Voice recognition module with mega arduino 2560
I am currently working on a project for college. I am trying to use 2 servos, a lcd screen, RFID scanner, an elechouse Voice Recognition Module V3(Speak Recognition, Voice Recognition Module V3 - ELECHOUSE) and a mega arduino 2560. But I am running into an issue where the voice module doesn't work with the MEGA, i've done lots of searching and found nothing. So im wondering if its even possible with the MEGA.
Please include your complete sketch, enclosed in the handy <CODE/> tag tool, and a schematic, and exactly what doesn't work (i.e what were you expecting to see happen, and what happened instead) and perhaps someone might be able to help you diagnose your problem.
 * @file    vr_sample_train.ino
 * @author  JiapengLi
 * @brief   This file provides a demostration on
 * how to train VoiceRecognitionModule to record your voice
 * @note:
 * Use serial command to control VoiceRecognitionModule. '
 * All commands are case insensitive. Default serial baud rate 115200.
 * COMMAND        FORMAT                        EXAMPLE                    Comment
 * train          train (r0) (r1)...            train 0 2 45               Train records
 * load           load (r0) (r1) ...            load 0 51 2 3              Load records
 * clear          clear                         clear                      remove all records in  Recognizer
 * record         record / record (r0) (r1)...  record / record 0 79       Check record train status
 * vr             vr                            vr                         Check recognizer status
 * getsig         getsig (r)                    getsig 0                   Get signature of record (r)
 * sigtrain       sigtrain (r) (sig)            sigtrain 0 ZERO            Train one record(r) with signature(sig)
 * settings       settings                      settings                   Check current system settings
 * @section  HISTORY
 * 2013/06/13    Initial version.
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
 * Connection
 * Arduino    VoiceRecognitionModule
 * 2   ------->     TX
 * 3   ------->     RX
VR myVR(2,3);    // 2:RX 3:TX, you can choose your favourite pins.
/** declare print functions */
void printSeperator();
void printSignature(uint8_t *buf, int len);
void printVR(uint8_t *buf);
void printLoad(uint8_t *buf, uint8_t len);
void printTrain(uint8_t *buf, uint8_t len);
void printCheckRecognizer(uint8_t *buf);
void printUserGroup(uint8_t *buf, int len);
void printCheckRecord(uint8_t *buf, int num);
void printCheckRecordAll(uint8_t *buf, int num);
void printSigTrain(uint8_t *buf, uint8_t len);
void printSystemSettings(uint8_t *buf, int len);
void printHelp(void);
// command analyze part
#define CMD_BUF_LEN      64+1
#define CMD_NUM     10
typedef int (*cmd_function_t)(int, int);
uint8_t cmd[CMD_BUF_LEN];
uint8_t cmd_cnt;
uint8_t *paraAddr;
int receiveCMD();
int checkCMD(int len);
int checkParaNum(int len);
int findPara(int len, int paraNum, uint8_t **addr);
int compareCMD(uint8_t *para1 , uint8_t *para2, int len);
int cmdTrain(int len, int paraNum);
int cmdLoad(int len, int paraNum);
int cmdTest(int len, int paraNum);
int cmdVR(int len, int paraNum);
int cmdClear(int len, int paraNum);
int cmdRecord(int len, int paraNum);
int cmdSigTrain(int len, int paraNum);
int cmdGetSig(int len, int paraNum);
int cmdSettings(int len, int paraNum);
int cmdHelp(int len, int paraNum);
/** cmdList, cmdLen, cmdFunction has correspondence */
const char cmdList[CMD_NUM][10] = {  // command list table
    "train"  }
    "load"  }
    "clear"  }
    "vr"  }
    "record"  }
    "sigtrain"  }
    "getsig"  }
    "Settings"  }
    "test"  }
    "help"  }
const char cmdLen[CMD_NUM]= {    // command length
  5,  //  {"train"},
