I can't get it working, i have a VC0706 Camera "VC0706-3-3V-Camera-Module-TTL-UART-Jpeg-CVBS-For-AVR-STM32-Arduino-Compatible"
I had follow all steps from http://learn.adafruit.com/ttl-serial-camera, so it works with VC0706CommTool at 115200 bauds but one i try to make it work with snap shot example I just get this response from console when arduino try to locate the camera:
VC0706 Camera snapshot test
No camera found?
I also tried to change baud rate in the code:
if (cam.begin(115200))
I can't find out what is wrong, please what can I do?
as discribed at adafruit site, the only baud rate possible is 38400. I suggest to verify before that signal TV is ok and the use common tool as specified. it's just simple.
So, did we ever get it to work? What was the problem? I am trying to use the example code given and having no luck. Like you, only the comm tool is working properly...
