcp2.pinMode(SEN8,INPUT_PULLUP);
mcp2.pinMode(SEN9,INPUT_PULLUP);
mcp2.pinMode(SEN10,INPUT_PULLUP);
mcp2.pinMode(SEN11,INPUT_PULLUP);
mcp2.pinMode(SEN12,INPUT_PULLUP);
//Aspect Signal Setup Addr 0x20 mcp1 and DIR9 is Addr ox21 mcp2
mcp1.pinMode(ASP1,OUTPUT);
mcp1.pinMode(ASP2,OUTPUT);
mcp1.pinMode(ASP3,OUTPUT);
mcp1.pinMode(ASP4,OUTPUT);
mcp1.pinMode(ASP5,OUTPUT);
mcp1.pinMode(ASP6,OUTPUT);
mcp1.pinMode(ASP7,OUTPUT);
mcp1.pinMode(ASP8,OUTPUT);
mcp1.pinMode(DIR1,OUTPUT);
mcp1.pinMode(DIR2,OUTPUT);
mcp1.pinMode(DIR3,OUTPUT);
mcp1.pinMode(DIR4,OUTPUT);
mcp1.pinMode(DIR5,OUTPUT);
mcp1.pinMode(DIR6,OUTPUT);
mcp1.pinMode(DIR7,OUTPUT);
mcp1.pinMode(DIR8,OUTPUT);
mcp2.pinMode(DIR9,OUTPUT);
//Po#define Button Inputs Button1 - Button8 SW1 - SW8 Addr 0x25 mcp6 .. Button9 - Button16 SW9 - SW16 Addr 0x24 mcp5
//Buttons17 - Button19 SW17 - SW19 Addr 0x21 mcp2
mcp6.pinMode(SW1,INPUT_PULLUP);
mcp6.pinMode(SW2,INPUT_PULLUP);
mcp6.pinMode(SW3,INPUT_PULLUP);
mcp6.pinMode(SW4,INPUT_PULLUP);
mcp6.pinMode(SW5,INPUT_PULLUP);
mcp6.pinMode(SW6,INPUT_PULLUP);
mcp6.pinMode(SW7,INPUT_PULLUP);
mcp6.pinMode(SW8,INPUT_PULLUP);
mcp5.pinMode(SW9,INPUT_PULLUP);
mcp5.pinMode(SW10,INPUT_PULLUP);
mcp5.pinMode(SW11,INPUT_PULLUP);
mcp5.pinMode(SW13,INPUT_PULLUP);
mcp5.pinMode(SW14,INPUT_PULLUP);
mcp5.pinMode(SW15,INPUT_PULLUP);
mcp5.pinMode(SW16,INPUT_PULLUP);
mcp2.pinMode(SW17,INPUT_PULLUP);
mcp2.pinMode(SW18,INPUT_PULLUP);
mcp2.pinMode(SW19,INPUT_PULLUP);
mcp4.pinMode(SW20,INPUT_PULLUP);
//Po#define Switching 1 - 5 are "Y" po#defines
//Po#define Switch Outputs on Addr 0x25 PSW1 - PSW8
mcp6.pinMode(PSW1,OUTPUT);
mcp6.pinMode(PSW2,OUTPUT);
mcp6.pinMode(PSW3,OUTPUT);
mcp6.pinMode(PSW4,OUTPUT);
mcp6.pinMode(PSW5,OUTPUT);
mcp6.pinMode(PSW6,OUTPUT);
mcp6.pinMode(PSW7,OUTPUT);
mcp6.pinMode(PSW8,OUTPUT);
//define Switching 9 - 16
//define Switch Outputs on Addr 0x24 PSW9 - PSW16
mcp5.pinMode(PSW9,OUTPUT);
mcp5.pinMode(PSW10,OUTPUT);
mcp5.pinMode(PSW11,OUTPUT);
mcp5.pinMode(PSW12,OUTPUT);
mcp5.pinMode(PSW13,OUTPUT);
mcp5.pinMode(PSW14,OUTPUT);
mcp5.pinMode(PSW15,OUTPUT);
mcp5.pinMode(PSW16,OUTPUT);
//int Switch Point Outputs on Nano Pins 3,4,5,6 PSW17 - PSW20
pinMode(PSW17,OUTPUT);
pinMode(PSW18,OUTPUT);
pinMode(PSW19,OUTPUT);
pinMode(PSW20,OUTPUT);
//Sensor LED's for Tracks 1,2 and top of Layout Entry 3.4.5
//Track Detect LED's Addr 0x23 mcp4
mcp4.pinMode(TR1LED,OUTPUT);//Track 1 Indicator
mcp4.pinMode(TR2LED,OUTPUT);//Track 2 Indicator
mcp4.pinMode(TR3LED,OUTPUT);//Track 3 Indicator
mcp4.pinMode(TR4LED,OUTPUT);//Track 4 Indicator
mcp4.pinMode(TR5LED,OUTPUT);//Track 5 Indicator
pinMode(TR6LED,OUTPUT);//Track 6 Indicator plus 7 to 12 from Nano
pinMode(TR7LED,OUTPUT);//Reversing Loop R to L
pinMode(TR8LED,OUTPUT);//Reversing Loop L to R
pinMode(TR9LED,OUTPUT);//spare
pinMode(TR10LED,OUTPUT);//spare
pinMode(TR11LED,OUTPUT);//spare
pinMode(TR12LED,OUTPUT);//spare
void loop(){
SEN1state = mcp2.digitalRead(SEN1);
// ...... Route 5 from Sensor 1 ot Platform 1 .......
