Waveshare e-paper displays with SPI
I have the same board and problem. Could the display be salvaged by disconnecting it from the board and reconnecting it to a DESPI-C02? Or do I need to buy a new (supported) display?
@vanilla_chief, Hi, welcome to the forum. Please read How to get the best out of this forum.
Please always post as much information as possible. It gets frustrating to have to ask back!
What processor did you use, link to the display (to make sure it is a board with booster circuit, level converter, b/w or 3-color etc.).
What constructor did you use, do parameters match your wiring?
What inking do you see on the flex connector (to compare to the panels I have).
What diagnostic information is reported in Serial Monitor (please put it into a code window), by which example?
Jean-Marc
Yes, it could be worth to try with the DESPI-C02. But if the panel works, you should be able to get it to work with the Waveshare board. You may need to use init() with shortened reset, and maybe use a different pin for CS. I would expect the panel to be the GDEM029T94.
I am sorry, here is the missing info:
The display I am using:
The Amazon link I ordered it from.
The inking on the flex connector:
It is connected to this ESP32:
The code with the constructor(?) line for GxEPD2_DRIVER_CLASS GxEPD2_290 // GDEH029A1 128x296 uncommented
// Display Library example for SPI e-paper panels from Dalian Good Display and boards from Waveshare.
// Requires HW SPI and Adafruit_GFX. Caution: the e-paper panels require 3.3V supply AND data lines!
// Display Library based on Demo Example from Good Display: http://www.e-paper-display.com/download_list/downloadcategoryid=34&isMode=false.html
// Author: Jean-Marc Zingg
// Version: see library.properties
// Library: https://github.com/ZinggJM/GxEPD2
// Supporting Arduino Forum Topics:
// Waveshare e-paper displays with SPI: http://forum.arduino.cc/index.php?topic=487007.0
// Good Display ePaper for Arduino: https://forum.arduino.cc/index.php?topic=436411.0
// select the display class (only one), matching the kind of display panel
#define GxEPD2_DISPLAY_CLASS GxEPD2_BW
//#define GxEPD2_DISPLAY_CLASS GxEPD2_3C
//#define GxEPD2_DISPLAY_CLASS GxEPD2_7C
// select the display driver class (only one) for your  panel
//#define GxEPD2_DRIVER_CLASS GxEPD2_154     // GDEP015OC1  200x200, no longer available
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_D67 // GDEH0154D67 200x200
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_T8  // GDEW0154T8  152x152
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_M09 // GDEW0154M09 200x200
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_M10 // GDEW0154M10 152x152
//#define GxEPD2_DRIVER_CLASS GxEPD2_213     // GDE0213B1   128x250, phased out
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_B72 // GDEH0213B72 128x250
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_B73 // GDEH0213B73 128x250
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_flex // GDEW0213I5F 128x250
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_M21 // GDEW0213M21 128x250
#define GxEPD2_DRIVER_CLASS GxEPD2_290     // GDEH029A1   128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T5  // GDEW029T5   128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T94 // GDEM029T94  128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_M06 // GDEW029M06  128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_260     // GDEW026T0   152x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_260_M01 // GDEW026M01  152x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_270     // GDEW027W3   176x264
//#define GxEPD2_DRIVER_CLASS GxEPD2_371     // GDEW0371W7  240x416
//#define GxEPD2_DRIVER_CLASS GxEPD2_420     // GDEW042T2   400x300
//#define GxEPD2_DRIVER_CLASS GxEPD2_420_M01 // GDEW042M01  400x300
//#define GxEPD2_DRIVER_CLASS GxEPD2_583     // GDEW0583T7  600x448
//#define GxEPD2_DRIVER_CLASS GxEPD2_583_T8  // GDEW0583T8  648x480
//#define GxEPD2_DRIVER_CLASS GxEPD2_750     // GDEW075T8   640x384
//#define GxEPD2_DRIVER_CLASS GxEPD2_750_T7  // GDEW075T7   800x480
// 3-color e-papers
//#define GxEPD2_DRIVER_CLASS GxEPD2_154c     // GDEW0154Z04 200x200, no longer available
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_Z90c // GDEH0154Z90 200x200
//#define GxEPD2_DRIVER_CLASS GxEPD2_213c     // GDEW0213Z16 104x212
//#define GxEPD2_DRIVER_CLASS GxEPD2_290c     // GDEW029Z10  128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_C90c // GDEM029C90  128x296
//#define GxEPD2_DRIVER_CLASS GxEPD2_270c     // GDEW027C44  176x264
//#define GxEPD2_DRIVER_CLASS GxEPD2_420c     // GDEW042Z15  400x300
//#define GxEPD2_DRIVER_CLASS GxEPD2_583c     // GDEW0583Z21 600x448
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c     // GDEW075Z09  640x384
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c_Z08 // GDEW075Z08  800x480
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c_Z90 // GDEH075Z90  880x528
//#define GxEPD2_DRIVER_CLASS GxEPD2_1248     // GDEW1248T3  1303x984
// 7-color e-paper
//#define GxEPD2_DRIVER_CLASS GxEPD2_565c // Waveshare 5.65" 7-color (3C graphics)
// grey levels parallel IF e-papers on Waveshare e-Paper IT8951 Driver HAT
//#define GxEPD2_DRIVER_CLASS GxEPD2_it60           // ED060SCT 800x600
//#define GxEPD2_DRIVER_CLASS GxEPD2_it60_1448x1072 // ED060KC1 1448x1072
// SS is usually used for CS. define here for easy change
#ifndef EPD_CS
#define EPD_CS SS
#endif
#if defined(GxEPD2_DISPLAY_CLASS) && defined(GxEPD2_DRIVER_CLASS)
// somehow there should be an easier way to do this
#define GxEPD2_BW_IS_GxEPD2_BW true
#define GxEPD2_3C_IS_GxEPD2_3C true
#define GxEPD2_7C_IS_GxEPD2_7C true
#define GxEPD2_1248_IS_GxEPD2_1248 true
#define IS_GxEPD(c, x) (c##x)
#define IS_GxEPD2_BW(x) IS_GxEPD(GxEPD2_BW_IS_, x)
#define IS_GxEPD2_3C(x) IS_GxEPD(GxEPD2_3C_IS_, x)
#define IS_GxEPD2_7C(x) IS_GxEPD(GxEPD2_7C_IS_, x)
#define IS_GxEPD2_1248(x) IS_GxEPD(GxEPD2_1248_IS_, x)
#if defined (ESP8266)
#define MAX_DISPLAY_BUFFER_SIZE (81920ul-34000ul-5000ul) // ~34000 base use, change 5000 to your application use
#if IS_GxEPD2_BW(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8) ? EPD::HEIGHT : MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8))
#elif IS_GxEPD2_3C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8))
#elif IS_GxEPD2_7C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2))
#endif
// adapt the constructor parameters to your wiring
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=D8*/ EPD_CS, /*DC=D3*/ 0, /*RST=D4*/ 2, /*BUSY=D2*/ 4));
// mapping of Waveshare e-Paper ESP8266 Driver Board, new version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=2*/ 2, /*BUSY=5*/ 5));
// mapping of Waveshare e-Paper ESP8266 Driver Board, old version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=5*/ 5, /*BUSY=16*/ 16));
#endif
#if defined(ESP32)
#define MAX_DISPLAY_BUFFER_SIZE 65536ul // e.g.
