WeAct 1.54 inch E-paper Arduino Pro Mini
Hello,
I bought my first E-paper display - the "WeAct 1.54 inch", but I'm having no luck getting anything to work with my Arduino Pro Mini and the GxEPD2 library. When trying to upload the short example code, there is an error saying "Not enough memory".
Is this library really so big it cannot be used with the Arduino Pro Mini or am I missing something? Would appreciate any suggestions!
Hi, welcome to the forum!
One of the features of GxEPD2 is its ability to cope with limited RAM, by using so called "paged drawing".
Take a look at the README.md of the library.
Try to use GxEPD2_Example with your display, to learn how it works.
if you have an issue with limited code space, then you can comment out some example bitmaps.
Thanks for the suggestion.
I tried this example, and uncommented all bitmaps apart from:
#include "bitmaps/Bitmaps200x200.h" // 1.54" b/w
Also removed:
#include <GxEPD2_3C.h>
#include <GxEPD2_4C.h>
#include <GxEPD2_7C.h>
Used the constructor:
// 1.54'' EPD Module
GxEPD2_BW<GxEPD2_154_D67, GxEPD2_154_D67::HEIGHT> display(GxEPD2_154_D67(/CS=5/ SS, /DC=/ 1, /RES=/ 2, /BUSY=/ 3)); // GDEH0154D67 200x200, SSD1681
But still it says:
Sketch uses 22252 bytes (72%) of program storage space. Maximum is 30720 bytes.
data section exceeds available space in board
Global variables use 5835 bytes (284%) of dynamic memory
This is the cause of your issue. You don't have enough RAM for full buffered graphics.
Take another look at the example.
Either use a fraction of HEIGHT, or use the MAX_HEIGHT macro.
Not entirely sure what you meant but I came across some code and tried this:
#define MAX_DISPLAY_BUFFER_SIZE 800 //
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8) ? EPD::HEIGHT : MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8))
GxEPD2_BW<GxEPD2_154_D67, MAX_HEIGHT(GxEPD2_154_D67)> display(GxEPD2_154_D67(/*CS=5*/ SS, /*DC=*/ 1, /*RES=*/ 2, /*BUSY=*/ 3)); // GDEH0154D67 200x200, SSD1681
The memory problems have gone which is good, so I uploaded the code and wired it up
but nothing happened to the display. Do you know how to define the full set of pins?
This constructor is only defining 4, so I am unsure how it is determining the wiring.
Having used OLED displays I thought I would not be out of my depth using an E-Paper display but it seems they are more complex and much less info available on them!
I am not sure if I should answer at all. But you could consult this file:
https://github.com/ZinggJM/GxEPD2/blob/master/examples/GxEPD2_Example/GxEPD2_wiring_examples.h
I'm sorry if my ignorance is frustrating! I do appreciate your help.
Well, it's taken virtually all day but it is now working.
In case it is of use to anyone else, here is a working example code for a WeAct Studio 1.54 inch 200 x 200 pixel E-paper SPI display and an Arduino Pro Mini.
Libraries needed: GxEPD2 and AdafruitGFX
Wiring: BUSY -> 7, RST -> 9, DC -> 8, CS-> 10, SCL -> 13, SDA -> 11
// Pin connection wiring for Arduino Pro Mini: BUSY -> 7, RST -> 9, DC -> 8, CS-> 10, SCL -> 13, SDA -> 11
#define ENABLE_GxEPD2_GFX 0
// uncomment next line to use class GFX of library GFX_Root instead of Adafruit_GFX
//#include <GFX.h>
// Note: if you use this with ENABLE_GxEPD2_GFX 1:
//       uncomment it in GxEPD2_GFX.h too, or add #include <GFX.h> before any #include <GxEPD2_GFX.h>
#include <GxEPD2_BW.h>
#include <Fonts/FreeMonoBold9pt7b.h>
GxEPD2_BW<GxEPD2_154_D67, MAX_HEIGHT(GxEPD2_154_D67)> display(GxEPD2_154_D67(/*CS=5*/ 10, /*DC=*/ 8, /*RES=*/ 9, /*BUSY=*/ 7)); // GDEH0154D67 200x200, SSD1681
#if !defined(__AVR) && !defined(STM32F1xx)
#endif
  Serial.println("setup");
  delay(100);
#if defined(ARDUINO_ARCH_RP2040) && (defined(ARDUINO_RASPBERRY_PI_PICO) || defined(ARDUINO_RASPBERRY_PI_PICO_W))
  // uncomment next line for use with GoodDisplay DESPI-PICO or my proto board, or Waveshare RPi boards
  display.epd2.selectSPI(SPIn, SPISettings(4000000, MSBFIRST, SPI_MODE0));
  // uncomment next 2 lines to allow recovery from configuration failures
  pinMode(15, INPUT_PULLUP); // safety pin
  while (!digitalRead(15)) delay(100); // check safety pin for fail recovery
  // recovery can be done also by holding BOOTSEL during power-up.
