* @file vr_sample_train.ino
* @author JiapengLi
* @brief This file provides a demostration on
* how to train VoiceRecognitionModule to record your voice
* @note:
* Use serial command to control VoiceRecognitionModule. '
* All commands are case insensitive. Default serial baud rate 115200.
* COMMAND FORMAT EXAMPLE Comment
* train train (r0) (r1)... train 0 2 45 Train records
* load load (r0) (r1) ... load 0 51 2 3 Load records
* clear clear clear remove all records in Recognizer
* record record / record (r0) (r1)... record / record 0 79 Check record train status
* vr vr vr Check recognizer status
* getsig getsig (r) getsig 0 Get signature of record (r)
* sigtrain sigtrain (r) (sig) sigtrain 0 ZERO Train one record(r) with signature(sig)
* settings settings settings Check current system settings
* @section HISTORY
* 2013/06/13 Initial version.
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
* Connection
* Arduino VoiceRecognitionModule
* 2 -------> TX
* 3 -------> RX
VR myVR(2,3); // 2:RX 3:TX, you can choose your favourite pins.
/** declare print functions */
void printSeperator();
void printSignature(uint8_t *buf, int len);
void printVR(uint8_t *buf);
void printLoad(uint8_t *buf, uint8_t len);
void printTrain(uint8_t *buf, uint8_t len);
void printCheckRecognizer(uint8_t *buf);
void printUserGroup(uint8_t *buf, int len);
void printCheckRecord(uint8_t *buf, int num);
void printCheckRecordAll(uint8_t *buf, int num);
void printSigTrain(uint8_t *buf, uint8_t len);
void printSystemSettings(uint8_t *buf, int len);
void printHelp(void);
// command analyze part
#define CMD_BUF_LEN 64+1
#define CMD_NUM 10
typedef int (*cmd_function_t)(int, int);
uint8_t cmd[CMD_BUF_LEN];
uint8_t cmd_cnt;
uint8_t *paraAddr;
int receiveCMD();
int checkCMD(int len);
int checkParaNum(int len);
int findPara(int len, int paraNum, uint8_t **addr);
int compareCMD(uint8_t *para1 , uint8_t *para2, int len);
int cmdTrain(int len, int paraNum);
int cmdLoad(int len, int paraNum);
int cmdTest(int len, int paraNum);
int cmdVR(int len, int paraNum);
int cmdClear(int len, int paraNum);
int cmdRecord(int len, int paraNum);
int cmdSigTrain(int len, int paraNum);
int cmdGetSig(int len, int paraNum);
int cmdSettings(int len, int paraNum);
int cmdHelp(int len, int paraNum);
/** cmdList, cmdLen, cmdFunction has correspondence */
const char cmdList[CMD_NUM][10] = { // command list table
"train" }
"load" }
"clear" }
"vr" }
"record" }
"sigtrain" }
"getsig" }
"Settings" }
"test" }
"help" }
const char cmdLen[CMD_NUM]= { // command length
5, // {"train"},
4, // {"load"},
5, // {"clear"},
2, // {"vr"},
6, // {"record"},
8, // {"sigtrain"},
6, // {"getsig"},
8, // {"Settings"},
4, // {"test"},
4, // {"help"}
cmd_function_t cmdFunction[CMD_NUM]={ // command handle fuction(function pointer table)
cmdTrain,
cmdLoad,
cmdClear,
cmdVR,
cmdRecord,
cmdSigTrain,
cmdGetSig,
cmdSettings,
cmdTest,
cmdHelp,
//CMD_NUM = 4; // cmd_num's load
//cmd_function_t cmdFunction[CMD_NUM] = cmdLoad;
/** temprory data */
uint8_t buf[255];
uint8_t records[7]; // save record
void setup(void)
myVR.begin(9600);
pinMode(11 ,OUTPUT);
pinMode(9,INPUT);
/** initialize */
Serial.println(F("Elechouse Voice Recognition V3 Module \"train\" sample."));
printSeperator();
Serial.println(F("Usage:"));
printSeperator();
printHelp();
printSeperator();
cmd_cnt = 0;
void loop(void)
int len, paraNum, paraLen, i;
/** receive Serial command */
len = receiveCMD();
if(len>0){
/** check if the received command is valid */
if(!checkCMD(len)){
/** check parameter number of the received command */
paraNum = checkParaNum(len);
/** display the receved command back */
Serial.write(cmd, len);
/** find the first parameter */
paraLen = findPara(len, 1, ¶Addr);
/** compare the received command with command in the list */
for(i=0; i<CMD_NUM; i++){
/** compare command length */
if(paraLen == cmdLen[i]){
/** compare command content */
if( compareCMD(paraAddr, (uint8_t *)cmdList[i], paraLen) == 0 ){
/** call command function */
if( cmdFunction[i](len, paraNum) != 0){
printSeperator();
Serial.println(F("Command Format Error!"));
printSeperator();
/** command is not supported*/
if(i == CMD_NUM){
printSeperator();
Serial.println(F("Unkonwn command"));
printSeperator();
else{
/** received command is invalid */
printSeperator();
Serial.println(F("Command format error"));
printSeperator();
/** try to receive recognize result */
int ret;
ret = myVR.recognize(buf, 50);
if(ret>0){
/** voice recognized, print result */
printVR(buf);
int B = digitalRead(9);
if (B == HIGH){
Serial.println(F("load 0 1 2"));
* @brief receive command from Serial.