#endif
#if !IS_GxEPD2_1248(GxEPD2_DRIVER_CLASS)
#if defined(ARDUINO_LOLIN_D32_PRO)
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 0, /*RST=*/ 2, /*BUSY=*/ 15));
#elif defined(ARDUINO_ESP32_DEV) // e.g. TTGO T8 ESP32-WROVER
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 2, /*RST=*/ 0, /*BUSY=*/ 4));
#else
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4));
#endif
#else // GxEPD2_1248
// Waveshare 12.48 b/w SPI display board and frame or Good Display 12.48 b/w panel GDEW1248T3
// general constructor for use with all parameters, e.g. for Waveshare ESP32 driver board mounted on connection board
GxEPD2_BW < GxEPD2_1248, GxEPD2_1248::HEIGHT / 4 > display(GxEPD2_1248(/*sck=*/ 13, /*miso=*/ 12, /*mosi=*/ 14,
    /*cs_m1=*/ 23, /*cs_s1=*/ 22, /*cs_m2=*/ 16, /*cs_s2=*/ 19,
    /*dc1=*/ 25, /*dc2=*/ 17, /*rst1=*/ 33, /*rst2=*/ 5,
    /*busy_m1=*/ 32, /*busy_s1=*/ 26, /*busy_m2=*/ 18, /*busy_s2=*/ 4));
#endif
#endif
// can't use package "STMF1 Boards (STM32Duino.com)" (Roger Clark) anymore with Adafruit_GFX, use "STM32 Boards (selected from submenu)" (STMicroelectronics)
#if defined(ARDUINO_ARCH_STM32)
#define MAX_DISPLAY_BUFFER_SIZE 15000ul // ~15k is a good compromise
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ EPD_CS, /*DC=*/ 3, /*RST=*/ 2, /*BUSY=*/ 1));
#endif
#if defined(__AVR)
#if defined (ARDUINO_AVR_MEGA2560) // Note: SS is on 53 on MEGA
#define MAX_DISPLAY_BUFFER_SIZE 5000 // e.g. full height for 200x200
#else // Note: SS is on 10 on UNO, NANO
#define MAX_DISPLAY_BUFFER_SIZE 800 //
#endif
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#endif
#if defined(ARDUINO_ARCH_SAM)
#define MAX_DISPLAY_BUFFER_SIZE 32768ul // e.g., up to 96k
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=77*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#endif
#if defined(ARDUINO_ARCH_SAMD)
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 4, /*DC=*/ 7, /*RST=*/ 6, /*BUSY=*/ 5));
#endif
#endif
I used this wiring example:
// mapping suggestion for ESP32, e.g. LOLIN32, see .../variants/.../pins_arduino.h for your board
// NOTE: there are variants with different pins for SPI ! CHECK SPI PINS OF YOUR BOARD
// BUSY -> 4, RST -> 16, DC -> 17, CS -> SS(5), CLK -> SCK(18), DIN -> MOSI(23), GND -> GND, 3.3V -> 3.3V
This is the example code I am using:
// see GxEPD2_wiring_examples.h for wiring suggestions and examples
// base class GxEPD2_GFX can be used to pass references or pointers to the display instance as parameter, uses ~1.2k more code
// enable or disable GxEPD2_GFX base class
#define ENABLE_GxEPD2_GFX 0
// uncomment next line to use class GFX of library GFX_Root instead of Adafruit_GFX
//#include <GFX.h>
// Note: if you use this with ENABLE_GxEPD2_GFX 1:
//       uncomment it in GxEPD2_GFX.h too, or add #include <GFX.h> before any #include <GxEPD2_GFX.h>
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <GxEPD2_7C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// select the display constructor line in one of the following files (old style):
#include "GxEPD2_display_selection.h"
#include "GxEPD2_display_selection_added.h"
//#include "GxEPD2_display_selection_more.h" // private
// or select the display class and display driver class in the following file (new style):
#include "GxEPD2_display_selection_new_style.h"
#if !defined(__AVR) && !defined(_BOARD_GENERIC_STM32F103C_H_)
// note 16.11.2019: the compiler may exclude code based on constant if statements (display.epd2.panel == constant),
//                  therefore bitmaps may get optimized out by the linker
// comment out unused bitmaps to reduce code space used
#include "bitmaps/Bitmaps152x152.h" // 1.54" b/w
#include "bitmaps/Bitmaps200x200.h" // 1.54" b/w
#include "bitmaps/Bitmaps104x212.h" // 2.13" b/w flexible GDEW0213I5F
#include "bitmaps/Bitmaps128x250.h" // 2.13" b/w
#include "bitmaps/Bitmaps128x296.h" // 2.9"  b/w
#include "bitmaps/Bitmaps152x296.h" // 2.6"  b/w
#include "bitmaps/Bitmaps176x264.h" // 2.7"  b/w
#include "bitmaps/Bitmaps240x416.h" // 3.71"  b/w
#include "bitmaps/Bitmaps400x300.h" // 4.2"  b/w
#include "bitmaps/Bitmaps648x480.h" // 5.38"  b/w
#include "bitmaps/Bitmaps640x384.h" // 7.5"  b/w
#include "bitmaps/Bitmaps800x480.h" // 7.5"  b/w
// 3-color
#include "bitmaps/Bitmaps3c200x200.h" // 1.54" b/w/r
#include "bitmaps/Bitmaps3c104x212.h" // 2.13" b/w/r
