Very confused after compile
i advanced a bit, the problem comes from the monochrome bitmaps that i use in the sketch, but unknow how to evade the problem without use these bitmaps.
I made a test with this code and the problem appears again.
// BMP-loading example specifically for the TFTLCD breakout board.
// If using the Arduino shield, use the tftbmp_shield.pde sketch instead!
// If using an Arduino Mega make sure to use its hardware SPI pins, OR make
// sure the SD library is configured for 'soft' SPI in the file Sd2Card.h.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// For Arduino Uno/Duemilanove, etc
//  connect the SD card with DI going to pin 11, DO going to pin 12 and SCK going to pin 13 (standard)
//  Then pin 10 goes to CS (or whatever you have set up)
#define SD_CS 10     // Set the chip select line to whatever you use (10 doesnt conflict with the library)
// In the SD card, place 24 bit color BMP files (be sure they are 24-bit!)
// There are examples in the sketch folder
// our TFT wiring
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, A4);
static const unsigned char PROGMEM nieve[] =
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x01, 0xfc, 0x00,
  0x7e, 0x00, 0x1f, 0x80, 0x07, 0xe0, 0x03, 0xf8, 0x00, 0xfe, 0x00, 0x3f, 0x00, 0x0f, 0xc0, 0x03,
  0xf0, 0x01, 0xfc, 0x00, 0x7e, 0x00, 0x1f, 0x80, 0x07, 0xe0, 0x03, 0xf8, 0x00, 0xfe, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x03, 0x70, 0x01, 0xdc, 0x00, 0x76, 0x00, 0x1d, 0x80, 0x06, 0xe0, 0x03, 0xb8,
  0x00, 0xee, 0x00, 0x3b, 0x00, 0x0d, 0xc0, 0x03, 0x70, 0x01, 0xdc, 0x00, 0x66, 0x00, 0x1b, 0x80,
  0x06, 0xe0, 0x03, 0xb8, 0x00, 0xce, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x70, 0x01, 0xdc, 0x00,
  0x76, 0x00, 0x1d, 0x80, 0x06, 0x60, 0x03, 0xb8, 0x00, 0xce, 0x00, 0x3f, 0x00, 0x0c, 0xc0, 0x03,
  0x70, 0x01, 0x9c, 0x00, 0x66, 0x00, 0x1b, 0x80, 0x06, 0x60, 0x03, 0xb8, 0x00, 0xde, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x03, 0xf0, 0x01, 0xfc, 0x00, 0x7e, 0x00, 0x1f, 0x80, 0x07, 0xe0, 0x03, 0xf8,
  0x00, 0xfe, 0x00, 0x3f, 0x00, 0x0f, 0xc0, 0x03, 0xf0, 0x01, 0xfc, 0x00, 0x7e, 0x00, 0x1f, 0x80,
  0x07, 0xe0, 0x03, 0xf8, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x03, 0xf0, 0x01, 0xfc, 0x00,
  0x7f, 0x00, 0x1f, 0x80, 0x07, 0xe0, 0x03, 0xf8, 0x00, 0xfe, 0x00, 0x3f, 0x80, 0x0f, 0xc0, 0x03,
  0xf0, 0x01, 0xfc, 0x00, 0x7f, 0x00, 0x1f, 0x80, 0x07, 0xe0, 0x03, 0xf8, 0x00, 0xfe, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00,
  0x10, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x40, 0x00, 0x04, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
  0x80, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x24, 0x00, 0x0b,
  0x00, 0x02, 0x80, 0x00, 0x20, 0x00, 0x48, 0x00, 0x16, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x10,
  0x00, 0x24, 0x00, 0x0a, 0x00, 0x02, 0x00, 0x00, 0x20, 0x00, 0x48, 0x00, 0x12, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x30, 0x00, 0x0c, 0x00, 0x03, 0x00, 0x01, 0x80, 0x00, 0x70, 0x00, 0x18, 0x00,
  0x04, 0x00, 0x01, 0x80, 0x00, 0x60, 0x00, 0x10, 0x00, 0x04, 0x00, 0x03, 0x00, 0x00, 0x80, 0x00,
  0x70, 0x00, 0x18, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x04, 0x40, 0x01, 0x15, 0x00, 0x46, 0x50, 0x31, 0x94, 0x08, 0x66, 0x02, 0x21, 0x80,
  0xca, 0xa0, 0x52, 0x20, 0x05, 0x20, 0x01, 0x4c, 0x00, 0x44, 0x00, 0x24, 0x80, 0x0c, 0x40, 0x03,
