If a want to put a switch between a signal that controls a relay, do I need to bind the switch to ground also?
Consider this: I write a high value on digital pin 7, causing the relay to power a 12V device.
Can I put my switch between the pin 7 and relay, without the need of any resistors? Or do I need to set the pin mode on pin 7 to pullup? Or do I need to connect the switch to ground, like this:
See attachment for complete circuit:
http://forum.arduino.cc/index.php?action=dlattach;topic=360474.0;attach=144290
