Yeah thanks Ive deleted some parts of the code for lcd cause it kept cruising through all of the pictures on the SD card so Ive removed parts that I thought were doing that and the part that kept loading image all the time cause I don't need it to be loaded every second I just need it to be loaded while the state from the sensor is the same.
My problem now is that sensor just reads the state one time and picture is just loaded 1 time depending ont he state of the sensor. It doesent iterate in void loop for some reason.
#define RESTORE_SPI_GPIO() SPCR = 0
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#if defined(ESP32)
#define SD_CS 5
#else
#define SD_CS 5 //10
#endif
#define NAMEMATCH1 "green.bmp"
#define NAMEMATCH2 "yellow.bmp"
#define NAMEMATCH3 "red.bmp"
#define PALETTEDEPTH 0
char namebuf[32] = "/";
//char namebuf[32] = "/bitmaps/";
File root;
int pathlen;
int A = 2;
int B = 3;
uint16_t ID;
Serial.print("Show BMP files on TFT with ID:0x");
ID = tft.readID();
Serial.println(ID, HEX);
if (ID == 0x0D3D3) ID = 0x9481;
tft.begin(ID);
tft.fillScreen(0x001F);
tft.setTextColor(0xFFFF, 0x0000);
bool good = SD.begin(SD_CS);
if (!good) {
Serial.print(F("cannot start SD"));
while (1);
root = SD.open(namebuf);
pathlen = strlen(namebuf);
pinMode (A, INPUT);
pinMode (B, INPUT);
char *nm = namebuf + pathlen;
File f = root.openNextFile();
uint8_t ret;
uint32_t start;
if (f != NULL) {
#ifdef USE_SDFAT
f.getName(nm, 32 - pathlen);
#else
strcpy(nm, (char *)f.name());
#endif
f.close();
RESTORE_SPI_GPIO();
strlwr(nm);
int a = digitalRead(A);
int b = digitalRead(B);
Serial.println("Vrijednost A:");
Serial.println(a);
Serial.println("Vrijednost B:");
Serial.println(b);
if(a==LOW && b==LOW){
if (strstr(nm, ".bmp") != NULL && strstr(nm, NAMEMATCH1) != NULL) {
Serial.print(namebuf);
//Serial.print(F(" - "));
tft.fillScreen(0);
//start = millis();
ret = showBMP(namebuf, 5, 5);
if(a==LOW && b==HIGH) {
if (strstr(nm, ".bmp") != NULL && strstr(nm, NAMEMATCH2) != NULL) {
tft.fillScreen(0);
//start = millis();
if(a==HIGH && b==LOW) {
tft.fillScreen(0);
//start = millis();
if(a==HIGH && b==HIGH){
if (strstr(nm, ".bmp") != NULL && strstr(nm, NAMEMATCH3) != NULL) {
tft.fillScreen(0);
//start = millis();
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL 20
uint16_t read16(File& f) {
uint16_t result;
f.read((uint8_t*)&result, sizeof(result));
return result;
uint32_t read32(File& f) {
uint32_t result;
return result;
uint8_t showBMP(char *nm, int x, int y)
File bmpFile;
int bmpWidth, bmpHeight;
uint8_t bmpDepth;
uint32_t bmpImageoffset;
uint32_t rowSize;
uint8_t sdbuffer[3 * BUFFPIXEL];
uint16_t lcdbuffer[(1 << PALETTEDEPTH) + BUFFPIXEL], *palette = NULL;
uint8_t bitmask, bitshift;
boolean flip = true;
int w, h, row, col, lcdbufsiz = (1 << PALETTEDEPTH) + BUFFPIXEL, buffidx;
uint32_t pos;
boolean is565 = false;
uint16_t bmpID;
uint16_t n;
uint8_t ret;
if ((x >= tft.width()) || (y >= tft.height()))
return 1; // off screen
bmpFile = SD.open(nm);
bmpID = read16(bmpFile);
(void) read32(bmpFile);
bmpImageoffset = read32(bmpFile);
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
n = read16(bmpFile);
bmpDepth = read16(bmpFile);
pos = read32(bmpFile);
if (bmpID != 0x4D42) ret = 2;
else if (n != 1) ret = 3;
else if (pos != 0 && pos != 3) ret = 4;
else if (bmpDepth < 16 && bmpDepth > PALETTEDEPTH) ret = 5;
else {
bool first = true;
is565 = (pos == 3);
rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
if (bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
w = bmpWidth;
h = bmpHeight;
RESTORE_SPI_GPIO();
tft.setRotation(w > h ? 1 : 0);
if ((x + w) >= tft.width())
w = tft.width() - x;
if ((y + h) >= tft.height())
h = tft.height() - y;
if (bmpDepth <= PALETTEDEPTH) {
bmpFile.seek(BMPIMAGEOFFSET);
bitmask = 0xFF;
if (bmpDepth < 8)
bitmask >>= bmpDepth;
bitshift = 8 - bmpDepth;
n = 1 << bmpDepth;
lcdbufsiz -= n;
palette = lcdbuffer + lcdbufsiz;
for (col = 0; col < n; col++) {
palette[col] = ((pos & 0x0000F8) >> 3) | ((pos & 0x00FC00) >> 5) | ((pos & 0xF80000) >> 8);
RESTORE_SPI_GPIO();
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
for (row = 0; row < h; row++) {
uint8_t r, g, b, *sdptr;
int lcdidx, lcdleft;
if (flip)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
pos = bmpImageoffset + row * rowSize;
if (bmpFile.position() != pos) {
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer);
for (col = 0; col < w; ) {
lcdleft = w - col;
if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) {
uint16_t color;
if (buffidx >= sizeof(sdbuffer)) {
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0;
r = 0;
switch (bmpDepth) {
case 24:
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
color = tft.color565(r, g, b);
case 16:
if (is565)
color = (r << 8) | (b);
color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
case 1:
case 4:
case 8:
if (r == 0)
b = sdbuffer[buffidx++], r = 8;
color = palette[(b >> bitshift) & bitmask];
r -= bmpDepth;
b <<= bmpDepth;
lcdbuffer[lcdidx] = color;
RESTORE_SPI_GPIO();
tft.pushColors(lcdbuffer, lcdidx, first);
first = false;
col += lcdidx;
tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
ret = 0;
bmpFile.close();
RESTORE_SPI_GPIO();
return (ret);
