Using milli () delay instead of delay
maybe it would be benefical if we could go through the example code
Mountain Standard time here, that's 2 hours after you.
We will get to what SwitchManager does in a few minutes.
Consider this:
  • we want the LCD to display a message on the screen example Temp = 23'C.
  • every time we push a switch we go to the next screen. example Humidity = 14%
We use a state machine to accomplish this task.
Makes sense ?
i think so the switch is what determines the state ?
would the obtaining the measurements be a static state ?
No
The switch is used to ask the State Machine to advance to the next state.
Each time the switch is pressed its says, hey Mr. State Machine please advance to the next state.
Okay ?
"would the obtaining the measurements be a static state ?"
Obtaining measurements will be done on a cyclic basis, i.e. First we read and save the Temperature, then the Humidity, then the Moisture of the soil. We can the scroll thru the LCD State Machine to display these saved readings on the individual LCD screen shots.
Then we will use the saved information to effect changes i.e. Turn on a fan, operate a servo motor, fill a water tank etc.
Okay ?
When ready, we can continue . . .
okay i get that and turning the fan on , opertaing the servo motor those would be states
to scroll through lcd we use lcd.autoscroll() ?
Those control actions could be placed in a Control State Machine and your updating of your LCD would be in their LCD State Machine, You can add as many State Machines as you need in your sketch.
When ready, we can continue to advance . . .
Slow down we will take this one step at a time.
When you are ready, we will go thru the sketch.
okay i think i have the hang of it , when im taking my measurements i want the lcd to display the value and an led to go on
so i will have two state machines?
one for the lcd and one for the leds ?
That would work.
  • Are you are ready go thru the sketch.
yeah lets do it
im not sure if it would be easier to go through this on discord with screen share if you would prefer that just lmk
I think doing here might be useful to others that want to start a new project but need to learn the basics.
Question
Do you know what an Arduino library does for you ?
yeah i think so , it includes commands you can call to right ?
A library is code that some has written to handle complex things that otherwise we have to handle.
For example, the 4 libraries in you code look after how we communicate with the different hardware in your project.
Does the above image make sense to you ?
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Thank you.
See post #116
hey larry so sorry for the delay i was bring my printer down stairs and my dog ran behind me and it broke so i had to clean it up and try to fix it , but im back now
so libraries are like sub codes that allow us to integrate different sensors with each other