  // uncomment next line for Waveshare PhotoPainter module
  pinMode(16, OUTPUT); digitalWrite(16, HIGH); // power to the paper
#endif
#if defined(ESP32) && defined(USE_HSPI_FOR_EPD)
  hspi.begin(13, 12, 14, 15); // remap hspi for EPD (swap pins)
  display.epd2.selectSPI(hspi, SPISettings(4000000, MSBFIRST, SPI_MODE0));
#elif (defined(ARDUINO_ARCH_ESP32) && defined(ARDUINO_LOLIN_S2_MINI))
  // SPI.begin(sck, miso, mosi, ss); // preset for remapped pins
  SPI.begin(18, -1, 16, 33); // my LOLIN ESP32 S2 mini connection
#endif
  //display.init(115200); // default 10ms reset pulse, e.g. for bare panels with DESPI-C02
  display.init(115200, true, 2, false); // USE THIS for Waveshare boards with "clever" reset circuit, 2ms reset pulse
  //display.init(115200, true, 10, false, SPIn, SPISettings(4000000, MSBFIRST, SPI_MODE0)); // extended init method with SPI channel and/or settings selection
  if (display.pages() > 1)
    delay(100);
    Serial.print("pages = "); Serial.print(display.pages()); Serial.print(" page height = "); Serial.println(display.pageHeight());
  // first update should be full refresh
  helloWorld();
  // partial refresh mode can be used to full screen,
  // effective if display panel hasFastPartialUpdate
  helloFullScreenPartialMode();
  //stripeTest(); return; // GDEH029Z13 issue
  helloArduino();
  helloEpaper();
  //helloValue(123.9, 1);
  //delay(1000);
  showFont("FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
  if (display.epd2.WIDTH < 104)
    showFont("glcdfont", 0);
  //drawGrid(); return;
  drawBitmaps();
  //display.powerOff(); return;
  drawGraphics();
  //return;
#if !defined(__AVR) // takes too long!
  if ((display.epd2.panel == GxEPD2::ACeP565) || (display.epd2.panel == GxEPD2::GDEY073D46) || (display.epd2.panel == GxEPD2::ACeP730))
    //draw7colorlines();
    //delay(2000);
    draw7colors();
    delay(4000);
    //return;
#endif
  if (display.epd2.hasPartialUpdate)
    showPartialUpdate();
  } // else // on GDEW0154Z04 only full update available, doesn't look nice
  //drawCornerTest();
  //showBox(16, 16, 48, 32, false);
  //showBox(16, 56, 48, 32, true);
  display.powerOff();
  deepSleepTest();
#if defined(ESP32) && defined(_GxBitmaps1304x984_H_)
  drawBitmaps1304x984();
  display.powerOff();
#endif
  Serial.println("setup done");
  display.end();
// note for partial update window and setPartialWindow() method:
// partial update window size and position is on byte boundary in physical x direction
// the size is increased in setPartialWindow() if x or w are not multiple of 8 for even rotation, y or h for odd rotation
// see also comment in GxEPD2_BW.h, GxEPD2_3C.h or GxEPD2_GFX.h for method setPartialWindow()
const char HelloWorld[] = "Hello World!";
const char HelloArduino[] = "Hello Arduino!";
const char HelloEpaper[] = "Hello E-Paper!";
void helloWorld()
  //Serial.println("helloWorld");
  display.setRotation(1);
  display.setFont(&FreeMonoBold9pt7b);
  if (display.epd2.WIDTH < 104) display.setFont(0);
  display.setTextColor(GxEPD_BLACK);
  int16_t tbx, tby; uint16_t tbw, tbh;
  display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
  // center bounding box by transposition of origin:
  uint16_t x = ((display.width() - tbw) / 2) - tbx;
  uint16_t y = ((display.height() - tbh) / 2) - tby;
  display.setFullWindow();
  display.firstPage();
  do
    display.fillScreen(GxEPD_WHITE);
    display.setCursor(x, y);
    display.print(HelloWorld);
  while (display.nextPage());
  //Serial.println("helloWorld done");
void helloWorldForDummies()
  const char text[] = "Hello World!";
  // most e-papers have width < height (portrait) as native orientation, especially the small ones
  // in GxEPD2 rotation 0 is used for native orientation (most TFT libraries use 0 fix for portrait orientation)
  // set rotation to 1 (rotate right 90 degrees) to have enough space on small displays (landscape)
  // select a suitable font in Adafruit_GFX
  // on e-papers black on white is more pleasant to read
  // Adafruit_GFX has a handy method getTextBounds() to determine the boundary box for a text for the actual font
  int16_t tbx, tby; uint16_t tbw, tbh; // boundary box window
  display.getTextBounds(text, 0, 0, &tbx, &tby, &tbw, &tbh); // it works for origin 0, 0, fortunately (negative tby!)
  // full window mode is the initial mode, set it anyway
  // here we use paged drawing, even if the processor has enough RAM for full buffer
  // so this can be used with any supported processor board.
