Hi! I am using the Adafruit ultimate logger shield to parse through GGA and GMC data. I was following this tutorial (Hardware Serial Connect | Adafruit Ultimate GPS Logger Shield | Adafruit Learning System) and was using the GPS_Hardwareserial_Parsing example code from the Adafruit GPS library. From the tutorial, I am supposed to set the switch to the "Soft. Serial" position, then add jumper wires from the auxiliary header row's TX/RX to pins 1/0.
However, when I run the code I get this error message.
The only way I've found to fix this issue is to disconnect the TX/RX pins from pins 1/0 to upload the code. Then after the code is done uploading I can reconnect the TX/RX pins to pins 1/0 and the program works as it is supposed to.
How can I fix this issue so that I don't have to disconnect the pins every time I upload the code and then reconnect them once it is done uploading?
Secondly, most of the time the GNGGA and GNRMC data appear as the top section where a new line is made after each GNGGA and GNRMC line of data. However, every once in a while the lines will appear as in the bottom section of code where they appear on one line. I did not change any of the example code in the GPS_Hardwareserial_Parsing so I am not sure why this happens.
Thanks in advance for your help!