  4,  //  {"load"},
  5,  //  {"clear"},
  2,  //  {"vr"},
  6,  //  {"record"},
  8,  //  {"sigtrain"},
  6,  //  {"getsig"},
  8,  //  {"Settings"},
  4,  //  {"test"},
  4,  //  {"help"}
cmd_function_t cmdFunction[CMD_NUM]={      // command handle fuction(function pointer table)
  cmdTrain,
  cmdLoad,
  cmdClear,
  cmdVR,
  cmdRecord,
  cmdSigTrain,
  cmdGetSig,
  cmdSettings,
  cmdTest,
  cmdHelp,
/** temprory data */
uint8_t buf[255];
uint8_t records[7]; // save record
void setup(void)
  myVR.begin(19200);
  /** initialize */
  Serial.println(F("Elechouse Voice Recognition V3 Module \"train\" sample."));
  printSeperator();
  Serial.println(F("Usage:"));
  printSeperator();
  printHelp();
  printSeperator();
  cmd_cnt = 0;
void loop(void)
  int len, paraNum, paraLen, i;
  /** receive Serial command */
  len = receiveCMD();
  if(len>0){
    /** check if the received command is valid */
    if(!checkCMD(len)){
      /** check parameter number of the received command  */
      paraNum = checkParaNum(len);
      /** display the receved command back */
      Serial.write(cmd, len);
      /** find the first parameter */
      paraLen = findPara(len, 1, &paraAddr);
      /** compare the received command with command in the list */
      for(i=0; i<CMD_NUM; i++){
        /** compare command length */
        if(paraLen == cmdLen[i]){
          /** compare command content */
          if( compareCMD(paraAddr, (uint8_t *)cmdList[i], paraLen) == 0 ){
            /** call command function */
            if( cmdFunction[i](len, paraNum) != 0){
              printSeperator();
              Serial.println(F("Command Format Error!"));
              printSeperator();
      /** command is not supported*/
      if(i == CMD_NUM){
        printSeperator();
        Serial.println(F("Unkonwn command"));
        printSeperator();
    else{
      /** received command is invalid */
      printSeperator();
      Serial.println(F("Command format error"));
      printSeperator();
  /** try to receive recognize result */
  int ret;
  ret = myVR.recognize(buf, 50);
  if(ret>0){
    /** voice recognized, print result */
    printVR(buf);
 * @brief   receive command from Serial.
 * @param   NONE.
 * @retval  command length, if no command receive return -1.
int receiveCMD()
  int ret;
  int len;
  unsigned long start_millis;
  start_millis = millis();
  while(1){
    ret = Serial.read();
    if(ret>0){
      cmd[cmd_cnt] = ret;
      if(cmd[cmd_cnt] == '\n'){
        len = cmd_cnt+1;
        cmd_cnt = 0;
        return len;
      cmd_cnt++;
      if(cmd_cnt == CMD_BUF_LEN){
        cmd_cnt = 0;
        return -1;
    if(millis() - start_millis > 100){
      cmd_cnt = 0;
      return -1;
 * @brief   compare two commands, case insensitive.
 * @param   para1  -->  command buffer 1
 * para2  -->  command buffer 2
 * len    -->  buffer length
 * @retval  0  --> equal
 * -1  --> unequal
  int i;
  uint8_t res;
  for(i=0; i<len; i++){
    res = para2[i] - para1[i];
    if(res != 0 && res != 0x20){
      res = para1[i] - para2[i];
        return -1;
  return 0;
 * @brief   Check command format.
 * @param   len  -->  command length
 * @retval  0  -->  command is valid
 * -1  -->  command is invalid
  int i;
    if(cmd[i] > 0x1F && cmd[i] < 0x7F){
    else if(cmd[i] == '\t' || cmd[i] == ' ' || cmd[i] == '\r' || cmd[i] == '\n'){
    else{
      return -1;
  return 0;
 * @brief   Check the number of parameters in the command
 * @retval  number of parameters
  int cnt=0, i;
  for(i=0; i<len; ){
    if(cmd[i]!='\t' && cmd[i]!=' ' && cmd[i] != '\r' && cmd[i] != '\n'){
      cnt++;
      while(cmd[i] != '\t' && cmd[i] != ' ' && cmd[i] != '\r' && cmd[i] != '\n'){
        i++;
    i++;
  return cnt;
 * @brief   Find the specified parameter.