  // the cost in code overhead and execution time penalty is marginal
  // tell the graphics class to use paged drawing mode
  do
    // this part of code is executed multiple times, as many as needed,
    // in case of full buffer it is executed once
    // IMPORTANT: each iteration needs to draw the same, to avoid strange effects
    // use a copy of values that might change, don't read e.g. from analog or pins in the loop!
    display.fillScreen(GxEPD_WHITE); // set the background to white (fill the buffer with value for white)
    display.setCursor(x, y); // set the postition to start printing text
    display.print(text); // print some text
    // end of part executed multiple times
  // tell the graphics class to transfer the buffer content (page) to the controller buffer
  // the graphics class will command the controller to refresh to the screen when the last page has been transferred
  // returns true if more pages need be drawn and transferred
  // returns false if the last page has been transferred and the screen refreshed for panels without fast partial update
  // returns false for panels with fast partial update when the controller buffer has been written once more, to make the differential buffers equal
  // (for full buffered with fast partial update the (full) buffer is just transferred again, and false returned)
void helloFullScreenPartialMode()
  //Serial.println("helloFullScreenPartialMode");
  const char fullscreen[] = "full screen update";
  const char fpm[] = "fast partial mode";
  const char spm[] = "slow partial mode";
  const char npm[] = "no partial mode";
  display.setPartialWindow(0, 0, display.width(), display.height());
  const char* updatemode;
  if (display.epd2.hasFastPartialUpdate)
    updatemode = fpm;
  else if (display.epd2.hasPartialUpdate)
    updatemode = spm;
    updatemode = npm;
  // do this outside of the loop
  // center update text
  display.getTextBounds(fullscreen, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t utx = ((display.width() - tbw) / 2) - tbx;
  uint16_t uty = ((display.height() / 4) - tbh / 2) - tby;
  // center update mode
  display.getTextBounds(updatemode, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t umx = ((display.width() - tbw) / 2) - tbx;
  uint16_t umy = ((display.height() * 3 / 4) - tbh / 2) - tby;
  // center HelloWorld
  uint16_t hwx = ((display.width() - tbw) / 2) - tbx;
  uint16_t hwy = ((display.height() - tbh) / 2) - tby;
  do
    display.setCursor(hwx, hwy);
    display.setCursor(utx, uty);
    display.print(fullscreen);
    display.setCursor(umx, umy);
    display.print(updatemode);
  //Serial.println("helloFullScreenPartialMode done");
void helloArduino()
  //Serial.println("helloArduino");
  display.setTextColor(display.epd2.hasColor ? GxEPD_RED : GxEPD_BLACK);
  // align with centered HelloWorld
  // height might be different
  display.getTextBounds(HelloArduino, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = ((display.height() / 4) - tbh / 2) - tby; // y is base line!
  // make the window big enough to cover (overwrite) descenders of previous text
  uint16_t wh = FreeMonoBold9pt7b.yAdvance;
  uint16_t wy = (display.height() / 4) - wh / 2;
  display.setPartialWindow(0, wy, display.width(), wh);
  do
    //display.drawRect(x, y - tbh, tbw, tbh, GxEPD_BLACK);
    display.print(HelloArduino);
  //Serial.println("helloArduino done");
void helloEpaper()
  //Serial.println("helloEpaper");
  display.getTextBounds(HelloEpaper, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = ((display.height() * 3 / 4) - tbh / 2) - tby; // y is base line!
  uint16_t wy = (display.height() * 3 / 4) - wh / 2;
  do
    display.print(HelloEpaper);
  //Serial.println("helloEpaper done");
// test partial window issue on GDEW0213Z19 and GDEH029Z13
void stripeTest()
  helloStripe(104);
  delay(2000);
  helloStripe(96);
const char HelloStripe[] = "Hello Stripe!";
void helloStripe(uint16_t pw_xe) // end of partial window in physcal x direction
  //Serial.print("HelloStripe("); Serial.print(pw_xe); Serial.println(")");
  display.setRotation(3);
  display.getTextBounds(HelloStripe, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t wy = pw_xe - wh;
  uint16_t y = wy - tby;
  do
    display.print(HelloStripe);
  //Serial.println("HelloStripe done");
#if defined(ESP8266) || defined(ESP32)
#include <StreamString.h>
#define PrintString StreamString
#else
class PrintString : public Print, public String
  public:
    size_t write(uint8_t data) override
      return concat(char(data));
#endif
void helloValue(double v, int digits)
  //Serial.println("helloValue");
  PrintString valueString;
  valueString.print(v, digits);
  display.getTextBounds(valueString, 0, 0, &tbx, &tby, &tbw, &tbh);
  // show what happens, if we use the bounding box for partial window
  uint16_t wx = (display.width() - tbw) / 2;
  uint16_t wy = ((display.height() * 3 / 4) - tbh / 2);
  display.setPartialWindow(wx, wy, tbw, tbh);
  do
    display.print(valueString);
  delay(2000);
  // make the partial window big enough to cover the previous text
  uint16_t ww = tbw; // remember window width
  // adjust, because HelloEpaper was aligned, not centered (could calculate this to be precise)
  ww = max(ww, uint16_t(tbw + 12)); // 12 seems ok
  display.setPartialWindow(wx, wy, ww, wh);
  // alternately use the whole width for partial window
  //display.setPartialWindow(0, wy, display.width(), wh);
  do
  //Serial.println("helloValue done");
void deepSleepTest()
  //Serial.println("deepSleepTest");
  const char hibernating[] = "hibernating ...";
  const char wokeup[] = "woke up";
  const char from[] = "from deep sleep";
  const char again[] = "again";
  // center text
  display.getTextBounds(hibernating, 0, 0, &tbx, &tby, &tbw, &tbh);
  do
    display.print(hibernating);
  display.hibernate();
  delay(5000);
  display.getTextBounds(wokeup, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t wy = ((display.height() / 3) - tbh / 2) - tby; // y is base line!