  0xbc, 0x00, 0xae, 0x00, 0x21, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x40, 0x00, 0x11, 0x40, 0x02,
  0x20, 0x20, 0x88, 0x08, 0x92, 0x02, 0x3a, 0x40, 0xc8, 0xc0, 0x52, 0x20, 0x05, 0x00, 0x01, 0x48,
  0x00, 0x44, 0x00, 0x14, 0x80, 0x0c, 0x40, 0x02, 0x38, 0x00, 0x09, 0x00, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x05, 0x52, 0x00, 0x55, 0x00, 0x12, 0x50, 0x20, 0x94, 0x08, 0x92, 0x02, 0x2a, 0x41,
  0xa8, 0xa0, 0x48, 0x20, 0x04, 0x88, 0x01, 0x48, 0x00, 0x44, 0x00, 0x18, 0x80, 0x08, 0x40, 0x02,
  0x28, 0x00, 0x28, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x20, 0x04,
  0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x10, 0x04, 0x00,
  0x00, 0x40, 0x00, 0x18, 0x00, 0x0a, 0x00, 0x02, 0x80, 0x80, 0x20, 0x00, 0x02, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x10, 0x08, 0x00, 0x00, 0x00,
  0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x00, 0x10, 0x00, 0x04, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x08,
  0x00, 0x02, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x10, 0x00, 0x04, 0x00, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x20, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x10, 0x00, 0x24, 0x00, 0x0b, 0x00, 0x02, 0xc0, 0x00, 0x00, 0x00, 0x08, 0x00,
  0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x04, 0x00, 0x08, 0x00, 0x00, 0x80, 0x00,
  0x20, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x08,
  0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xb0, 0x00, 0x2c, 0x00, 0x0b, 0x00, 0x02, 0xc0, 0x01, 0xa0, 0x00, 0x50, 0x00,
  0x16, 0x00, 0x05, 0x80, 0x01, 0x40, 0x00, 0x90, 0x00, 0x24, 0x00, 0x08, 0x00, 0x02, 0x00, 0x01,
  0xa0, 0x00, 0x48, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x0c, 0x00, 0x03,
  0x00, 0x00, 0xc0, 0x00, 0x20, 0x00, 0x18, 0x00, 0x02, 0x00, 0x01, 0x80, 0x00, 0x40, 0x00, 0x10,
  0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x46, 0x01, 0x50, 0x80, 0x94,
  0x10, 0x20, 0x04, 0x0a, 0x82, 0x02, 0x92, 0x80, 0x8a, 0x80, 0x41, 0x28, 0x10, 0xca, 0x01, 0x1e,
  0x01, 0x15, 0x40, 0xc4, 0x40, 0x08, 0x40, 0x02, 0x30, 0x00, 0xa8, 0x00, 0x0a, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x05, 0x46, 0x00, 0x50, 0x00, 0x98, 0x00, 0x26, 0x0c, 0x09, 0x86, 0x03, 0xab, 0x80,
  0x04, 0xe0, 0x61, 0x28, 0x10, 0xce, 0x01, 0x1e, 0x00, 0x11, 0x40, 0xc0, 0x40, 0x0c, 0x00, 0x02,
  0x80, 0x00, 0xe2, 0x00, 0x08, 0x80, 0x00, 0x00, 0x00, 0x00, 0x05, 0x60, 0x01, 0x54, 0xc0, 0xe5,
  0x60, 0x29, 0x14, 0x0a, 0x02, 0x00, 0xa6, 0x00, 0x24, 0xa0, 0x40, 0x28, 0x15, 0x22, 0x01, 0x02,
  0x00, 0x55, 0x00, 0x81, 0x50, 0x08, 0x10, 0x02, 0x84, 0x00, 0xa2, 0x00, 0x2a, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x41, 0xc0, 0x00, 0x00, 0x80, 0x00, 0x20, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
  0x00, 0x00, 0x20, 0x40, 0x02, 0x40, 0x06, 0x00, 0x00, 0x80, 0x00, 0x20, 0x00, 0x00, 0x00, 0x02,
  0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x08,
  0x00, 0x02, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x20, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0e, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0d, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x40,
  0x00, 0x00, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x00, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x0d,