 * paraIndex -->  parameter index
 * addr      -->  return value. position of the parameter
 * @retval  length of specified parameter
int findPara(int len, int paraIndex, uint8_t **addr)
  int cnt=0, i, paraLen;
  uint8_t dt;
  for(i=0; i<len; ){
    dt = cmd[i];
    if(dt!='\t' && dt!=' '){
      cnt++;
      if(paraIndex == cnt){
        *addr = cmd+i;
        paraLen = 0;
          i++;
          paraLen++;
        return paraLen;
      else{
          i++;
    else{
      i++;
  return -1;
  if(paraNum != 1){
    return -1;
  printSeperator();
  printHelp();
  printSeperator();
  return 0;
 * @brief   Handle "train" command
 * paraNum --> number of parameters
 * @retval  0 --> success
 * -1 --> Command format error
  int i, ret;
  if(paraNum < 2 || paraNum > 8 ){
    return -1;
  for(i=2; i<=paraNum; i++){
    findPara(len, i, &paraAddr);
    records[i-2] = atoi((char *)paraAddr);
    if(records[i-2] == 0 && *paraAddr != '0'){
      return -1;
  printSeperator();
  ret = myVR.train(records, paraNum-1, buf);
  //  ret = myVR.train(records, paraNum-1);
  if(ret >= 0){
    printTrain(buf, ret);
  else if(ret == -1){
    Serial.println(F("Train failed."));
  else if(ret == -2){
    Serial.println(F("Train Timeout."));
  printSeperator();
  return 0;
 * @brief   Handle "load" command
  int i, ret;
    return -1;
      return -1;
  //  myVR.writehex(records, paraNum-1);
  ret = myVR.load(records, paraNum-1, buf);
  printSeperator();
  if(ret >= 0){
    printLoad(buf, ret);
  else{
    Serial.println(F("Load failed or timeout."));
  printSeperator();
  return 0;
 * @brief   Handle "clear" command
  if(paraNum != 1){
    return -1;
  if(myVR.clear() == 0){
    printSeperator();
    Serial.println(F("Recognizer cleared."));
    printSeperator();
  else{
    printSeperator();
    Serial.println(F("Clear recognizer failed or timeout."));
    printSeperator();
  return 0;
 * @brief   Handle "vr" command
  int ret;
  if(paraNum != 1){
    return -1;
  ret = myVR.checkRecognizer(buf);
  if(ret<=0){
    printSeperator();
    Serial.println(F("Check recognizer failed or timeout."));
    printSeperator();
    return 0;
  printSeperator();
  printCheckRecognizer(buf);
  printSeperator();
  return 0;
 * @brief   Handle "record" command
  int ret;
  if(paraNum == 1){
    ret = myVR.checkRecord(buf);
    printSeperator();
    if(ret>=0){
      printCheckRecordAll(buf, ret);
    else{
      Serial.println(F("Check record failed or timeout."));
    printSeperator();
  else if(paraNum < 9){
    for(int i=2; i<=paraNum; i++){
        return -1;
    ret = myVR.checkRecord(buf, records, paraNum-1);    // auto clean duplicate records
    printSeperator();
    if(ret>=0){
      printCheckRecord(buf, ret);
    else{
    printSeperator();
  else{
    return -1;
  return 0;
 * @brief   Handle "sigtrain" command
  int ret, sig_len;
  uint8_t *lastAddr;
  if(paraNum < 2){
    return -1;
  findPara(len, 2, &paraAddr);