  display.getTextBounds(from, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t fx = (display.width() - tbw) / 2;
  uint16_t fy = ((display.height() * 2 / 3) - tbh / 2) - tby; // y is base line!
  do
    display.setCursor(wx, wy);
    display.print(wokeup);
    display.setCursor(fx, fy);
    display.print(from);
  delay(5000);
  uint16_t hx = (display.width() - tbw) / 2;
  uint16_t hy = ((display.height() / 3) - tbh / 2) - tby; // y is base line!
  display.getTextBounds(again, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t ax = (display.width() - tbw) / 2;
  uint16_t ay = ((display.height() * 2 / 3) - tbh / 2) - tby; // y is base line!
  do
    display.setCursor(hx, hy);
    display.setCursor(ax, ay);
    display.print(again);
  //Serial.println("deepSleepTest done");
void showBox(uint16_t x, uint16_t y, uint16_t w, uint16_t h, bool partial)
  //Serial.println("showBox");
  if (partial)
    display.setPartialWindow(x, y, w, h);
  do
    display.fillRect(x, y, w, h, GxEPD_BLACK);
  //Serial.println("showBox done");
void drawCornerTest()
  for (uint16_t r = 0; r <= 4; r++)
    display.setRotation(r);
    do
      display.fillRect(0, 0, 8, 8, GxEPD_BLACK);
      display.fillRect(display.width() - 18, 0, 16, 16, GxEPD_BLACK);
      display.fillRect(display.width() - 25, display.height() - 25, 24, 24, GxEPD_BLACK);
      display.fillRect(0, display.height() - 33, 32, 32, GxEPD_BLACK);
      display.setCursor(display.width() / 2, display.height() / 2);
      display.print(display.getRotation());
    delay(2000);
void showFont(const char name[], const GFXfont* f)
  display.setRotation(0);
  do
    drawFont(name, f);
void drawFont(const char name[], const GFXfont* f)
  //display.setRotation(0);
  display.setFont(f);
  display.setCursor(0, 0);
  display.println();
  display.println(name);
  display.println(" !\"#$%&'()*+,-./");
  display.println("0123456789:;<=>?");
  display.println("@ABCDEFGHIJKLMNO");
  display.println("PQRSTUVWXYZ[\\]^_");
  if (display.epd2.hasColor)
    display.setTextColor(GxEPD_RED);
  display.println("`abcdefghijklmno");
  display.println("pqrstuvwxyz{|}~ ");
// showPartialUpdate() purposely uses values that are not multiples of 8 to test this
void showPartialUpdate()
  // some useful background
  helloWorld();
  // use asymmetric values for test
  uint16_t box_x = 10;
  uint16_t box_y = 15;
  uint16_t box_w = 70;
  uint16_t box_h = 20;
  uint16_t cursor_y = box_y + box_h - 6;
  if (display.epd2.WIDTH < 104) cursor_y = box_y + 6;
  float value = 13.95;
  uint16_t incr = display.epd2.hasFastPartialUpdate ? 1 : 3;
  // show where the update box is
  for (uint16_t r = 0; r < 4; r++)
    display.setPartialWindow(box_x, box_y, box_w, box_h);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_BLACK);
      //display.fillScreen(GxEPD_BLACK);
    delay(2000);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_WHITE);
  //return;
  // show updates in the update box
    for (uint16_t i = 1; i <= 10; i += incr)
      do
        display.setCursor(box_x, cursor_y);
        display.print(value * i, 2);
    do
void drawGrid()
  uint16_t x, y;
  do
    x = 0;
    do
      display.drawLine(x, 0, x, display.height() - 1, GxEPD_BLACK);
      x += 10;
    while (x < display.width());
    y = 0;
    do
      display.drawLine(0, y, display.width() - 1, y, GxEPD_BLACK);
      y += 10;
    while (y < display.height());
    x = 0;
    do
      display.fillCircle(x, display.height() / 2, 3, GxEPD_BLACK);
      x += 50;
    while (x <= display.width());
    y = 0;
    do
      display.fillCircle(display.width() / 2, y, 3, GxEPD_BLACK);
      y += 50;
    while (y <= display.height());
void drawBitmaps()
#ifdef _GxBitmaps80x128_H_
  drawBitmaps80x128();
#endif
#ifdef _GxBitmaps152x152_H_
  drawBitmaps152x152();
#endif
#ifdef _GxBitmaps104x212_H_
  drawBitmaps104x212();
#endif
#ifdef _GxBitmaps128x250_H_
  drawBitmaps128x250();
#endif
#ifdef _GxBitmaps128x296_H_
  drawBitmaps128x296();
#endif
#ifdef _GxBitmaps152x296_H_
  drawBitmaps152x296();
#endif
#ifdef _GxBitmaps240x320_H_
  drawBitmaps240x320();
#endif
#ifdef _GxBitmaps176x264_H_
  drawBitmaps176x264();
#endif
#ifdef _GxBitmaps240x416_H_
  drawBitmaps240x416();
#endif
#ifdef _GxBitmaps400x300_H_
  drawBitmaps400x300();
#endif
#ifdef _GxBitmaps640x384_H_
  drawBitmaps640x384();
#endif
#ifdef _GxBitmaps648x480_H_
  drawBitmaps648x480();
#endif
#ifdef _GxBitmaps800x480_H_
  drawBitmaps800x480();
#endif
#ifdef _WS_Bitmaps800x600_H_
  drawBitmaps800x600();
#endif
#if defined(ESP32) && defined(_GxBitmaps960x640_H_)
  drawBitmaps960x640();
#endif