  0x80, 0x01, 0x20, 0x01, 0xf8, 0x00, 0xa2, 0x00, 0x0e, 0x00, 0x03, 0x00, 0x00, 0xc0, 0x00, 0x20,
  0x00, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x09, 0x80, 0x00, 0x20, 0x01, 0x48, 0x01, 0xa4, 0x00,
  0x13, 0x00, 0x01, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x1c, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
  0x00, 0x07, 0x60, 0x01, 0x40, 0x00, 0xa8, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x10,
  0x00, 0x14, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x02, 0x40, 0x00, 0xf0, 0x00, 0x10, 0x00,
  0x18, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x18, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
  0x00, 0x06, 0xe0, 0x00, 0x48, 0x00, 0x2b, 0x00, 0x25, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x18,
  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x40, 0x03, 0x4c, 0x00, 0x49, 0x00,
  0x67, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x18, 0x00, 0x00, 0x00, 0x02, 0x00, 0x01, 0x00, 0x00,
  0x00, 0x00, 0x10, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
  0x00, 0x04, 0x00, 0x01, 0xf8, 0x00, 0x8f, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x01, 0x80, 0x00, 0x10,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x20,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x06,
  0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x30,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xd8, 0x00, 0x1c, 0x00, 0x0d, 0x80, 0x06, 0x60, 0x00, 0x30, 0x00, 0x6c, 0x00,
  0x1b, 0x00, 0x06, 0xc0, 0x03, 0x30, 0x00, 0xd8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x2c, 0x00, 0x00,
  0x80, 0x00, 0x20, 0x00, 0x50, 0x00, 0x40, 0x00, 0x30, 0x00, 0x00, 0x80, 0x02, 0x10, 0x01, 0x84,
  0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0xe0, 0x01, 0xf8, 0x00, 0x70, 0x00, 0x21, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x01, 0xa4, 0x00, 0x0c, 0x00, 0x00, 0x80, 0x00, 0x60, 0x00, 0x90, 0x00, 0x7c, 0x00,
  0x3f, 0x00, 0x01, 0x80, 0x01, 0x20, 0x01, 0x84, 0x00, 0x08, 0x00, 0x02, 0x00, 0x07, 0x00, 0x00,
  0x00, 0x00, 0x0e, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xa4, 0x00, 0x0c, 0x00, 0x03,
  0x00, 0x00, 0xc0, 0x01, 0x10, 0x00, 0x46, 0x00, 0x31, 0x80, 0x01, 0x00, 0x03, 0x30, 0x00, 0xdc,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x06, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x84, 0x00, 0x0c, 0x00, 0x04, 0x00, 0x00, 0x20, 0x03, 0xf8, 0x00, 0x02, 0x00,
  0x31, 0x80, 0x03, 0x00, 0x02, 0x10, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x01,
  0xf8, 0x00, 0x38, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8c, 0x00, 0x0c, 0x00, 0x18,
  0x00, 0x06, 0x20, 0x00, 0x10, 0x00, 0x46, 0x00, 0x11, 0x00, 0x02, 0x00, 0x02, 0x10, 0x00, 0x88,
  0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x78, 0x00, 0x3f, 0x00, 0x1f, 0x80, 0x03, 0xc0, 0x00, 0x10, 0x00, 0x7c, 0x00,
  0x0e, 0x00, 0x02, 0x00, 0x01, 0xe0, 0x00, 0x70, 0x00, 0x08, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x02, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x08,
  0x00, 0x0c, 0xc0, 0x90, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00,
  0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x48, 0x00, 0x08, 0x00, 0x0f, 0x00, 0x01, 0xc0, 0x01, 0xe0, 0x00, 0x7e, 0x00,
  0x1f, 0x00, 0x03, 0x80, 0x02, 0x10, 0x00, 0xf8, 0x00, 0x0e, 0x00, 0x10, 0x80, 0x02, 0x00, 0x01,