  records[0] = atoi((char *)paraAddr);
  if(records[0] == 0 && *paraAddr != '0'){
    return -1;
  findPara(len, 3, &paraAddr);
  sig_len = findPara(len, paraNum, &lastAddr);
  sig_len +=( (unsigned int)lastAddr - (unsigned int)paraAddr );
  printSeperator();
  ret = myVR.trainWithSignature(records[0], paraAddr, sig_len, buf);
  //  ret = myVR.trainWithSignature(records, paraNum-1);
  if(ret >= 0){
    printSigTrain(buf, ret);
  else{
    Serial.println(F("Train with signature failed or timeout."));
  printSeperator();
  return 0;
 * @brief   Handle "getsig" command
  int ret;
  if(paraNum != 2){
    return -1;
    return -1;
  ret = myVR.checkSignature(records[0], buf);
  printSeperator();
  if(ret == 0){
    Serial.println(F("Signature isn't set."));
  else if(ret > 0){
    Serial.print(F("Signature:"));
    printSignature(buf, ret);
  else{
    Serial.println(F("Get sig error or timeout."));
  printSeperator();
  return 0;
 * @brief   Handle "test" command
  printSeperator();
  Serial.println(F("TEST is not supported."));
  printSeperator();
  return 0;
  int ret;
  if(paraNum != 1){
    return -1;
  ret = myVR.checkSystemSettings(buf);
  if( ret > 0){
    printSeperator();
    printSystemSettings(buf, ret);
    printSeperator();
  else{
    printSeperator();
    Serial.println(F("Check system settings error or timeout"));
    printSeperator();
  return 0;
 * @brief   Print signature, if the character is invisible,
 * print hexible value instead.
 * @param   buf     --> command length
 * len     --> number of parameters
  int i;
    if(buf[i]>0x19 && buf[i]<0x7F){
      Serial.write(buf[i]);
    else{
      Serial.print(F("["));
      Serial.print(buf[i], HEX);
      Serial.print(F("]"));
 * @param   buf  -->  VR module return value when voice is recognized.
 * buf[0]  -->  Group mode(FF: None Group, 0x8n: User, 0x0n:System
 * buf[1]  -->  number of record which is recognized.
 * buf[2]  -->  Recognizer index(position) value of the recognized record.
 * buf[3]  -->  Signature length
 * buf[4]~buf[n] --> Signature
  Serial.println(F("VR Index\tGroup\tRecordNum\tSignature"));
  Serial.print(buf[2], DEC);
  Serial.print(F("\t\t"));
  if(buf[0] == 0xFF){
    Serial.print(F("NONE"));
  else if(buf[0]&0x80){
    Serial.print(F("UG "));
    Serial.print(buf[0]&(~0x80), DEC);
  else{
    Serial.print(F("SG "));
    Serial.print(buf[0], DEC);
  Serial.print(F("\t"));
  Serial.print(buf[1], DEC);
  if(buf[3]>0){
    printSignature(buf+4, buf[3]);
  else{
  Serial.println(F("\r\n"));
 * @brief   Print seperator. Print 80 '-'.
  for(int i=0; i<80; i++){
    Serial.write('-');
 * @brief   Print recoginizer status.
 * buf[0]     -->  Number of valid voice records in recognizer
 * buf[i+1]   -->  Record number.(0xFF: Not loaded(Nongroup mode), or not set (Group mode)) (i= 0, 1, ... 6)
 * buf[8]     -->  Number of all voice records in recognizer
 * buf[9]     -->  Valid records position indicate.