* @param NONE.
* @retval command length, if no command receive return -1.
int receiveCMD()
int ret;
int len;
unsigned long start_millis;
start_millis = millis();
while(1){
ret = Serial.read();
if(ret>0){
cmd[cmd_cnt] = ret;
if(cmd[cmd_cnt] == '\n'){
len = cmd_cnt+1;
cmd_cnt = 0;
return len;
cmd_cnt++;
if(cmd_cnt == CMD_BUF_LEN){
cmd_cnt = 0;
return -1;
if(millis() - start_millis > 100){
cmd_cnt = 0;
return -1;
* @brief compare two commands, case insensitive.
* @param para1 --> command buffer 1
* para2 --> command buffer 2
* len --> buffer length
* @retval 0 --> equal
* -1 --> unequal
int i;
uint8_t res;
for(i=0; i<len; i++){
res = para2[i] - para1[i];
if(res != 0 && res != 0x20){
res = para1[i] - para2[i];
return -1;
return 0;
* @brief Check command format.
* @param len --> command length
* @retval 0 --> command is valid
* -1 --> command is invalid
int i;
if(cmd[i] > 0x1F && cmd[i] < 0x7F){
else if(cmd[i] == '\t' || cmd[i] == ' ' || cmd[i] == '\r' || cmd[i] == '\n'){
else{
return -1;
return 0;
* @brief Check the number of parameters in the command
* @retval number of parameters
int cnt=0, i;
for(i=0; i<len; ){
if(cmd[i]!='\t' && cmd[i]!=' ' && cmd[i] != '\r' && cmd[i] != '\n'){
cnt++;
while(cmd[i] != '\t' && cmd[i] != ' ' && cmd[i] != '\r' && cmd[i] != '\n'){
i++;
i++;
return cnt;
* @brief Find the specified parameter.
* paraIndex --> parameter index
* addr --> return value. position of the parameter
* @retval length of specified parameter
int findPara(int len, int paraIndex, uint8_t **addr)
int cnt=0, i, paraLen;
uint8_t dt;
for(i=0; i<len; ){
dt = cmd[i];
if(dt!='\t' && dt!=' '){
cnt++;
if(paraIndex == cnt){
*addr = cmd+i;
paraLen = 0;
i++;
paraLen++;
return paraLen;
else{
i++;
else{
i++;
return -1;
if(paraNum != 1){
return -1;
printSeperator();
printHelp();
printSeperator();
return 0;
* @brief Handle "train" command
* paraNum --> number of parameters
* @retval 0 --> success
* -1 --> Command format error
int i, ret;
if(paraNum < 2 || paraNum > 8 ){
return -1;
for(i=2; i<=paraNum; i++){
findPara(len, i, ¶Addr);
records[i-2] = atoi((char *)paraAddr);
if(records[i-2] == 0 && *paraAddr != '0'){
return -1;
printSeperator();
ret = myVR.train(records, paraNum-1, buf);
// ret = myVR.train(records, paraNum-1);
if(ret >= 0){
printTrain(buf, ret);
else if(ret == -1){
Serial.println(F("Train failed."));
else if(ret == -2){
Serial.println(F("Train Timeout."));
printSeperator();
return 0;
* @brief Handle "load" command
int i, ret;
return -1;
return -1;
// myVR.writehex(records, paraNum-1);
ret = myVR.load(records, paraNum-1, buf);
printSeperator();
if(ret >= 0){
printLoad(buf, ret);
else{
Serial.println(F("Load failed or timeout."));
printSeperator();
return 0;
* @brief Handle "clear" command
if(paraNum != 1){
return -1;
if(myVR.clear() == 0){
printSeperator();
Serial.println(F("Recognizer cleared."));
printSeperator();
else{
printSeperator();
Serial.println(F("Clear recognizer failed or timeout."));
printSeperator();
return 0;
* @brief Handle "vr" command
int ret;
if(paraNum != 1){
return -1;
ret = myVR.checkRecognizer(buf);
if(ret<=0){
printSeperator();