  0x08, 0x00, 0x42, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x1c, 0x00, 0x18,
  0x80, 0x06, 0x20, 0x01, 0x18, 0x00, 0x40, 0x00, 0x30, 0x00, 0x0c, 0x40, 0x02, 0x10, 0x00, 0x30,
  0x00, 0x02, 0x00, 0x19, 0x80, 0x06, 0x00, 0x03, 0x98, 0x00, 0x62, 0x00, 0x31, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x5a, 0x00, 0x14, 0x00, 0x18, 0x80, 0x04, 0x00, 0x01, 0x08, 0x00, 0x40, 0x00,
  0x30, 0x00, 0x08, 0x00, 0x02, 0x10, 0x00, 0x20, 0x00, 0x02, 0x00, 0x13, 0x00, 0x06, 0x00, 0x03,
  0x98, 0x00, 0x62, 0x00, 0x21, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x4a, 0x00, 0x22, 0x00, 0x1f,
  0x80, 0x04, 0x00, 0x01, 0x08, 0x00, 0x7c, 0x00, 0x30, 0x00, 0x08, 0x00, 0x03, 0xf0, 0x00, 0x20,
  0x00, 0x02, 0x00, 0x1e, 0x00, 0x06, 0x00, 0x03, 0x68, 0x00, 0xd2, 0x00, 0x21, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x8a, 0x00, 0x32, 0x00, 0x18, 0xc0, 0x04, 0x00, 0x01, 0x08, 0x00, 0x40, 0x00,
  0x3f, 0x00, 0x08, 0xe0, 0x02, 0x10, 0x00, 0x20, 0x00, 0x02, 0x00, 0x1b, 0x00, 0x06, 0x00, 0x03,
  0x68, 0x00, 0xda, 0x00, 0x21, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x10, 0x00, 0x63, 0x00, 0x18,
  0x40, 0x04, 0x20, 0x01, 0x08, 0x00, 0x40, 0x00, 0x30, 0x00, 0x0c, 0x60, 0x02, 0x10, 0x00, 0x20,
  0x00, 0x22, 0x00, 0x19, 0x80, 0x06, 0x00, 0x03, 0x08, 0x00, 0xce, 0x00, 0x31, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x6c, 0x00, 0x41, 0x00, 0x19, 0xc0, 0x02, 0x60, 0x01, 0x30, 0x00, 0x40, 0x00,
  0x30, 0x00, 0x06, 0x40, 0x02, 0x10, 0x00, 0x30, 0x00, 0x36, 0x00, 0x18, 0xc0, 0x02, 0x00, 0x03,
  0x08, 0x00, 0xc6, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0d, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x80, 0x00, 0x00, 0x00, 0x08,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x04, 0x00, 0x00,
  0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x00, 0x3e, 0x00, 0x1f,
  0x80, 0x07, 0xe0, 0x03, 0xf8, 0x00, 0xc2, 0x00, 0x60, 0x80, 0x10, 0x20, 0x02, 0x10, 0x01, 0x84,
  0x00, 0x7f, 0x00, 0x04, 0x00, 0x06, 0x00, 0x00, 0x20, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x84, 0x00, 0x63, 0x00, 0x18, 0xc0, 0x04, 0x20, 0x00, 0x40, 0x00, 0xc2, 0x00,
  0x21, 0x80, 0x18, 0x20, 0x01, 0x20, 0x00, 0x8c, 0x00, 0x02, 0x00, 0x04, 0x00, 0x02, 0x00, 0x00,
  0x20, 0x00, 0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x41, 0x00, 0x18,
  0xc0, 0x06, 0x00, 0x00, 0x40, 0x00, 0xc2, 0x00, 0x31, 0x00, 0x1b, 0x20, 0x01, 0xc0, 0x00, 0x58,
  0x00, 0x04, 0x00, 0x04, 0x00, 0x01, 0x00, 0x00, 0x20, 0x00, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x8c, 0x00, 0x41, 0x00, 0x1f, 0x80, 0x03, 0xc0, 0x00, 0x40, 0x00, 0xc2, 0x00,
  0x11, 0x00, 0x0b, 0x20, 0x00, 0xc0, 0x00, 0x30, 0x00, 0x08, 0x00, 0x04, 0x00, 0x00, 0x80, 0x00,
  0x20, 0x00, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x41, 0x00, 0x19,
  0x00, 0x00, 0x30, 0x00, 0x40, 0x00, 0xc2, 0x00, 0x1a, 0x00, 0x0a, 0xe0, 0x01, 0xe0, 0x00, 0x20,
  0x00, 0x10, 0x00, 0x04, 0x00, 0x00, 0xc0, 0x00, 0x20, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0x00, 0x63, 0x00, 0x19, 0x80, 0x04, 0x30, 0x00, 0x60, 0x00, 0xc6, 0x00,
  0x0e, 0x00, 0x0c, 0xc0, 0x03, 0x30, 0x00, 0x20, 0x00, 0x20, 0x00, 0x04, 0x00, 0x00, 0x40, 0x00,
  0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x3e, 0x00, 0x10,
  0xc0, 0x07, 0xe0, 0x00, 0x40, 0x00, 0x7c, 0x00, 0x0c, 0x00, 0x0c, 0xc0, 0x02, 0x10, 0x00, 0x20,