 * buf[10]    -->  Group mode indicate(FF: None Group, 0x8n: User, 0x0n:System)
  Serial.print(F("All voice records in recognizer: "));
  Serial.println(buf[8], DEC);
  Serial.print(F("Valid voice records in recognizer: "));
  Serial.println(buf[0], DEC);
  if(buf[10] == 0xFF){
    Serial.println(F("VR is not in group mode."));
  else if(buf[10]&0x80){
    Serial.print(F("VR is in user group mode:"));
    Serial.println(buf[10]&0x7F, DEC);
  else{
    Serial.print(F("VR is in system group mode:"));
    Serial.println(buf[10], DEC);
  Serial.println(F("VR Index\tRecord\t\tComment"));
  for(int i=0; i<7; i++){
    Serial.print(i, DEC);
    if(buf[i+1] == 0xFF){
        Serial.print(F("Unloaded\tNONE"));
      else{
        Serial.print(F("Not Set\t\tNONE"));
    else{
      Serial.print(buf[i+1], DEC);
      if(buf[9]&(1<<i)){
        Serial.print(F("Valid"));
      else{
        Serial.print(F("Untrained"));
 * @brief   Print record train status.
 * @param   buf  -->  Check record command return value
 * buf[0]     -->  Number of checked records
 * buf[2i+1]  -->  Record number.
 * buf[2i+2]  -->  Record train status. (00: untrained, 01: trained, FF: record value out of range)
 * (i = 0 ~ buf[0]-1 )
 * num  -->  Number of trained records
  Serial.print(F("Check "));
  Serial.println(F(" records."));
  Serial.print(num, DEC);
  if(num>1){
    Serial.println(F(" records trained."));
  else{
    Serial.println(F(" record trained."));
  for(int i=0; i<buf[0]*2; i += 2){
    Serial.print(F("\t-->\t"));
    switch(buf[i+2]){
    case 0x01:
      Serial.print(F("Trained"));
    case 0x00:
    case 0xFF:
      Serial.print(F("Record value out of range"));
    default:
      Serial.print(F("Unknown Stauts"));
  Serial.print(F("Check 255"));
  if(num>1){
  else{
  myVR.writehex(buf, 255);
  for(int i=0; i<255; i++){
    if(buf[i] == 0xF0){
      continue;
    switch(buf[i]){
    case 0x01:
    case 0x00:
    case 0xFF:
    default:
 * @brief   Print check user group result.
 * buf[8i]    -->  group number.
 * buf[8i+1]  -->  group position 0 status.
 * buf[8i+2]  -->  group position 1 status.
 * buf[8i+6]  -->  group position 5 status.
 * buf[8i+7]  -->  group position 6 status.
 * (i = 0 ~ len)
 * len  -->  number of checked groups
  int i, j;
  Serial.println(F("Check User Group:"));
    Serial.print(F("Group:"));
    Serial.println(buf[8*i]);
    for(j=0; j<7; j++){
      if(buf[8*i+1+j] == 0xFF){
        Serial.print(F("NONE\t"));
      else{
        Serial.print(buf[8*i+1+j], DEC);
 * @brief   Print "load" command return value.
 * @param   buf  -->  "load" command return value
 * buf[0]    -->  number of records which are load successfully.
 * buf[2i+1]  -->  record number
 * buf[2i+2]  -->  record load status.
 * 00 --> Loaded
 * FC --> Record already in recognizer
 * FD --> Recognizer full
 * FE --> Record untrained
 * FF --> Value out of range"
 * (i = 0 ~ (len-1)/2 )
 * len  -->  length of buf
  if(len == 0){
    Serial.println(F("Load Successfully."));
    return;
  else{
    Serial.print(F("Load success: "));
  for(int i=0; i<len-1; i += 2){
    Serial.print(F("Record "));
    switch(buf[i+2]){
    case 0:
      Serial.println(F("Loaded"));
    case 0xFC:
      Serial.println(F("Record already in recognizer"));
    case 0xFD:
      Serial.println(F("Recognizer full"));
    case 0xFE:
      Serial.println(F("Record untrained"));
    case 0xFF:
      Serial.println(F("Value out of range"));
    default:
      Serial.println(F("Unknown status"));
 * @brief   Print "train" command return value.
 * @param   buf  -->  "train" command return value
 * buf[0]    -->  number of records which are trained successfully.