#if defined(ESP32) && defined(_GxBitmaps960x680_H_)
  drawBitmaps960x680();
#endif
#endif
  // 3-color
#ifdef _GxBitmaps3c104x212_H_
  drawBitmaps3c104x212();
#endif
#ifdef _GxBitmaps3c128x250_H_
  drawBitmaps3c128x250();
#endif
#ifdef _GxBitmaps3c128x296_H_
  drawBitmaps3c128x296();
#endif
#ifdef _GxBitmaps3c152x296_H_
  drawBitmaps3c152x296();
#endif
#ifdef _GxBitmaps3c176x264_H_
  drawBitmaps3c176x264();
#endif
#ifdef _GxBitmaps3c400x300_H_
  drawBitmaps3c400x300();
#endif
#ifdef _GxBitmaps3c648x480_H_
  drawBitmaps3c648x480();
#endif
#ifdef _GxBitmaps3c800x480_H_
  drawBitmaps3c800x480();
#endif
#ifdef _GxBitmaps3c880x528_H_
  drawBitmaps3c880x528();
#endif
#if defined(ESP32) && defined(_GxBitmaps3c960x640_H_)
  drawBitmaps3c960x640();
#endif
#if defined(ESP32) && defined(_GxBitmaps3c960x680_H_)
  drawBitmaps3c960x680();
#endif
  // 4-color
#if defined(_GxBitmaps4c128x250_H_)
  drawBitmaps4c128x250();
#endif
#if defined(_WS_Bitmaps4c168x168_H_)
  drawBitmaps4c168x168();
#endif
#endif
#if defined(_GxBitmaps4c168x384_H_)
  drawBitmaps4c168x384();
#endif
#if defined(_GxBitmaps4c184x360_H_)
  drawBitmaps4c184x360();
#endif
#if defined(_GxBitmaps4c400x300_H_)
  drawBitmaps4c400x300();
#endif
#if defined(_WS_Bitmaps7c192x143_H_)
  drawBitmaps7c192x143();
#endif
#if defined(_GxBitmaps7c800x480_H_)
  drawBitmaps7c800x480();
#endif
#if defined(_WS_Bitmaps7c300x180_H_)
  drawBitmaps7c300x180();
#endif
  if ((display.epd2.WIDTH >= 200) && (display.epd2.HEIGHT >= 200))
    // show these after the specific bitmaps
#ifdef _GxBitmaps200x200_H_
    drawBitmaps200x200();
#endif
#if defined(ESP32) && defined(_GxBitmaps1360x480_H_)
    drawBitmaps1360x480();
#endif
    // 3-color
#ifdef _GxBitmaps3c200x200_H_
    drawBitmaps3c200x200();
#endif
#if defined(ESP32) && defined(_GxBitmaps3c1304x984_H_)
  drawBitmaps3c1304x984();
#endif
void drawBitmaps80x128()
#if !defined(__AVR)
  const unsigned char* bitmaps[] =
    Bitmap80x128_1, Bitmap80x128_2, Bitmap80x128_3, Bitmap80x128_4, Bitmap80x128_5
#else
#endif
  if ((display.epd2.WIDTH == 80) && (display.epd2.HEIGHT == 128))
    for (uint16_t i = 0; i < sizeof(bitmaps) / sizeof(char*); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 80, 128, GxEPD_BLACK);
      delay(2000);
    do
      display.drawBitmap(0, 0, WS_Bitmap80x128, 80, 128, GxEPD_BLACK);
    delay(2000);
#endif
void drawBitmaps152x152()
#if !defined(__AVR)
    Bitmap152x152_1, Bitmap152x152_2, Bitmap152x152_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 152))
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 152, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps200x200()
#if defined(ARDUINO_AVR_PRO)
    logo200x200
#elif defined(__AVR)
    logo200x200, //first200x200
#elif defined(_BOARD_GENERIC_STM32F103C_H_) || defined(STM32F1xx)
    logo200x200, first200x200, second200x200, third200x200, //fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
#else
    logo200x200, first200x200, second200x200, third200x200, fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
    //logo200x200, first200x200, second200x200, fourth200x200, third200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200 // ED037TC1 test
#endif
  if (display.epd2.hasColor) return; // to avoid many long refreshes
  if ((display.epd2.WIDTH == 200) && (display.epd2.HEIGHT == 200) && !display.epd2.hasColor)
    bool m = display.mirror(true);
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 200, 200, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
  //else
    bool mirror_y = (display.epd2.panel != GxEPD2::GDE0213B1);
    display.clearScreen(); // use default for white
    int16_t x = (int16_t(display.epd2.WIDTH) - 200) / 2;
    int16_t y = (int16_t(display.epd2.HEIGHT) - 200) / 2;
      display.drawImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
    int16_t x = -60;
    int16_t y = -60;
    for (uint16_t j = 0; j < 10; j++)
      display.writeScreenBuffer(); // use default for white
      display.writeImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      display.refresh(true);
        // for differential update: set previous buffer equal to current buffer in controller
        display.epd2.writeScreenBufferAgain(); // use default for white
        display.epd2.writeImageAgain(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
      x += display.epd2.WIDTH / 4;
      y += display.epd2.HEIGHT / 4;
      if ((x >= int16_t(display.epd2.WIDTH)) || (y >= int16_t(display.epd2.HEIGHT))) break;
    if (!display.epd2.hasFastPartialUpdate) break; // comment out for full show