Serial.println(F("Check recognizer failed or timeout."));
printSeperator();
return 0;
printSeperator();
printCheckRecognizer(buf);
printSeperator();
return 0;
* @brief Handle "record" command
int ret;
if(paraNum == 1){
ret = myVR.checkRecord(buf);
printSeperator();
if(ret>=0){
printCheckRecordAll(buf, ret);
else{
Serial.println(F("Check record failed or timeout."));
printSeperator();
else if(paraNum < 9){
for(int i=2; i<=paraNum; i++){
return -1;
ret = myVR.checkRecord(buf, records, paraNum-1); // auto clean duplicate records
printSeperator();
if(ret>=0){
printCheckRecord(buf, ret);
else{
printSeperator();
else{
return -1;
return 0;
* @brief Handle "sigtrain" command
int ret, sig_len;
uint8_t *lastAddr;
if(paraNum < 2){
return -1;
findPara(len, 2, ¶Addr);
records[0] = atoi((char *)paraAddr);
if(records[0] == 0 && *paraAddr != '0'){
return -1;
findPara(len, 3, ¶Addr);
sig_len = findPara(len, paraNum, &lastAddr);
sig_len +=( (unsigned int)lastAddr - (unsigned int)paraAddr );
printSeperator();
ret = myVR.trainWithSignature(records[0], paraAddr, sig_len, buf);
// ret = myVR.trainWithSignature(records, paraNum-1);
if(ret >= 0){
printSigTrain(buf, ret);
else{
Serial.println(F("Train with signature failed or timeout."));
printSeperator();
return 0;
* @brief Handle "getsig" command
int ret;
if(paraNum != 2){
return -1;
return -1;
ret = myVR.checkSignature(records[0], buf);
printSeperator();
if(ret == 0){
Serial.println(F("Signature isn't set."));
else if(ret > 0){
Serial.print(F("Signature:"));
printSignature(buf, ret);
else{
Serial.println(F("Get sig error or timeout."));
printSeperator();
return 0;
* @brief Handle "test" command
printSeperator();
Serial.println(F("TEST is not supported."));
printSeperator();
return 0;
int ret;
if(paraNum != 1){
return -1;
ret = myVR.checkSystemSettings(buf);
if( ret > 0){
printSeperator();
printSystemSettings(buf, ret);
printSeperator();
else{
printSeperator();
Serial.println(F("Check system settings error or timeout"));
printSeperator();
return 0;
* @brief Print signature, if the character is invisible,
* print hexible value instead.
* @param buf --> command length
* len --> number of parameters
int i;
if(buf[i]>0x19 && buf[i]<0x7F){
Serial.write(buf[i]);
else{
Serial.print(F("["));
Serial.print(buf[i], HEX);
Serial.print(F("]"));
* @param buf --> VR module return value when voice is recognized.
* buf[0] --> Group mode(FF: None Group, 0x8n: User, 0x0n:System
* buf[1] --> number of record which is recognized.
* buf[2] --> Recognizer index(position) value of the recognized record.
* buf[3] --> Signature length
* buf[4]~buf[n] --> Signature
Serial.println(F("VR Index\tGroup\tRecordNum\tSignature"));
Serial.print(buf[2], DEC);
Serial.print(F("\t\t"));
if(buf[0] == 0xFF){
Serial.print(F("NONE"));
else if(buf[0]&0x80){
Serial.print(F("UG "));
Serial.print(buf[0]&(~0x80), DEC);
else{
Serial.print(F("SG "));
Serial.print(buf[0], DEC);
Serial.print(F("\t"));
Serial.print(buf[1], DEC);
if(buf[3]>0){
printSignature(buf+4, buf[3]);
else{
Serial.println(F("\r\n"));
* @brief Print seperator. Print 80 '-'.
for(int i=0; i<80; i++){
Serial.write('-');
* @brief Print recoginizer status.