switch (route5_state) {
case Idle: {
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW5) == HIGH) {
mcp4.digitalWrite(TR5LED,HIGH);
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW5) == LOW) {
if (mcp6.digitalRead(SW5) == LOW && !SEN1_in_use) {
SEN1_in_use = true;
mcp6.digitalWrite(PSW5, LOW);//Point switch to Right
mcp1.digitalWrite(ASP1, HIGH);//Aspect on Sen1 Green
mcp1.digitalWrite(DIR1, LOW);//Dierection OFF
mcp5.digitalWrite(PSW15, HIGH);//Point 15 Straight
mcp5.digitalWrite(PSW13, LOW);//Point 13 Right
digitalWrite(PSW19, HIGH);//Point 19 Straight (Nano Switch)4
mcp4.digitalWrite(R4C, HIGH);//Mimic R4C GREEN
mcp4.digitalWrite(R5A, HIGH);//Mimic R5A GREEN
route5_state = Active;
case Active: {
if (mcp2.digitalRead(SEN1) == HIGH) {
route5_state = Clearing;
case Clearing: {
mcp6.digitalWrite(PSW5, HIGH);//Point switch to Left
mcp1.digitalWrite(ASP1, LOW);//Aspect on Sen1 RED
mcp5.digitalWrite(PSW13, HIGH);//Point 13 Straight
mcp4.digitalWrite(R4C, LOW);//Mimic R4C RED
mcp4.digitalWrite(R5A, LOW);//Mimic R5A RED
// ...... Route 5A from Sensor 2 to Platform 1 .......
switch (route5A_state) {
case Idle: {
if (mcp2.digitalRead(SEN2) == LOW && mcp6.digitalRead(SW5) == HIGH) {
if (mcp2.digitalRead(SEN2) == LOW && mcp6.digitalRead(SW5) == LOW) {
if (mcp6.digitalRead(SW5) == LOW && !SEN2_in_use) {
SEN2_in_use = true;
mcp1.digitalWrite(ASP3, HIGH);//Aspect on Sen2 Green
mcp1.digitalWrite(ASP4, HIGH);//Aspect on Track GREEN
mcp1.digitalWrite(DIR5, HIGH);//Direction LEFT
mcp5.digitalWrite(PSW11, HIGH);//Point 11 Straight
mcp5.digitalWrite(PSW8, LOW);//Point Left
mcp4.digitalWrite(L4D, HIGH);//Mimic L4D GREEN
mcp4.digitalWrite(L4C, HIGH);//Mimic L4C GREEN
mcp4.digitalWrite(L5ABC, HIGH);//Mimic L5ABC GREEN
route5A_state = Active;
case Active: {
if (mcp2.digitalRead(SEN2) == HIGH) {
route5A_state = Clearing;
case Clearing: {
mcp6.digitalWrite(PSW5, HIGH);//Point switch to LEFT
mcp1.digitalWrite(ASP3, LOW);//Aspect on Sen2 RED
mcp1.digitalWrite(ASP4, LOW);//Aspect on Track RED
mcp1.digitalWrite(DIR5, LOW);//Direction OFF
mcp5.digitalWrite(PSW11, HIGH);//Point 11 STRAIGHT
mcp5.digitalWrite(PSW8, HIGH);//Point STRAIGHT
mcp4.digitalWrite(L4D, LOW);//Mimic L4D RED
mcp4.digitalWrite(L4C, LOW);//Mimic L4C RED
mcp4.digitalWrite(L5ABC, LOW);//Mimic L5ABC RED
// ...... Route 4 from Sensor 1 ot Platform 2 .......