  display.writeImage(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.writeImage(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  delay(2000);
#endif
void drawBitmaps104x212()
#if !defined(__AVR)
    WS_Bitmap104x212, Bitmap104x212_1, Bitmap104x212_2, Bitmap104x212_3
#else
#endif
  if ((display.epd2.WIDTH == 104) && (display.epd2.HEIGHT == 212) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 104, 212, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps128x250()
#if !defined(__AVR)
    Bitmap128x250_1, logo128x250, first128x250, second128x250, third128x250
#else
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 250) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 250, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps128x296()
#if !defined(__AVR)
    Bitmap128x296_1, logo128x296, first128x296, second128x296, third128x296
#else
    Bitmap128x296_1, logo128x296 //, first128x296, second128x296, third128x296
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 296, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps152x296()
#if !defined(__AVR)
    Bitmap152x296_1, Bitmap152x296_2, Bitmap152x296_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 296, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps240x320()
#if !defined(__AVR)
    Bitmap240x320_1, Bitmap240x320_2, Bitmap240x320_3, Bitmap240x320_4, Bitmap240x320_5
#else
#endif
  if ((display.epd2.WIDTH == 240) && (display.epd2.HEIGHT == 320) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 240, 320, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps176x264()
#if !defined(__AVR)
    Bitmap176x264_1, Bitmap176x264_2, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#else
    Bitmap176x264_1, Bitmap176x264_2 //, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#endif
  if ((display.epd2.WIDTH == 176) && (display.epd2.HEIGHT == 264) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 176, 264, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps240x416()
#if !defined(__AVR)
    Bitmap240x416_1, Bitmap240x416_2, Bitmap240x416_3
#else
    Bitmap240x460_1, Bitmap240x460_2, Bitmap240x460_3
#endif
  if ((display.epd2.WIDTH == 240) && (display.epd2.HEIGHT == 416) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 240, 416, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps400x300()
#if !defined(__AVR)
    Bitmap400x300_1, Bitmap400x300_2
#else
  const unsigned char* bitmaps[] = {}; // not enough code space
#endif
  if ((display.epd2.WIDTH == 400) && (display.epd2.HEIGHT == 300) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 400, 300, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps640x384()
#if !defined(__AVR)
    Bitmap640x384_1, Bitmap640x384_2
#else
#endif
  if ((display.epd2.WIDTH == 640) && (display.epd2.HEIGHT == 384))
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 640, 384, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps648x480()
#if !defined(__AVR)
    Bitmap648x480_1, Bitmap648x480_2, Bitmap648x480_3
#else
#endif
  if ((display.epd2.WIDTH == 648) && (display.epd2.HEIGHT == 480) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 648, 480, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps800x480()
#if defined(ARDUINO_UNOR4_MINIMA) || defined(ARDUINO_UNOR4_WIFI)
    Bitmap800x480_3, Bitmap800x480_4
#elif !defined(__AVR)
    Bitmap800x480_1, Bitmap800x480_2, Bitmap800x480_3, Bitmap800x480_4
#else
#endif
  if ((display.epd2.WIDTH == 800) && (display.epd2.HEIGHT == 480))
      do
        display.drawBitmap(0, 0, bitmaps[i], 800, 480, GxEPD_BLACK);
      delay(2000);
    if ((display.epd2.panel == GxEPD2::GDEW075T7) || (display.epd2.panel == GxEPD2::GDEY075T7))
      // avoid ghosting caused by OTP waveform
      display.refresh(false); // full update
#endif
void drawBitmaps960x640()
  if ((display.epd2.WIDTH == 960) && (display.epd2.HEIGHT == 640) && !display.epd2.hasColor)
    display.drawImage(Bitmap960x640_1, 0, 0, 960, 640, false, true, true); delay(5000);
    display.drawImage(Bitmap960x640_2, 0, 0, 960, 640, false, true, true); delay(5000);
    display.drawImage(Bitmap960x640_3, 0, 0, 960, 640, false, true, true); delay(5000);
#endif
void drawBitmaps960x680()
  if ((display.epd2.WIDTH == 960) && (display.epd2.HEIGHT == 680) && !display.epd2.hasColor)
    display.drawImage(Bitmap960x680_1, 0, 0, 960, 680, false, true, true); delay(5000);
    display.drawImage(Bitmap960x680_2, 0, 0, 960, 680, false, true, true); delay(5000);
#endif
void drawBitmaps800x600()
  if ((display.epd2.panel == GxEPD2::ED060SCT) || (display.epd2.panel == GxEPD2::ED060KC1) || (display.epd2.panel == GxEPD2::ED078KC2))