* buf[0] --> Number of valid voice records in recognizer
* buf[i+1] --> Record number.(0xFF: Not loaded(Nongroup mode), or not set (Group mode)) (i= 0, 1, ... 6)
* buf[8] --> Number of all voice records in recognizer
* buf[9] --> Valid records position indicate.
* buf[10] --> Group mode indicate(FF: None Group, 0x8n: User, 0x0n:System)
Serial.print(F("All voice records in recognizer: "));
Serial.println(buf[8], DEC);
Serial.print(F("Valid voice records in recognizer: "));
Serial.println(buf[0], DEC);
if(buf[10] == 0xFF){
Serial.println(F("VR is not in group mode."));
else if(buf[10]&0x80){
Serial.print(F("VR is in user group mode:"));
Serial.println(buf[10]&0x7F, DEC);
else{
Serial.print(F("VR is in system group mode:"));
Serial.println(buf[10], DEC);
Serial.println(F("VR Index\tRecord\t\tComment"));
for(int i=0; i<7; i++){
Serial.print(i, DEC);
if(buf[i+1] == 0xFF){
Serial.print(F("Unloaded\tNONE"));
else{
Serial.print(F("Not Set\t\tNONE"));
else{
Serial.print(buf[i+1], DEC);
if(buf[9]&(1<<i)){
Serial.print(F("Valid"));
else{
Serial.print(F("Untrained"));
* @brief Print record train status.
* @param buf --> Check record command return value
* buf[0] --> Number of checked records
* buf[2i+1] --> Record number.
* buf[2i+2] --> Record train status. (00: untrained, 01: trained, FF: record value out of range)
* (i = 0 ~ buf[0]-1 )
* num --> Number of trained records
Serial.print(F("Check "));
Serial.println(F(" records."));
Serial.print(num, DEC);
if(num>1){
Serial.println(F(" records trained."));
else{
Serial.println(F(" record trained."));
for(int i=0; i<buf[0]*2; i += 2){
Serial.print(F("\t-->\t"));
switch(buf[i+2]){
case 0x01:
Serial.print(F("Trained"));
case 0x00:
case 0xFF:
Serial.print(F("Record value out of range"));
default:
Serial.print(F("Unknown Stauts"));
Serial.print(F("Check 255"));
if(num>1){
else{
myVR.writehex(buf, 255);
for(int i=0; i<255; i++){
if(buf[i] == 0xF0){
continue;
switch(buf[i]){
case 0x01:
case 0x00:
case 0xFF:
default:
* @brief Print check user group result.
* buf[8i] --> group number.
* buf[8i+1] --> group position 0 status.
* buf[8i+2] --> group position 1 status.
* buf[8i+6] --> group position 5 status.
* buf[8i+7] --> group position 6 status.
* (i = 0 ~ len)
* len --> number of checked groups
int i, j;
Serial.println(F("Check User Group:"));
Serial.print(F("Group:"));
Serial.println(buf[8*i]);
for(j=0; j<7; j++){
if(buf[8*i+1+j] == 0xFF){
Serial.print(F("NONE\t"));
else{
Serial.print(buf[8*i+1+j], DEC);
* @brief Print "load" command return value.
* @param buf --> "load" command return value
* buf[0] --> number of records which are load successfully.
* buf[2i+1] --> record number
* buf[2i+2] --> record load status.
* 00 --> Loaded
* FC --> Record already in recognizer
* FD --> Recognizer full
* FE --> Record untrained
* FF --> Value out of range"
* (i = 0 ~ (len-1)/2 )
* len --> length of buf
if(len == 0){
Serial.println(F("Load Successfully."));
return;
else{
Serial.print(F("Load success: "));
for(int i=0; i<len-1; i += 2){
Serial.print(F("Record "));
switch(buf[i+2]){
case 0:
Serial.println(F("Loaded"));
case 0xFC:
Serial.println(F("Record already in recognizer"));
case 0xFD:
Serial.println(F("Recognizer full"));
case 0xFE:
Serial.println(F("Record untrained"));
case 0xFF:
Serial.println(F("Value out of range"));
default:
Serial.println(F("Unknown status"));
* @brief Print "train" command return value.