#include "bitmaps/Bitmaps3c128x296.h" // 2.9"  b/w/r
#include "bitmaps/Bitmaps3c176x264.h" // 2.7"  b/w/r
#include "bitmaps/Bitmaps3c400x300.h" // 4.2"  b/w/r
#if defined(ESP8266) || defined(ESP32)
#include "bitmaps/Bitmaps3c800x480.h" // 7.5"  b/w/r
#include "bitmaps/Bitmaps3c880x528.h" // 7.5"  b/w/r
#include "bitmaps/WS_Bitmaps800x600.h" // 6.0"  grey
#include "bitmaps/WS_Bitmaps7c192x143.h" // 5.65" 7-color
#endif
#if defined(ESP32)
#include "bitmaps/Bitmaps1304x984.h" // 12.48" b/w
#endif
#else
// select only one to fit in code space
//#include "bitmaps/Bitmaps104x212.h" // 2.13" b/w flexible GDEW0213I5F
//#include "bitmaps/Bitmaps128x250.h" // 2.13" b/w
//#include "bitmaps/Bitmaps128x296.h" // 2.9"  b/w
//#include "bitmaps/Bitmaps176x264.h" // 2.7"  b/w
////#include "bitmaps/Bitmaps400x300.h" // 4.2"  b/w // not enough code space
////#include "bitmaps/Bitmaps640x384.h" // 7.5"  b/w // not enough code space
// 3-color
//#include "bitmaps/Bitmaps3c200x200.h" // 1.54" b/w/r
//#include "bitmaps/Bitmaps3c104x212.h" // 2.13" b/w/r
//#include "bitmaps/Bitmaps3c128x296.h" // 2.9"  b/w/r
//#include "bitmaps/Bitmaps3c176x264.h" // 2.7"  b/w/r
////#include "bitmaps/Bitmaps3c400x300.h" // 4.2"  b/w/r // not enough code space
#endif
  Serial.println("setup");
  delay(100);
  display.init(115200, true, 2, false);
  // first update should be full refresh
  helloWorld();
  // partial refresh mode can be used to full screen,
  // effective if display panel hasFastPartialUpdate
  helloFullScreenPartialMode();
  helloArduino();
  helloEpaper();
  //helloValue(123.9, 1);
  //delay(1000);
  showFont("FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
  drawBitmaps();
#if !defined(__AVR) // takes too long!
  if (display.epd2.panel == GxEPD2::ACeP565)
    //draw7colorlines();
    //delay(2000);
    draw7colors();
    delay(4000);
#endif
  if (display.epd2.hasPartialUpdate)
    showPartialUpdate();
  } // else // on GDEW0154Z04 only full update available, doesn't look nice
  //drawCornerTest();
  //showBox(16, 16, 48, 32, false);
  //showBox(16, 56, 48, 32, true);
  display.powerOff();
  deepSleepTest();
#if defined(ESP32) && defined(_GxBitmaps1304x984_H_)
  drawBitmaps1304x984();
  display.powerOff();
#endif
  Serial.println("setup done");
// note for partial update window and setPartialWindow() method:
// partial update window size and position is on byte boundary in physical x direction
// the size is increased in setPartialWindow() if x or w are not multiple of 8 for even rotation, y or h for odd rotation
// see also comment in GxEPD2_BW.h, GxEPD2_3C.h or GxEPD2_GFX.h for method setPartialWindow()
const char HelloWorld[] = "Hello World!";
const char HelloArduino[] = "Hello Arduino!";
const char HelloEpaper[] = "Hello E-Paper!";
void helloWorld()
  //Serial.println("helloWorld");
  display.setRotation(1);
  display.setFont(&FreeMonoBold9pt7b);
  display.setTextColor(GxEPD_BLACK);
  int16_t tbx, tby; uint16_t tbw, tbh;
  display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
  // center bounding box by transposition of origin:
  uint16_t x = ((display.width() - tbw) / 2) - tbx;
  uint16_t y = ((display.height() - tbh) / 2) - tby;
  display.setFullWindow();
  display.firstPage();
  do
    display.fillScreen(GxEPD_WHITE);
    display.setCursor(x, y);
    display.print(HelloWorld);
  while (display.nextPage());
  //Serial.println("helloWorld done");
void helloWorldForDummies()
  const char text[] = "Hello World!";
  // most e-papers have width < height (portrait) as native orientation, especially the small ones
  // in GxEPD2 rotation 0 is used for native orientation (most TFT libraries use 0 fix for portrait orientation)
  // set rotation to 1 (rotate right 90 degrees) to have enough space on small displays (landscape)
  // select a suitable font in Adafruit_GFX
  // on e-papers black on white is more pleasant to read
  // Adafruit_GFX has a handy method getTextBounds() to determine the boundary box for a text for the actual font
  int16_t tbx, tby; uint16_t tbw, tbh; // boundary box window
  display.getTextBounds(text, 0, 0, &tbx, &tby, &tbw, &tbh); // it works for origin 0, 0, fortunately (negative tby!)
  // full window mode is the initial mode, set it anyway
  // here we use paged drawing, even if the processor has enough RAM for full buffer
  // so this can be used with any supported processor board.