    //    Serial.print("sizeof(WS_zoo_800x600) is "); Serial.println(sizeof(WS_zoo_800x600));
    display.drawNative(WS_zoo_800x600, 0, 0, 0, 800, 600, false, false, true);
    delay(2000);
    //    Serial.print("sizeof(WS_pic_1200x825) is "); Serial.println(sizeof(WS_pic_1200x825));
    //    display.drawNative((const uint8_t*)WS_pic_1200x825, 0, 0, 0, 1200, 825, false, false, true);
    //    delay(2000);
    //    Serial.print("sizeof(WS_acaa_1024x731) is "); Serial.println(sizeof(WS_acaa_1024x731));
    //    display.drawNative(WS_acaa_1024x731, 0, 0, 0, 1024, 731, false, false, true);
    //    delay(2000);
#endif
#endif
void drawBitmaps1304x984()
  if (display.epd2.panel == GxEPD2::GDEW1248T3)
    display.drawImage(Bitmap1304x984, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
#endif
void drawBitmaps1360x480()
  if (display.epd2.panel == GxEPD2::GDEM1085T51)
    display.drawImage(Bitmap1360x480_1, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
    delay(2000);
    display.drawImage(Bitmap1360x480_p1, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
    display.drawImage(Bitmap1360x480_p2, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
    display.drawImage(Bitmap1360x480_p3, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
    int16_t wp = display.epd2.WIDTH / 5;
    int16_t hp = display.epd2.HEIGHT / 5;
    for (int16_t i = 0; i < 5; i++)
      for (int16_t j = 0; j < 5; j++)
        display.writeImagePart(Bitmap1360x480_1, i * wp, j * hp, 1360, 480, i * wp, j * hp, wp, hp, false, false, true);
#endif
struct bitmap_pair
  const unsigned char* black;
  const unsigned char* red;
void drawBitmaps3c200x200()
  bitmap_pair bitmap_pairs[] =
    //{Bitmap3c200x200_black, Bitmap3c200x200_red},
    {WS_Bitmap3c200x200_black, WS_Bitmap3c200x200_red}
  if (display.epd2.panel == GxEPD2::GDEW0154Z04)
    do
      // Bitmap3c200x200_black has 2 bits per pixel
      // taken from Adafruit_GFX.cpp, modified
      int16_t byteWidth = (display.epd2.WIDTH + 7) / 8; // Bitmap scanline pad = whole byte
      uint8_t byte = 0;
      for (int16_t j = 0; j < display.epd2.HEIGHT; j++)
        for (int16_t i = 0; i < display.epd2.WIDTH; i++)
          if (i & 3) byte <<= 2;
#if defined(__AVR) || defined(ESP8266) || defined(ESP32)
            byte = pgm_read_byte(&Bitmap3c200x200_black[j * byteWidth * 2 + i / 4]);
#else
            byte = Bitmap3c200x200_black[j * byteWidth * 2 + i / 4];
#endif
          if (!(byte & 0x80))
            display.drawPixel(i, j, GxEPD_BLACK);
      display.drawInvertedBitmap(0, 0, Bitmap3c200x200_red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
    delay(2000);
    for (uint16_t i = 0; i < sizeof(bitmap_pairs) / sizeof(bitmap_pair); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
      display.drawImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
      delay(2000);
      int16_t x = -60;
      int16_t y = -60;
        display.writeImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
        display.refresh();
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, 0, 0, 200, 200, false, false, true);
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, int16_t(display.epd2.WIDTH) - 200, int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, false, true);
    display.refresh();
    delay(2000);
#endif
void drawBitmaps3c104x212()
#if !defined(__AVR)
    {Bitmap3c104x212_1_black, Bitmap3c104x212_1_red},
    {Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
    {WS_Bitmap3c104x212_black, WS_Bitmap3c104x212_red}
#else
    //{Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
#endif
  if (display.epd2.panel == GxEPD2::GDEW0213Z16)
      do
        if (bitmap_pairs[i].red == WS_Bitmap3c104x212_red)
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c128x250()
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 250) && display.epd2.hasColor)
    bool mirrored = display.mirror(true);
    do
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_1_black, 128, 250, GxEPD_BLACK);
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_1_red, 128, 250, GxEPD_RED);
    delay(2000);
#if !defined(__AVR)
    do
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_2_black, 128, 250, GxEPD_BLACK);
      display.drawBitmap(0, 0, Bitmap3c128x250_2_red, 128, 250, GxEPD_RED);
    delay(2000);
#endif
    display.mirror(mirrored);
#endif
void drawBitmaps3c128x296()
#if !defined(__AVR)
    {Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    {Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
    {WS_Bitmap3c128x296_black, WS_Bitmap3c128x296_red}
#else