* @param buf --> "train" command return value
* buf[0] --> number of records which are trained successfully.
* buf[2i+2] --> record train status.
* 00 --> Trained
* FE --> Train Time Out
* (i = 0 ~ len-1 )
if(len == 0){
Serial.println(F("Train Finish."));
return;
else{
Serial.print(F("Train success: "));
switch(buf[i+2]){
case 0:
Serial.println(F("Trained"));
case 0xFE:
Serial.println(F("Train Time Out"));
case 0xFF:
default:
Serial.print(F("Unknown status "));
Serial.println(buf[i+2], HEX);
* @brief Print "sigtrain" command return value.
* @param buf --> "sigtrain" command return value
* buf[1] --> record number
* buf[2] --> record train status.
* 00 --> Trained
* F0 --> Trained, signature truncate
* buf[3] ~ buf[len-1] --> Signature.
if(len == 0){
Serial.println(F("Train With Signature Finish."));
return;
else{
Serial.print(F("Success: "));
switch(buf[2]){
case 0:
case 0xF0:
Serial.println(F("Trained, signature truncate"));
case 0xFE:
case 0xFF:
default:
Serial.println(buf[2], HEX);
Serial.print(F("SIG: "));
Serial.write(buf+3, len-3);
* @brief Print "settings" command return value.
* @param buf --> "settings" command return value
* 00 --> Trained
const unsigned int io_pw_tab[16]={
10, 15, 20, 25, 30, 35, 40, 45,
50, 75, 100, 200, 300, 400, 500, 1000
switch(buf[0]){
case 0:
case 3:
Serial.println(F("Baud rate: 9600"));
case 1:
Serial.println(F("Baud rate: 2400"));
case 2:
Serial.println(F("Baud rate: 4800"));
case 4:
Serial.println(F("Baud rate: 19200"));
case 5:
Serial.println(F("Baud rate: 38400"));
default:
Serial.println(F("Baud rate: UNKONOWN"));
switch(buf[1]){
case 0:
case 0xFF:
Serial.println(F("Outpu IO Mode: Pulse"));
case 1:
Serial.println(F("Outpu IO Mode: Toggle"));
case 2:
Serial.println(F("Outpu IO Mode: Clear(When recognized) "));
case 3:
Serial.println(F("Outpu IO Mode: Set(When recognized)"));
default:
Serial.println(F("Output IO Mode: UNKONOWN"));
if(buf[2] > 15){
Serial.println(F("Pulse width: UNKONOWN"));
else{
Serial.print(F("Pulse Width: "));
Serial.print(io_pw_tab[buf[2]], DEC);
Serial.println(F("ms"));
if(buf[3] == 0 || buf[3] == 0xFF){
Serial.println(F("Auto Load: disable"));
else{
Serial.println(F("Auto Load: enable"));
switch(buf[4]){
case 0:
case 0xFF:
Serial.println(F("Group control by external IO: disabled"));
case 1:
Serial.println(F("Group control by external IO: system group selected"));
case 2:
Serial.println(F("Group control by external IO: user group selected"));
default:
Serial.println(F("Group control by external IO: UNKNOWN STATUS"));
Serial.println(F("COMMAND FORMAT EXAMPLE Comment"));
printSeperator();
// Serial.println(F("--------------------------------------------------------------------------------------------------------------"));
Serial.println(F("train train (r0) (r1)... train 0 2 45 Train records"));
Serial.println(F("load load (r0) (r1) ... load 0 51 2 3 Load records"));
Serial.println(F("clear clear clear remove all records in Recognizer"));
Serial.println(F("record record / record (r0) (r1)... record / record 0 79 Check record train status"));
Serial.println(F("vr vr vr Check recognizer status"));
Serial.println(F("getsig getsig (r) getsig 0 Get signature of record (r)"));
Serial.println(F("sigtrain sigtrain (r) (sig) sigtrain 0 ZERO Train one record(r) with signature(sig)"));
Serial.println(F("settings settings settings Check current system settings"));
Serial.println(F("help help help print this message"));
