water valve arduino
Hello
I am working on a project that regulates the water supply for plants. I work with the soil moisture sensor to measure the humidity. I'm looking for another water valve that can water very precisely, to a centiliter accurate. it is for exotic plants that need little water. I'm a novice with arduino, this is for my final project at school.
Someone who can help me?
Thank you in advance!
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
jarne1605:
Hello
Water valves cannot measure the water that is released. Look for peristaltic pump that you can control. The amount of water is controlled by the number of turns of the pump motor.
Paul
Hello Paul
First of all, thanks for your reply.
Now that you're saying this, it makes a lot of sense. my reservoir is at the bottom of the flower pot and due to the pressure of the weight the water can flow out. it will indeed flow harder in the beginning than when the reservoir becomes army.
I will search for a peristaltic pump. if you already have experience with this, you may leave it awhile.
thanks!