  // the cost in code overhead and execution time penalty is marginal
  // tell the graphics class to use paged drawing mode
  do
    // this part of code is executed multiple times, as many as needed,
    // in case of full buffer it is executed once
    // IMPORTANT: each iteration needs to draw the same, to avoid strange effects
    // use a copy of values that might change, don't read e.g. from analog or pins in the loop!
    display.fillScreen(GxEPD_WHITE); // set the background to white (fill the buffer with value for white)
    display.setCursor(x, y); // set the postition to start printing text
    display.print(text); // print some text
    // end of part executed multiple times
  // tell the graphics class to transfer the buffer content (page) to the controller buffer
  // the graphics class will command the controller to refresh to the screen when the last page has been transferred
  // returns true if more pages need be drawn and transferred
  // returns false if the last page has been transferred and the screen refreshed for panels without fast partial update
  // returns false for panels with fast partial update when the controller buffer has been written once more, to make the differential buffers equal
  // (for full buffered with fast partial update the (full) buffer is just transferred again, and false returned)
void helloFullScreenPartialMode()
  //Serial.println("helloFullScreenPartialMode");
  const char fullscreen[] = "full screen update";
  const char fpm[] = "fast partial mode";
  const char spm[] = "slow partial mode";
  const char npm[] = "no partial mode";
  display.setPartialWindow(0, 0, display.width(), display.height());
  const char* updatemode;
  if (display.epd2.hasFastPartialUpdate)
    updatemode = fpm;
  else if (display.epd2.hasPartialUpdate)
    updatemode = spm;
    updatemode = npm;
  // do this outside of the loop
  // center update text
  display.getTextBounds(fullscreen, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t utx = ((display.width() - tbw) / 2) - tbx;
  uint16_t uty = ((display.height() / 4) - tbh / 2) - tby;
  // center update mode
  display.getTextBounds(updatemode, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t umx = ((display.width() - tbw) / 2) - tbx;
  uint16_t umy = ((display.height() * 3 / 4) - tbh / 2) - tby;
  // center HelloWorld
  uint16_t hwx = ((display.width() - tbw) / 2) - tbx;
  uint16_t hwy = ((display.height() - tbh) / 2) - tby;
  do
    display.setCursor(hwx, hwy);
    display.setCursor(utx, uty);
    display.print(fullscreen);
    display.setCursor(umx, umy);
    display.print(updatemode);
  //Serial.println("helloFullScreenPartialMode done");
void helloArduino()
  //Serial.println("helloArduino");
  display.setTextColor(display.epd2.hasColor ? GxEPD_RED : GxEPD_BLACK);
  // align with centered HelloWorld
  // height might be different
  display.getTextBounds(HelloArduino, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = ((display.height() / 4) - tbh / 2) - tby; // y is base line!
  // make the window big enough to cover (overwrite) descenders of previous text
  uint16_t wh = FreeMonoBold9pt7b.yAdvance;
  uint16_t wy = (display.height() / 4) - wh / 2;
  display.setPartialWindow(0, wy, display.width(), wh);
  do
    //display.drawRect(x, y - tbh, tbw, tbh, GxEPD_BLACK);
    display.print(HelloArduino);
  //Serial.println("helloArduino done");
void helloEpaper()
  //Serial.println("helloEpaper");
  display.getTextBounds(HelloEpaper, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = (display.height() * 3 / 4) + tbh / 2; // y is base line!
  uint16_t wy = (display.height() * 3 / 4) - wh / 2;
  do
    display.print(HelloEpaper);
  //Serial.println("helloEpaper done");
#include <StreamString.h>
#define PrintString StreamString
#else
class PrintString : public Print, public String
  public:
    size_t write(uint8_t data) override
      return concat(char(data));
#endif
void helloValue(double v, int digits)
  //Serial.println("helloValue");
  PrintString valueString;
  valueString.print(v, digits);
  display.getTextBounds(valueString, 0, 0, &tbx, &tby, &tbw, &tbh);
  // show what happens, if we use the bounding box for partial window
  uint16_t wx = (display.width() - tbw) / 2;
  uint16_t wy = (display.height() * 3 / 4) - tbh / 2;
  display.setPartialWindow(wx, wy, tbw, tbh);
  do
    display.print(valueString);
  delay(2000);
  // make the partial window big enough to cover the previous text
  uint16_t ww = tbw; // remember window width
  // adjust, because HelloEpaper was aligned, not centered (could calculate this to be precise)
  ww = max(ww, uint16_t(tbw + 12)); // 12 seems ok
  display.setPartialWindow(wx, wy, ww, wh);
  // alternately use the whole width for partial window
  //display.setPartialWindow(0, wy, display.width(), wh);
  do
  //Serial.println("helloValue done");
void deepSleepTest()
  //Serial.println("deepSleepTest");
  const char hibernating[] = "hibernating ...";
  const char wokeup[] = "woke up";
  const char from[] = "from deep sleep";
  const char again[] = "again";
  // center text
  display.getTextBounds(hibernating, 0, 0, &tbx, &tby, &tbw, &tbh);
  do
    display.print(hibernating);
  display.hibernate();
  delay(5000);
  display.getTextBounds(wokeup, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t wy = (display.height() / 3) + tbh / 2; // y is base line!
  display.getTextBounds(from, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t fx = (display.width() - tbw) / 2;
  uint16_t fy = (display.height() * 2 / 3) + tbh / 2; // y is base line!
  do
    display.setCursor(wx, wy);
    display.print(wokeup);
    display.setCursor(fx, fy);
    display.print(from);
  delay(5000);
  uint16_t hx = (display.width() - tbw) / 2;
  uint16_t hy = (display.height() / 3) + tbh / 2; // y is base line!
  display.getTextBounds(again, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t ax = (display.width() - tbw) / 2;
  uint16_t ay = (display.height() * 2 / 3) + tbh / 2; // y is base line!