  0x00, 0x7f, 0x00, 0x04, 0x00, 0x00, 0x20, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
  0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x10, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x18,
  0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x30,
  0x00, 0x04, 0x00, 0x08, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
  0x08, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x80, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x1f,
  0x80, 0x03, 0xc0, 0x01, 0xf8, 0x00, 0x7c, 0x00, 0x3f, 0x00, 0x07, 0x40, 0x03, 0xe0, 0x00, 0xf0,
  0x00, 0x3c, 0x00, 0x08, 0x80, 0x00, 0x80, 0x03, 0xd8, 0x00, 0x5c, 0x00, 0x1f, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x22, 0x00, 0x18, 0x80, 0x04, 0x20, 0x01, 0x18, 0x00, 0x46, 0x00,
  0x08, 0x00, 0x0c, 0xc0, 0x03, 0x30, 0x00, 0x30, 0x00, 0x04, 0x00, 0x09, 0x00, 0x00, 0x80, 0x03,
  0x68, 0x00, 0x46, 0x00, 0x31, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x18,
  0xc0, 0x04, 0x00, 0x01, 0x08, 0x00, 0xfe, 0x00, 0x08, 0x00, 0x08, 0x40, 0x02, 0x10, 0x00, 0x30,
  0x00, 0x04, 0x00, 0x0e, 0x00, 0x00, 0x80, 0x03, 0x4c, 0x00, 0x46, 0x00, 0x21, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x62, 0x00, 0x18, 0xc0, 0x04, 0x00, 0x01, 0x08, 0x00, 0xc0, 0x00,
  0x08, 0x00, 0x08, 0x40, 0x02, 0x10, 0x00, 0x30, 0x00, 0x04, 0x00, 0x0b, 0x00, 0x00, 0x80, 0x03,
  0x4c, 0x00, 0x46, 0x00, 0x21, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x66, 0x00, 0x18,
  0x80, 0x06, 0x20, 0x01, 0x18, 0x00, 0x44, 0x00, 0x08, 0x00, 0x0c, 0xc0, 0x02, 0x10, 0x00, 0x30,
  0x00, 0x04, 0x00, 0x09, 0x80, 0x00, 0x80, 0x03, 0x4c, 0x00, 0x46, 0x00, 0x31, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x1f, 0x00, 0x03, 0xc0, 0x00, 0xe8, 0x00, 0x3c, 0x00,
  0x08, 0x00, 0x07, 0x40, 0x02, 0x10, 0x00, 0xfc, 0x00, 0x04, 0x00, 0x08, 0x80, 0x07, 0xe0, 0x02,
  0x48, 0x00, 0x42, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x10, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x02, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x01, 0x80, 0x00,
  0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x02, 0x00, 0x01, 0x80, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xf8, 0x00, 0x37, 0x00, 0x0b, 0x80, 0x02, 0x60, 0x01, 0xf0, 0x00, 0x46, 0x00,
  0x21, 0x80, 0x10, 0x20, 0x03, 0x30, 0x01, 0x84, 0x00, 0x3e, 0x00, 0x02, 0x00, 0x01, 0x80, 0x00,
  0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x63, 0x00, 0x0c,
  0x00, 0x06, 0x00, 0x00, 0x80, 0x00, 0x46, 0x00, 0x11, 0x00, 0x1b, 0x20, 0x01, 0xe0, 0x00, 0x8c,
  0x00, 0x04, 0x00, 0x06, 0x00, 0x01, 0x80, 0x00, 0x60, 0x00, 0xf2, 0x01, 0x28, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x84, 0x00, 0x63, 0x00, 0x08, 0x00, 0x03, 0xc0, 0x00, 0x80, 0x00, 0x46, 0x00,
  0x13, 0x00, 0x0b, 0x60, 0x00, 0xc0, 0x00, 0xc8, 0x00, 0x08, 0x00, 0x0c, 0x00, 0x01, 0x80, 0x00,
  0x30, 0x00, 0x04, 0x01, 0x28, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x63, 0x00, 0x08,
  0x00, 0x00, 0x20, 0x00, 0x80, 0x00, 0x46, 0x00, 0x0a, 0x00, 0x0e, 0xc0, 0x01, 0xe0, 0x00, 0x58,
  0x00, 0x10, 0x00, 0x06, 0x00, 0x01, 0x80, 0x00, 0x20, 0x00, 0x00, 0x01, 0x88, 0xc0, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xcc, 0x00, 0x22, 0x00, 0x08, 0x00, 0x06, 0x20, 0x00, 0xc0, 0x00, 0x46, 0x00,
  0x0e, 0x00, 0x0c, 0xc0, 0x03, 0x30, 0x00, 0x30, 0x00, 0x60, 0x00, 0x02, 0x00, 0x01, 0x80, 0x00,