switch (route4_state) {
case Idle: {
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW4) == HIGH) {
mcp4.digitalWrite(TR4LED,HIGH);
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW4) == LOW) {
if (mcp6.digitalRead(SW4) == LOW && !SEN1_in_use) {
SEN1_in_use = true;
mcp6.digitalWrite(PSW4, LOW);//Point switch to RIGHT
mcp1.digitalWrite(DIR1, HIGH);//Direction OFF
mcp1.digitalWrite(DIR3, HIGH);//Direction OFF
mcp1.digitalWrite(DIR2, LOW);//Direction LEFT
mcp5.digitalWrite(PSW15, LOW);//Point 15 STRAIGHT
mcp5.digitalWrite(PSW13, LOW);//Point 15 STRAIGHT
mcp5.digitalWrite(PSW12, HIGH);//Point 15 LEFT
mcp4.digitalWrite(R4AB, HIGH);//Mimic R4AB GREEN
route4_state = Active;
case Active: {
route4_state = Clearing;
case Clearing: {
mcp5.digitalWrite(PSW12, LOW);//Point 12 STRAIGHT
mcp4.digitalWrite(R4AB, LOW);//Mimic R4AB RED
// ...... Route 4A from Sensor 2 to Platform 2 .......
switch (route4A_state) {
case Idle: {
if (mcp2.digitalRead(SEN2) == LOW && mcp6.digitalRead(SW4) == HIGH) {
if (mcp2.digitalRead(SEN2) == LOW && mcp6.digitalRead(SW4) == LOW) {
if (mcp6.digitalRead(SW4) == LOW && !SEN2_in_use) {
SEN2_in_use = true;
mcp1.digitalWrite(ASP3, HIGH);//Aspect on Sen2 GREEN
mcp3.digitalWrite(L4AB, HIGH);//Mimic L4AB GREEN
route4A_state = Active;
case Active: {
route4A_state = Clearing;
case Clearing: {
mcp1.digitalWrite(ASP3, LOW);//Aspect on Sen2 GREEN
mcp1.digitalWrite(ASP4, LOW);//Aspect on Track GREEN
mcp3.digitalWrite(L4AB, LOW);//Mimic L4AB RED
// ...... Route 3 from Sensor 1 ot Fast Down Line .......
switch (route3_state) {
case Idle: {
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW3) == HIGH) {
mcp4.digitalWrite(TR3LED,HIGH);
if (mcp2.digitalRead(SEN1) == LOW && mcp6.digitalRead(SW3) == LOW) {
if (mcp6.digitalRead(SW3) == LOW && !SEN1_in_use) {
SEN1_in_use = true;
mcp6.digitalWrite(PSW3, LOW);//Point switch to RIGHT
mcp1.digitalWrite(DIR2, HIGH);//Direction OFF
mcp5.digitalWrite(PSW13, LOW);//Point 13 STRAIGHT
mcp3.digitalWrite(R3AB, HIGH);//Mimic R3AB GREEN
route3_state = Active;
case Active: {
route3_state = Clearing;
case Clearing: {
mcp6.digitalWrite(PSW3, HIGH);//Point switch to LEFT
mcp3.digitalWrite(R3AB, LOW);//Mimic R3AB RED
// ...... Route 3A from Sensor 2 to Fast Down .......
switch (route3A_state) {
case Idle: {
if (mcp2.digitalRead(SEN3) == LOW && mcp6.digitalRead(SW3) == HIGH) {
if (mcp2.digitalRead(SEN3) == LOW && mcp6.digitalRead(SW3) == LOW) {
if (mcp6.digitalRead(SW3) == LOW && !SEN3_in_use) {
SEN3_in_use = true;
mcp1.digitalWrite(ASP5, HIGH);//Aspect on Sen3 GREEN
mcp3.digitalWrite(L3ABC, HIGH);//Mimic L3ABC GREEN
route3A_state = Active;
case Active: {
if (mcp2.digitalRead(SEN3) == HIGH) {
route3A_state = Clearing;
case Clearing: {
mcp1.digitalWrite(ASP5, LOW);//Aspect on Sen3 RED
mcp3.digitalWrite(L3ABC, LOW);//Mimic L3ABC RED
// ...... Route 2 from Sensor 6 ot Fast UP Line and Right at point 2.......