  do
    display.setCursor(hx, hy);
    display.setCursor(ax, ay);
    display.print(again);
  //Serial.println("deepSleepTest done");
void showBox(uint16_t x, uint16_t y, uint16_t w, uint16_t h, bool partial)
  //Serial.println("showBox");
  if (partial)
    display.setPartialWindow(x, y, w, h);
  do
    display.fillRect(x, y, w, h, GxEPD_BLACK);
  //Serial.println("showBox done");
void drawCornerTest()
  for (uint16_t r = 0; r <= 4; r++)
    display.setRotation(r);
    do
      display.fillRect(0, 0, 8, 8, GxEPD_BLACK);
      display.fillRect(display.width() - 18, 0, 16, 16, GxEPD_BLACK);
      display.fillRect(display.width() - 25, display.height() - 25, 24, 24, GxEPD_BLACK);
      display.fillRect(0, display.height() - 33, 32, 32, GxEPD_BLACK);
      display.setCursor(display.width() / 2, display.height() / 2);
      display.print(display.getRotation());
    delay(2000);
void showFont(const char name[], const GFXfont* f)
  display.setRotation(0);
  do
    drawFont(name, f);
void drawFont(const char name[], const GFXfont* f)
  //display.setRotation(0);
  display.setFont(f);
  display.setCursor(0, 0);
  display.println();
  display.println(name);
  display.println(" !\"#$%&'()*+,-./");
  display.println("0123456789:;<=>?");
  display.println("@ABCDEFGHIJKLMNO");
  display.println("PQRSTUVWXYZ[\\]^_");
  if (display.epd2.hasColor)
    display.setTextColor(GxEPD_RED);
  display.println("`abcdefghijklmno");
  display.println("pqrstuvwxyz{|}~ ");
// showPartialUpdate() purposely uses values that are not multiples of 8 to test this
void showPartialUpdate()
  // some useful background
  helloWorld();
  // use asymmetric values for test
  uint16_t box_x = 10;
  uint16_t box_y = 15;
  uint16_t box_w = 70;
  uint16_t box_h = 20;
  uint16_t cursor_y = box_y + box_h - 6;
  float value = 13.95;
  uint16_t incr = display.epd2.hasFastPartialUpdate ? 1 : 3;
  // show where the update box is
  for (uint16_t r = 0; r < 4; r++)
    display.setPartialWindow(box_x, box_y, box_w, box_h);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_BLACK);
      //display.fillScreen(GxEPD_BLACK);
    delay(2000);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_WHITE);
  //return;
  // show updates in the update box
    for (uint16_t i = 1; i <= 10; i += incr)
      do
        display.setCursor(box_x, cursor_y);
        display.print(value * i, 2);
    do
void drawBitmaps()
#ifdef _GxBitmaps152x152_H_
  drawBitmaps152x152();
#endif
#ifdef _GxBitmaps104x212_H_
  drawBitmaps104x212();
#endif
#ifdef _GxBitmaps128x250_H_
  drawBitmaps128x250();
#endif
#ifdef _GxBitmaps128x296_H_
  drawBitmaps128x296();
#endif
#ifdef _GxBitmaps176x264_H_
  drawBitmaps176x264();
#endif
#ifdef _GxBitmaps400x300_H_
  drawBitmaps400x300();
#endif
#ifdef _GxBitmaps640x384_H_
  drawBitmaps640x384();
#endif
#ifdef _GxBitmaps648x480_H_
  drawBitmaps648x480();
#endif
#ifdef _GxBitmaps800x480_H_
  drawBitmaps800x480();
#endif
#ifdef _WS_Bitmaps800x600_H_
  drawBitmaps800x600();
#endif
#endif
  // 3-color
#ifdef _GxBitmaps3c104x212_H_
  drawBitmaps3c104x212();
#endif
#ifdef _GxBitmaps3c128x296_H_
  drawBitmaps3c128x296();
#endif
#ifdef _GxBitmaps152x296_H_
  drawBitmaps152x296();
#endif
#ifdef _GxBitmaps3c176x264_H_
  drawBitmaps3c176x264();
#endif
#ifdef _GxBitmaps240x416_H_
  drawBitmaps240x416();
#endif
#ifdef _GxBitmaps3c400x300_H_
  drawBitmaps3c400x300();
#endif
#ifdef _GxBitmaps3c800x480_H_
  drawBitmaps3c800x480();
#endif
#ifdef _GxBitmaps3c880x528_H_
  drawBitmaps3c880x528();
#endif
#if defined(_WS_Bitmaps7c192x143_H_)
  drawBitmaps7c192x143();
#endif
  if ((display.epd2.WIDTH >= 200) && (display.epd2.HEIGHT >= 200))
    // show these after the specific bitmaps
#ifdef _GxBitmaps200x200_H_
    drawBitmaps200x200();
#endif
    // 3-color
#ifdef _GxBitmaps3c200x200_H_
    drawBitmaps3c200x200();
#endif
void drawBitmaps152x152()
#if !defined(__AVR)
  const unsigned char* bitmaps[] =
    Bitmap152x152_1, Bitmap152x152_2, Bitmap152x152_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 152))
    for (uint16_t i = 0; i < sizeof(bitmaps) / sizeof(char*); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 152, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps200x200()
#if defined(ARDUINO_AVR_PRO)
    logo200x200
#elif defined(__AVR)
    logo200x200, //first200x200
#elif defined(_BOARD_GENERIC_STM32F103C_H_) || defined(STM32F1xx)
    logo200x200, first200x200, second200x200, third200x200, //fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
#else
    logo200x200, first200x200, second200x200, third200x200, fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
#endif
  if ((display.epd2.WIDTH == 200) && (display.epd2.HEIGHT == 200) && !display.epd2.hasColor)
    bool m = display.mirror(true);
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 200, 200, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
  //else
    bool mirror_y = (display.epd2.panel != GxEPD2::GDE0213B1);
    display.clearScreen(); // use default for white
    int16_t x = (int16_t(display.epd2.WIDTH) - 200) / 2;
    int16_t y = (int16_t(display.epd2.HEIGHT) - 200) / 2;
      display.drawImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
    int16_t x = -60;
    int16_t y = -60;
    for (uint16_t j = 0; j < 10; j++)
      display.writeScreenBuffer(); // use default for white
      display.writeImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      display.refresh(true);
        // for differential update: set previous buffer equal to current buffer in controller
        display.epd2.writeScreenBufferAgain(); // use default for white
        display.epd2.writeImageAgain(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
      x += display.epd2.WIDTH / 4;
      y += display.epd2.HEIGHT / 4;
      if ((x >= int16_t(display.epd2.WIDTH)) || (y >= int16_t(display.epd2.HEIGHT))) break;
    if (!display.epd2.hasFastPartialUpdate) break; // comment out for full show