  0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0x00, 0x13, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
  0x00, 0x00, 0x00, 0x80, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x02, 0x00, 0x01, 0x80, 0x00,
  0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x02, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x20, 0x01, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  tft.begin(0x9341);
  tft.setRotation(1);
tft.fillScreen(0x0000);
void loop(){
tft.drawBitmap(0, 0, nieve, 320, 240, 0xffff);
Can you tell us what is your projects application?
What are you trying to display?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Some monochrome symbols, the most big is 72x56.
This is what I get from the data in Post #21.
This was an example to recreate the problem.
but is indifferent the size of the bitmaps, i use some bitmaps 56x56, 64x64, etc etc and the problem is showed when i compile dont executing rotation(1) and remains as if I had written in code rotation (0).
about your image, how you get from your TFT the bitmap that i used in example? :scream:
Search "image2cpp"... use any one you find.
Copy the data only (0x??...0x??)
Paste into image2cpp "byte array"
This image I found to be:
  • 320x240
  • read horizontal
Then look in 3. Preview
What is your hardware/TFT? Show a picture of front an back, and if you have the datasheet for it, post that, too. Maybe your TFT does not support rotation?
Is a ILI9341 that can be placed over Arduino Uno, and support rotation, the problem is that when i compile some times launch in the report 2 orange lines , when the report launch these 2 orange lines the TFT dont execute the rotation(1), and whitout change nothing in code, i need to compile again and again and again until in report dont appear these 2 orange lines, then the TFT can execute the rotation(1)
(Unknown how i can place an image here, just a link)
but the ILI9341 is the one with the pins on the long sides of the TFT.
is this:
https://i.pinimg.com/originals/a6/47/ae/a647aee81ba9b3a09fb60cc35211c349.jpg
Hi, @miguelyx
Just copy and paste like normal Windows images, or use the Upload symbol.
Thx. :+1:
Can you show the "two orange lines?"
Ofc.
c:\users\migue_000\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\stdint.h:126:22: note: type 'uint8_t' should match type 'uint16_t'
 typedef unsigned int uint8_t __attribute__((__mode__(__QI__)));
c:\users\migue_000\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\stdint.h:128:22: note: the incompatible type is defined here
 typedef unsigned int uint16_t __attribute__ ((__mode__ (__HI__)));
What version of IDE are you using?
My guess: try adding #include<stdint.h> I do not know why a standard package would cause an error. Maybe @ptillisch would like to see this.
My IDE v. is 1.8.16.
Was the 1st step that i was made after read these 2 orange lines and before posting the issue, add stdint.h to the sketck, but it didn't work either.
Finally i found how to resolve, you give me the solve, i updated IDE to last V. 2.2.1 & never show the issue.
When the issue happened the sketch used 3.5k less than the total size, and when it was not produced, the compilation added 3.5k to the total size, now the sketch uses 3.5k less as if it were still happening, but the problem no longer occurs.