switch (route2_state) {
case Idle: {
if (mcp2.digitalRead(SEN6) == LOW && mcp6.digitalRead(SW2) == HIGH) {
mcp4.digitalWrite(TR2LED,HIGH);
if (mcp2.digitalRead(SEN6) == LOW && mcp6.digitalRead(SW2) == LOW) {
if (mcp6.digitalRead(SW2) == LOW && !SEN6_in_use) {
SEN6_in_use = true;
mcp6.digitalWrite(PSW2, LOW);//Point switch to RIGHT
mcp1.digitalWrite(ASP6, HIGH);//Aspect on Sen6 GREEN
mcp1.digitalWrite(DIR6, LOW);//Direction RIGHT
mcp1.digitalWrite(DIR7, HIGH);//Direction OFF
mcp6.digitalWrite(PSW4, LOW);//Point 4 STRAIGHT
mcp5.digitalWrite(PSW16, LOW);//Point 16 STRAIGHT
mcp3.digitalWrite(R2ABC, HIGH);//Mimic R2ABC GREEN
route2_state = Active;
case Active: {
if (mcp2.digitalRead(SEN6) == HIGH) {
route2_state = Clearing;
case Clearing: {
mcp6.digitalWrite(PSW2, HIGH);//Point switch to RIGHT
mcp1.digitalWrite(ASP6, LOW);//Aspect on Sen6 GREEN
mcp1.digitalWrite(DIR6, HIGH);//Direction OFF
mcp3.digitalWrite(R2ABC, LOW);//Mimic R2ABC GREEN
// ...... Route 2A from Sensor 2 to Fast Up and Left at Point 2 .......
switch (route2A_state) {
case Idle: {
SEN2_in_use = true;
mcp6.digitalWrite(PSW2, HIGH);//Point switch to LEFT
mcp1.digitalWrite(DIR7, LOW);//Direction LEFT
mcp5.digitalWrite(PSW9, LOW);//Point switch to STRAIGHT
mcp5.digitalWrite(PSW10, LOW);//Point switch to STRAIGHT
route2A_state = Active;
case Active: {
route2A_state = Clearing;
case Clearing: {
mcp1.digitalWrite(ASP6, LOW);//Aspect on Sen6 RED
mcp3.digitalWrite(L3ABC, LOW);//Mimic LBC RED
// ...... Route 1 from Sensor 5 ot Platform 3 UP Line and Right at point 1.......
switch (route1_state) {
case Idle: {
if (mcp2.digitalRead(SEN5) == LOW && mcp6.digitalRead(SW1) == HIGH) {
mcp4.digitalWrite(TR1LED,HIGH);
if (mcp2.digitalRead(SEN5) == LOW && mcp6.digitalRead(SW1) == LOW) {
if (mcp6.digitalRead(SW1) == LOW && !SEN5_in_use) {
SEN5_in_use = true;
mcp6.digitalWrite(PSW1, LOW);//Point switch to RIGHT
mcp1.digitalWrite(ASP7, HIGH);//Aspect on Sen6 GREEN
mcp1.digitalWrite(DIR8, LOW);//Direction RIGHT
mcp1.digitalWrite(DIR9, HIGH);//Direction OFF
route1_state = Active;
case Active: {
if (mcp2.digitalRead(SEN5) == HIGH) {
route1_state = Clearing;
case Clearing: {
mcp3.digitalWrite(R2ABC, LOW);//Mimic R2ABC RED
// ...... Route 1A from Sensor 5 to Platform 3 Up and Left at Point 2 .......
switch (route1A_state) {
case Idle: {
SEN5_in_use = true;
route1A_state = Active;
case Active: {
route1A_state = Clearing;
case Clearing: {
// ...... Route 6 from Sensor 4 ot Platform 4 UP Line .......
switch (route6_state) {
case Idle: {
if (mcp2.digitalRead(SEN4) == LOW && mcp2.digitalRead(SW17) == HIGH) {
mcp4.digitalWrite(TR6LED,HIGH);
if (mcp2.digitalRead(SEN4) == LOW && mcp2.digitalRead(SW17) == LOW) {
if (mcp2.digitalRead(SW17) == LOW && !SEN4_in_use) {
SEN5_in_use = true;
route6_state = Active;
case Active: {
if (mcp2.digitalRead(SEN4) == HIGH) {
route6_state = Clearing;
case Clearing: {
// ...... Route 6A from Sensor 4 to Platform 4 Up Line .......
switch (route6A_state) {
case Idle: {
SEN4_in_use = true;
route6A_state = Active;
case Active: {
route6A_state = Clearing;
case Clearing: {