  display.writeImage(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.writeImage(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  delay(2000);
#endif
void drawBitmaps104x212()
#if !defined(__AVR)
    WS_Bitmap104x212, Bitmap104x212_1, Bitmap104x212_2, Bitmap104x212_3
#else
#endif
  if ((display.epd2.WIDTH == 104) && (display.epd2.HEIGHT == 212) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 104, 212, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps128x250()
#if !defined(__AVR)
    Bitmap128x250_1, logo128x250, first128x250, second128x250, third128x250
#else
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 250) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 250, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps128x296()
#if !defined(__AVR)
    Bitmap128x296_1, logo128x296, first128x296, second128x296, third128x296
#else
    Bitmap128x296_1, logo128x296 //, first128x296, second128x296, third128x296
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 296, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps152x296()
#if !defined(__AVR)
    Bitmap152x296_1, Bitmap152x296_2, Bitmap152x296_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 296, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps176x264()
#if !defined(__AVR)
    Bitmap176x264_1, Bitmap176x264_2, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#else
    Bitmap176x264_1, Bitmap176x264_2 //, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#endif
  if ((display.epd2.WIDTH == 176) && (display.epd2.HEIGHT == 264) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 176, 264, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps240x416()
#if !defined(__AVR)
    Bitmap240x416_1, Bitmap240x416_2, Bitmap240x416_3
#else
    Bitmap240x460_1, Bitmap240x460_2, Bitmap240x460_3
#endif
  if ((display.epd2.WIDTH == 240) && (display.epd2.HEIGHT == 416) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 240, 416, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps400x300()
#if !defined(__AVR)
    Bitmap400x300_1, Bitmap400x300_2
#else
  const unsigned char* bitmaps[] = {}; // not enough code space
#endif
  if ((display.epd2.WIDTH == 400) && (display.epd2.HEIGHT == 300) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 400, 300, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps640x384()
#if !defined(__AVR)
    Bitmap640x384_1, Bitmap640x384_2
#else
#endif
  if ((display.epd2.WIDTH == 640) && (display.epd2.HEIGHT == 384))
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 640, 384, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps648x480()
#if !defined(__AVR)
    Bitmap648x480_1, Bitmap648x480_2, Bitmap648x480_3
#else
#endif
  if ((display.epd2.WIDTH == 648) && (display.epd2.HEIGHT == 480) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 648, 480, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps800x480()
#if !defined(__AVR)
    Bitmap800x480_1, Bitmap800x480_2, Bitmap800x480_3, Bitmap800x480_4
#else
#endif
  if ((display.epd2.WIDTH == 800) && (display.epd2.HEIGHT == 480))
      do
        display.drawBitmap(0, 0, bitmaps[i], 800, 480, GxEPD_BLACK);
      delay(2000);
    if (display.epd2.panel == GxEPD2::GDEW075T7)
      // avoid ghosting caused by OTP waveform
      display.refresh(false); // full update
#endif
void drawBitmaps800x600()
  if (display.epd2.panel == GxEPD2::ED060SCT)
    //    Serial.print("sizeof(WS_zoo_800x600) is "); Serial.println(sizeof(WS_zoo_800x600));
    display.drawNative(WS_zoo_800x600, 0, 0, 0, 800, 600, false, false, true);
    delay(2000);
    //    Serial.print("sizeof(WS_pic_1200x825) is "); Serial.println(sizeof(WS_pic_1200x825));
    //    display.drawNative((const uint8_t*)WS_pic_1200x825, 0, 0, 0, 1200, 825, false, false, true);
    //    delay(2000);
    //    Serial.print("sizeof(WS_acaa_1024x731) is "); Serial.println(sizeof(WS_acaa_1024x731));
    //    display.drawNative(WS_acaa_1024x731, 0, 0, 0, 1024, 731, false, false, true);
    //    delay(2000);
#endif
#endif
void drawBitmaps1304x984()
  if (display.epd2.panel == GxEPD2::GDEW1248T3)
    display.drawImage(Bitmap1304x984, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
#endif
struct bitmap_pair
  const unsigned char* black;
  const unsigned char* red;
void drawBitmaps3c200x200()
  bitmap_pair bitmap_pairs[] =
    //{Bitmap3c200x200_black, Bitmap3c200x200_red},
    {WS_Bitmap3c200x200_black, WS_Bitmap3c200x200_red}
  if (display.epd2.panel == GxEPD2::GDEW0154Z04)
    do
      // Bitmap3c200x200_black has 2 bits per pixel
      // taken from Adafruit_GFX.cpp, modified
      int16_t byteWidth = (display.epd2.WIDTH + 7) / 8; // Bitmap scanline pad = whole byte
      uint8_t byte = 0;
      for (int16_t j = 0; j < display.epd2.HEIGHT; j++)
        for (int16_t i = 0; i < display.epd2.WIDTH; i++)
          if (i & 3) byte <<= 2;
#if defined(__AVR) || defined(ESP8266) || defined(ESP32)
            byte = pgm_read_byte(&Bitmap3c200x200_black[j * byteWidth * 2 + i / 4]);
#else
            byte = Bitmap3c200x200_black[j * byteWidth * 2 + i / 4];
#endif
          if (!(byte & 0x80))
            display.drawPixel(i, j, GxEPD_BLACK);
      display.drawInvertedBitmap(0, 0, Bitmap3c200x200_red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
    delay(2000);
    for (uint16_t i = 0; i < sizeof(bitmap_pairs) / sizeof(bitmap_pair); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
      display.drawImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
      delay(2000);
      int16_t x = -60;
      int16_t y = -60;
        display.writeImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
        display.refresh();
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, 0, 0, 200, 200, false, false, true);
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, int16_t(display.epd2.WIDTH) - 200, int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, false, true);