 * buf[2i+2]  -->  record train status.
 * 00 --> Trained
 * FE --> Train Time Out
 * (i = 0 ~ len-1 )
  if(len == 0){
    Serial.println(F("Train Finish."));
    return;
  else{
    Serial.print(F("Train success: "));
    switch(buf[i+2]){
    case 0:
      Serial.println(F("Trained"));
    case 0xFE:
      Serial.println(F("Train Time Out"));
    case 0xFF:
    default:
      Serial.print(F("Unknown status "));
      Serial.println(buf[i+2], HEX);
 * @brief   Print "sigtrain" command return value.
 * @param   buf  -->  "sigtrain" command return value
 * buf[1]  -->  record number
 * buf[2]  -->  record train status.
 * 00 --> Trained
 * F0 --> Trained, signature truncate
 * buf[3] ~ buf[len-1] --> Signature.
  if(len == 0){
    Serial.println(F("Train With Signature Finish."));
    return;
  else{
    Serial.print(F("Success: "));
  switch(buf[2]){
  case 0:
  case 0xF0:
    Serial.println(F("Trained, signature truncate"));
  case 0xFE:
  case 0xFF:
  default:
    Serial.println(buf[2], HEX);
  Serial.print(F("SIG: "));
  Serial.write(buf+3, len-3);
 * @brief   Print "settings" command return value.
 * @param   buf  -->  "settings" command return value
 * 00 --> Trained
const unsigned int io_pw_tab[16]={
  10,  15,  20,  25,  30,  35,  40,  45,
  50,  75,  100, 200, 300, 400, 500, 1000
  switch(buf[0]){
  case 0:
  case 3:
    Serial.println(F("Baud rate: 9600"));
  case 1:
    Serial.println(F("Baud rate: 2400"));
  case 2:
    Serial.println(F("Baud rate: 4800"));
  case 4:
    Serial.println(F("Baud rate: 19200"));
  case 5:
    Serial.println(F("Baud rate: 38400"));
  default:
    Serial.println(F("Baud rate: UNKONOWN"));
  switch(buf[1]){
  case 0:
  case 0xFF:
    Serial.println(F("Outpu IO Mode: Pulse"));
  case 1:
    Serial.println(F("Outpu IO Mode: Toggle"));
  case 2:
    Serial.println(F("Outpu IO Mode: Clear(When recognized) "));
  case 3:
    Serial.println(F("Outpu IO Mode: Set(When recognized)"));
  default:
    Serial.println(F("Output IO Mode: UNKONOWN"));
  if(buf[2] > 15){
    Serial.println(F("Pulse width: UNKONOWN"));
  else{
    Serial.print(F("Pulse Width: "));
    Serial.print(io_pw_tab[buf[2]], DEC);
    Serial.println(F("ms"));
  if(buf[3] == 0 || buf[3] == 0xFF){
    Serial.println(F("Auto Load: disable"));
  else{
    Serial.println(F("Auto Load: enable"));
  switch(buf[4]){
  case 0:
  case 0xFF:
    Serial.println(F("Group control by external IO: disabled"));
  case 1:
    Serial.println(F("Group control by external IO: system group selected"));
  case 2:
    Serial.println(F("Group control by external IO: user group selected"));
  default:
    Serial.println(F("Group control by external IO: UNKNOWN STATUS"));
  Serial.println(F("COMMAND        FORMAT                        EXAMPLE                    Comment"));
  printSeperator();
  //  Serial.println(F("--------------------------------------------------------------------------------------------------------------"));
  Serial.println(F("train          train (r0) (r1)...            train 0 2 45               Train records"));
  Serial.println(F("load           load (r0) (r1) ...            load 0 51 2 3              Load records"));
  Serial.println(F("clear          clear                         clear                      remove all records in  Recognizer"));
  Serial.println(F("record         record / record (r0) (r1)...  record / record 0 79       Check record train status"));
  Serial.println(F("vr             vr                            vr                         Check recognizer status"));
  Serial.println(F("getsig         getsig (r)                    getsig 0                   Get signature of record (r)"));
  Serial.println(F("sigtrain       sigtrain (r) (sig)            sigtrain 0 ZERO            Train one record(r) with signature(sig)"));
  Serial.println(F("settings       settings                      settings                   Check current system settings"));
  Serial.println(F("help           help                          help                       print this message"));
basically the problem is when i plug the rxd and txd into pins 2 and 3 (which is the same as the regular arduino which when I tested that it worked on the regular arduino). When I run the code and type "train 0" to train a key word, it waits for about 5 seconds then go to 'train timeout'. So I don't know if its because I have it hooked up wrong or if the module just doesn't work together with the MEGA
You were requested to post the schematics... is Rx connected to Rx, Tx to Tx? If they are, it's wrong,
Why are you using SoftwareSerial with a board that has 3 extra hardware serial ports?
