I need to change the code to check the state of the push-button. The first time the button is pressed, freeze the current colour. On the second and subsequent presses, jump to a new (random) colour and freeze on the new colour.
I tried using states as per the Arduino tutorial, but its not working.
My button is on Pin 10
int red = 12;
int green = 14;
int blue = 15;
int redNow;
int blueNow;
int greenNow;
int redNew;
int blueNew;
int greenNew;
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
redNow = random(255);
blueNow = random(255);
greenNow = random(255);
redNew = redNow;
blueNew = blueNow;
greenNew = greenNow;
#define fade(x,y) if (x>y) x--; else if (x<y) x++;
if ((redNow == redNew) &&
(blueNow == blueNew) &&
(greenNow == greenNew))
redNew = random(255);
blueNew = random(255);
greenNew = random(255);
fade(redNow,redNew)
fade(blueNow,blueNew)
fade(greenNow,greenNew)
analogWrite(blue, blueNow);
analogWrite(red, redNow);
analogWrite(green, greenNow);
delay(20);
It sorta sounds like you confuse button state, and button toggle.
Maybe what you are wanting is: While the button state is pressed, find random light numbers, then when released, hold that number.
Could that be what you want?
(1) Those buttons don't always make good contact with a breadboard as their legs are too short.
(2) You have wired up your button wrong. The pulldown resistor should be connected to the same pin of the switch as the wire going to the Arduino input. You have connected it to the wire going to the power supply.
(3) Have you connected the red power rails on each side of the breadboard? You have connected VCC to the red line on one side, but connected the button to the red line on the other side - these two lines aren't connected unless you add a wire to do so.