    display.refresh();
    delay(2000);
#endif
void drawBitmaps3c104x212()
#if !defined(__AVR)
    {Bitmap3c104x212_1_black, Bitmap3c104x212_1_red},
    {Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
    {WS_Bitmap3c104x212_black, WS_Bitmap3c104x212_red}
#else
    //{Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
#endif
  if (display.epd2.panel == GxEPD2::GDEW0213Z16)
      do
        if (bitmap_pairs[i].red == WS_Bitmap3c104x212_red)
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c128x296()
#if !defined(__AVR)
    {Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    {Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
    {WS_Bitmap3c128x296_black, WS_Bitmap3c128x296_red}
#else
    //{Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    //{Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 128, 296, GxEPD_BLACK);
        if (bitmap_pairs[i].red == WS_Bitmap3c128x296_red)
          display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c176x264()
    {Bitmap3c176x264_black, Bitmap3c176x264_red}
  if (display.epd2.panel == GxEPD2::GDEW027C44)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps3c400x300()
#if !defined(__AVR)
    {Bitmap3c400x300_1_black, Bitmap3c400x300_1_red},
    {Bitmap3c400x300_2_black, Bitmap3c400x300_2_red},
    {WS_Bitmap3c400x300_black, WS_Bitmap3c400x300_red}
#else
  bitmap_pair bitmap_pairs[] = {}; // not enough code space
#endif
  if (display.epd2.panel == GxEPD2::GDEW042Z15)
      do
      delay(2000);
#endif
void drawBitmaps3c800x480()
#if !defined(__AVR)
    {Bitmap3c800x480_1_black, Bitmap3c800x480_1_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEW075Z08)
      do
      delay(2000);
#endif
void drawBitmaps3c880x528()
#if !defined(__AVR)
    {Bitmap3c880x528_black, Bitmap3c880x528_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEH075Z90)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 880, 528, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 880, 528, GxEPD_RED);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps7c192x143()
    display.drawNative(WS_Bitmap7c192x143, 0, (display.epd2.WIDTH - 192) / 2, (display.epd2.HEIGHT - 143) / 2, 192, 143, false, false, true);
    delay(5000);
#endif
void draw7colors()
  uint16_t h = display.height() / 7;
  do
    display.fillRect(0, 0, display.width(), h, GxEPD_BLACK);
    display.fillRect(0, h, display.width(), h, GxEPD_WHITE);
    display.fillRect(0, 2 * h, display.width(), h, GxEPD_GREEN);
    display.fillRect(0, 3 * h, display.width(), h, GxEPD_BLUE);
    display.fillRect(0, 4 * h, display.width(), h, GxEPD_RED);
    display.fillRect(0, 5 * h, display.width(), h, GxEPD_YELLOW);
    display.fillRect(0, 6 * h, display.width(), h, GxEPD_ORANGE);
void draw7colorlines()
  uint16_t h = 2;
  do
    uint16_t y = 0;
    do
      display.fillRect(0, y, display.width(), h, GxEPD_BLACK); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_WHITE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_GREEN); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_BLUE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_RED); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_YELLOW); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_ORANGE); y += h;
    while ((y + 12 * h) < display.height());
    //display.drawPixel(0, y, GxEPD_BLACK); display.drawPixel(10, y, GxEPD_GREEN);
    //display.drawPixel(20, y, GxEPD_BLUE); display.drawPixel(30, y, GxEPD_RED);
    //display.drawPixel(40, y, GxEPD_YELLOW); display.drawPixel(50, y, GxEPD_ORANGE);
    display.fillRect(0, y, 2, 2, GxEPD_BLACK); display.fillRect(10, y, 2, 2, GxEPD_GREEN);
    display.fillRect(20, y, 2, 2, GxEPD_BLUE); display.fillRect(30, y, 2, 2, GxEPD_RED);
    display.fillRect(40, y, 2, 2, GxEPD_YELLOW); display.fillRect(50, y, 2, 2, GxEPD_ORANGE);
The only thing I changed here was display.init(115200, true, 2, false);
The output from the serial monitor looks like this:
⸮⸮⸮⸮⸮⸮ ⸮z,o⸮⸮ 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
setup
⸮_PowerOn : 91001
_Update_Full : 91001
_Update_Part : 1
_PowerOff : 233001
_PowerOn : 91001
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_Update_Part : 1
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOn : 91001
_PowerOff : 233001
_PowerOff : 233001
Busy Timeout!
_PowerOff : 10001015
setup done
@vanilla_chief
Try uncommenting this line:
nice, it worked! Thank you!!!
has been falsified by @vanilla_chief, thanks!
Out of curiosity: How can I identify which 2.9inch constructor variant is needed for which board?
I contacted Good-Display and the GDEW0295TD has a 'fast full refresh' mode where it refreshes the full display in 0.82s. Although, this is similar to a partial update in the sense that there needs to be a standard full refresh after 5 partial updates.
The IC for GDEW0295T is no longer available so the GDEW0295TD will be replacing it.
If you are clever, you just try all candidates, same size and same resolution, and select the one that produces correct or best result.
If you buy a panel from Good Display you know what you ordered, and most likely it has a sticker on the backside.
If you buy a board or panel from Waveshare or someone else, you would need to ask the vendor which panel from Good Display it corresponds to. Maybe he knows.
The inking on the flex connector can help to exclude candidates, but there is no one-to-one relation.
Hey @ZinggJM and @vanilla_chief, thank you both for your fast responses. I've also tried the same setup as @vanilla_chief and it indeed worked with the ESP8266. After trying the same setup with an Arduino Pro Mini (3.3V) though, it doesn't work. I used the suggested pin mapping. Looking at the Serial Monitor I get:
Setup
Setup
Setup
and so forth
I will try a different pin setup and keep you updated. Meanwhile I'll also text Waveshare, maybe they'll indeed send you a free sample. I'd be ready to donate you one if they don't.