And perhaps this text from the SoftwareSerial library reference page is germane to your problem:
SoftwareSerial library has the following known limitations:
  • It cannot transmit and receive data at the same time.
  • If using multiple software serial ports, only one can receive data at a time.
  • Not all pins on the Mega and Mega 2560 boards support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69). Not all pins on the Leonardo and Micro boards support change interrupts, so only the following can be used for RX: 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
Yes they are connected to the correct ones. That was the first thing I checked as it should be everyones first thing to check.
So, I tried to change TXD to pin 11 and RXD to pin 10 and changed this line to "VR myVR(10,11); ", and I still get the same error, "Usage:
train 0
Train Timeout.
aka Train 0 then Train Timeout.
I'm new to using an arduino as I just bought it and am still trying to figure things out so this is all new information. Which ports are Serial1 or Serial2 or Serial3?
How much code would I have to change in order to get this program function?
I've done the research for that part, I am going to put Rx in 19 and Tx in 18 for Serial1. So now I just need to update the code for these changes, which is the main problem.
clarifying question, i wanna keep using the serial monitor for right now, I assume I don't change every 'serial' lines to serial1. Is that correct?
In a nutshell, you change the library to use HardwareSerial rather than SoftwareSerial. It's probably no more than 5 minutes work.
The VR class is derived from SoftwareSerial. Get rid of that derivation.
Add a HardwareSerial class variable, call it serial.
Change the VR constructor to take a pointer to a HardwareSerial and assign the pointer to the serial class variable, like so:
VR::VR(HardwareSerial *_serial)
	instance = this;
	serial = _serial;
which you would use thusly:
VR myvr(&Serial1);
Remove the SoftwareSerial's begin call from the VR constructor. Add a begin method to the VR class that looks something like this:
void VR::begin(long _speed) {
   serial->begin(_speed);
Anywhere in the library code where there's a call to available, read or write, change them to serial->available, serial->read or serial->write. That will likely be all there is to it.
You could extend the library to work with both SoftwareSerial and HardwareSerial but for your use case, why bother? If it really bothers you, make the changes in a copy of the library and call it HardwareSerialVR.
"The VR class is derived from SoftwareSerial. Get rid of that derivation."
I'm not sure what this means if i'm being honest, what exactly should I do.
I don’t know what that means can you provide how?
if u go here Speak Recognition, Voice Recognition Module V3 - ELECHOUSE and scroll down till you find Library for Arduino. That's the library, this code is meant for just a normal Arduino and not the MEGA. You guys have lost me and now I don't know what to change if you could offer guidance that would be helpful. Thanks
Can you link to where you found that?
Succinctly put. :slight_smile:
That makes sense. Do whatever setup needs to be done to the Stream object outside the library. And it would still only be a 5 minute fix.
I don't know how to do most of that, I was mostly done with the original changes.
I looked through all the issues and the only one that related to mine wasn't answered.
would you be able to fix it?
