I'm sure this is a stupid question, but, is it possible to use a Mega TFT screen/shield on a Due. This is the screen that I have which I have working with a mega but it is a bit slow. I was loaned a Due for another project and am trying to resist temptation to use it on it.
As long as you have DUE driver and can wire it.... should be able to. I have just recently wired a mega2650 SSD1289 shield to a DUE and get blazing speed. (~200 320*240 screen clears a second).
First, get it going on the Mega as intended... verify it works etc.
Then... wire it to the Mega as the pins will be 1:1 and in the same position. What you want to do is find out exactly what pins are needed.
For mine all I needed for the TFT was the 16 data lines, 4 control lines and gnd/vcc.
The port mapping on the DUE is different so if you have a 8 or 16 bit interface you need to make sure the pins for db0-7/db8-15 on your TFT match with the DUE ports.
Matching the 16 data lines on mine was a nightmare because of the horrible sequences.
Also... DUE is 3.3V and Mega is 5v... make sure the TFT is 3.3/5v compatible or like mine with a 3v3/5v switch.
Forget Hoek's advice........... Use UTFT libraries....... by Henning Karlsen.......... and the appropriate shield for whatever Arduino you are using......... everything works fine!!!