@allllo, Hi,
do you use paged display? The firstPage()...nextPage() loop?
It looks like you get exceptions and processor restarts.
Please also report which example you use. And memory use reported by the IDE.
I'm using the first example code of the library, that is "GxEPD2_Example". Just like @vanilla_chief I replaced the init code with "init(115200, true, 2, false)". I uncommented the line for GxEPD2_290_T94 in the display selection header.
The IDE reports a program memory usage of 65% and a dynamic memory usage of 78%, and warns me about low ram.
Including GFX_Root reduces memory to 58% and 71% respectively. The serial output stays the same for all cases. I have another Arduino Pro Mini here and will try it with that one as well.
EDIT: It works with a generic STM32F103CB
EDIT2: Nevermind. It seems my Arduino Board was faulty. On the spare board it does work. Thank you for your time! .. and sorry for wasting you time
Hello @ZinggJM !
I need help with board manager-ish/ GxEPD2 Library issue/ an explanation. I am using an ESP32 trigBoardv8 and have tried using the GxEPD2 library with the board manager, ESP32 v1.0.5 and above, with the ESP32 getting stuck in some sort of boot loop. For example the output is:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
To which its hung at the "?" because of an serial.print() before the initialization of the display and
should I remove the serial.print(), it then gets stuck in a boot loop and stops after a bit. Not a flicker on the display.
This is the example code I was working with (just adjusted to the trigBoard with some extra serial.prints() for troublshooting etc):
(his code is the description, it goes directly to a google doc redirect so be warned Here...)
Yet when I switch back to v1.0.4 for the ESP32 in board manager and the GxEPD2 is back to working. Why is this. I need the edits from the http redirect library as part of the v1.0.6 ESP32 in board manager as it actually lets me get to google scripts quite well-- long story short I get a text output from google scripts and want to put it on the display. Now v1.0.4 for the ESP32 in board manager was flawed and failed to handle Google's redirects as well as giving me a plethora of unnecessary issues with the Arduino IDE, wifi.h, and wificlientsecure.h.
Any suggestions or perhaps a fix so I can get my project working as a whole. I would rather it be on the side of the GxEPD2 library if at all possible. If it has to be messing with the ESP32 code in the board manager it would be awesome for some links on what to do or a solution. I really want to know why the GxEPD2 Library is behaving this way too. As it would help me with my senior project it was an unexpected issue that I may have to explain why my project wasn't working via the due date.
-OverThere
@thatpersonoverthere, Hi, maybe related to this issue:
The ESP32 processor hangs on a second call to Serial.begin(115200) when compiled for ESP32 Dev Module. · Issue #5043 · espressif/arduino-esp32 · GitHub
Jean-Marc
Dang you quick @ZinggJM , Thank you! Beat me to the punch 14 days ago I see.... again thank you so much. I hope it can be fixed! If its not, that's more than enough of an explanation!!!!!!!
Edit: got rid of the serial.begin(115200); and it works now
Hello ZinggJM,
Thank you for sending me the link and details.
I'm trying to see some results in both MKRZERO and MEGA, but as result I'm getting this:
setup
Busy Timeout!
_PowerOn : 20000796
Busy Timeout!
_Update_Full : 20000640
Busy Timeout!
_PowerOff : 20000180
Busy Timeout!
_PowerOn : 20001020
Busy Timeout!
_Update_Part : 20000772
Busy Timeout!
_Update_Part : 20001076
Busy Timeout!
_Update_Part : 20000848
Busy Timeout!
_Update_Full : 20000156
Busy Timeout!
Busy Timeout!
_PowerOn : 20000392
Busy Timeout!
_Update_Part : 20000640
Busy Timeout!
_Update_Part : 20000704
Busy Timeout!
_Update_Part : 20000536
Busy Timeout!
_Update_Part : 20000628
Busy Timeout!
Busy Timeout!
_Update_Part : 20000976
Any suggestion about what it can be ?
Thank you very much once again for your time and consideration.
Best regards
Lucci
@Luthi, Hi Lucci, welcome to the forum. Please read How to get the best out of this forum.
Yes, there is something wrong with your wiring. Looks like your SPI communication doesn't work.
I need complete information to be able to help. It is frustrating to have to ask back.
Please post a link to your e-paper panel or board and to the connection module (if separate).
Tell which processor you used, a link if not a common one.
Please report the wiring you used. And the constructor line you selected (old style), or the driver class definition and constructor line (new style).
Also report the example you used. Diagnostic output is preferred in a code window.
Jean-Marc
OMG !
Thank you for your feedback.
The Wiring I tried as suggested
// mapping suggestion for Arduino MKR1000 or MKRZERO
// note: can't use SS on MKR1000: is defined as 24, should be 4
// BUSY -> 5, RST -> 6, DC -> 7, CS-> 4, CLK -> 9, DIN -> 8
I'm trying to use the GxEPD2_GFX_Example, when I compile it shows me:
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:46
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : false
BOR : false
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.814 seconds
Write 161804 bytes to flash (2529 pages)
[==============================] 100% (2529/2529 pages)
done in 0.883 seconds
Verify 161804 bytes of flash with checksum.
Verify successful
done in 0.133 seconds
CPU reset.
But after it, nothing happens
Thank you very much for your attention again.
Best regards
Lucci
Nothing in Serial Monitor?
Please read my post again and provide all information requested.
On the picture I see that your Waveshare board has the "clever" reset circuit. From README.md:
- note that Waveshare bords with "clever" reset circuit may need shortened reset pulse
- use `init(115200, true, 2, false)` for Waveshare boards with "clever" reset circuit
Sorry Zingg, but where in the waveshare, did you saw the reset ? The last picture is my Arduino MKRZero just there I have the Reset button.
In the serial port, I received the same message as I described above:
setup
Busy Timeout!
_PowerOn : 20000796
Busy Timeout!
Busy Timeout!
Busy Timeout!
_PowerOn : 20001020
Busy Timeout!
Busy Timeout!