    //{Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    //{Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 128, 296, GxEPD_BLACK);
        if (bitmap_pairs[i].red == WS_Bitmap3c128x296_red)
          display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c152x296()
    {Bitmap3c152x296_black, Bitmap3c152x296_red}
  if (display.epd2.panel == GxEPD2::GDEY0266Z90)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, 152, 296, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 152, 296, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c176x264()
    {Bitmap3c176x264_black, Bitmap3c176x264_red}
  if (display.epd2.panel == GxEPD2::GDEW027C44)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps3c400x300()
#if !defined(__AVR)
    {Bitmap3c400x300_1_black, Bitmap3c400x300_1_red},
    {Bitmap3c400x300_2_black, Bitmap3c400x300_2_red},
    {WS_Bitmap3c400x300_black, WS_Bitmap3c400x300_red}
#else
  bitmap_pair bitmap_pairs[] = {}; // not enough code space
#endif
  if (display.epd2.panel == GxEPD2::GDEW042Z15)
      do
      delay(2000);
#endif
void drawBitmaps3c648x480()
#if !defined(__AVR)
    {Bitmap3c648x480_black, Bitmap3c648x480_red},
    {Bitmap3c648x480_black_2, Bitmap3c648x480_red_2}
#else
#endif
  if ((display.epd2.panel == GxEPD2::GDEW0583Z83) || (display.epd2.panel == GxEPD2::GDEQ0583Z31))
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, 648, 480, GxEPD_BLACK);
        display.drawBitmap(0, 0, bitmap_pairs[i].red, 648, 480, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c800x480()
#if !defined(__AVR)
    {Bitmap3c800x480_1_black, Bitmap3c800x480_1_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEW075Z08)
      do
      delay(2000);
#endif
void drawBitmaps3c880x528()
#if !defined(__AVR)
    {Bitmap3c880x528_black, Bitmap3c880x528_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEH075Z90)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 880, 528, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 880, 528, GxEPD_RED);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps3c960x640()
  if ((display.epd2.WIDTH == 960) && (display.epd2.HEIGHT == 640) && display.epd2.hasColor)
    display.drawImage(Bitmap3c960x640_black, Bitmap3c960x640_red, 0, 0, 960, 640, false, false, true);
    delay(2000);
#endif
void drawBitmaps3c960x680()
  if ((display.epd2.WIDTH == 960) && (display.epd2.HEIGHT == 680) && display.epd2.hasColor)
    display.drawImage(Bitmap3c960x680_black, Bitmap3c960x680_red, 0, 0, 960, 680, false, true, true);
  delay(2000);
#endif
void drawBitmaps3c1304x984()
  if (display.epd2.panel == GxEPD2::GDEY1248Z51)
    //display.drawImage(Bitmap3c1304x984_black, Bitmap3c1304x984_red, 0, 0, 1304, 984, false, false, true);
    display.writeImage(0, Bitmap3c1304x984_red, 0, 0, 1304, 984, true, false, true); // red bitmap is inverted
    display.drawImage(Bitmap3c1304x984_black, 0, 0, 0, 1304, 984, true, false, true); // black bitmap is normal
#endif
void drawBitmaps4c128x250()
  if (display.epd2.panel == GxEPD2::GDEY0213F51)
    display.drawNative(Bitmap4c128x250, 0, 0, 0, 128, 250, false, false, true);
    delay(5000);
#endif
void drawBitmaps4c168x168()
  if ((display.epd2.panel == GxEPD2::Waveshare437inch4color) || (display.epd2.panel == GxEPD2::Waveshare3inch4color))
    display.drawNative(WS_Bitmap4c168x168, 0, (display.epd2.WIDTH - 168) / 2, (display.epd2.HEIGHT - 168) / 2, 168, 168, false, false, true);
    delay(5000);
#endif
#if defined(_WS_Bitmaps4c168x400_H_)
void drawBitmaps4c168x400()
  if (display.epd2.panel == GxEPD2::Waveshare3inch4color)
    display.drawNative(WS_Bitmap4c168x400, 0, (display.epd2.WIDTH - 168) / 2, (display.epd2.HEIGHT - 400) / 2, 168, 400, false, false, true);
    delay(5000);
#endif
void drawBitmaps4c168x384()
  if (display.epd2.panel == GxEPD2::GDEY029F51H)
    display.drawNative(Bitmap4c168x384, 0, (display.epd2.WIDTH - 168) / 2, (display.epd2.HEIGHT - 384) / 2, 168, 384, false, false, true);
    delay(5000);
#endif
void drawBitmaps4c184x360()
  if (display.epd2.panel == GxEPD2::GDEY0266F51H)
    display.drawNative(Bitmap4c184x360, 0, (display.epd2.WIDTH - 184) / 2, (display.epd2.HEIGHT - 360) / 2, 184, 360, false, false, true);
    delay(5000);
#endif
void drawBitmaps4c400x300()
  if (display.epd2.panel == GxEPD2::GDEY0420F51)
    display.drawNative(Bitmap4c400x300, 0, (display.epd2.WIDTH - 400) / 2, (display.epd2.HEIGHT - 300) / 2, 400, 300, false, false, true);
    delay(5000);
#endif
void drawBitmaps7c192x143()
  if (display.epd2.panel == GxEPD2::ACeP565)
    display.drawNative(WS_Bitmap7c192x143, 0, (display.epd2.WIDTH - 192) / 2, (display.epd2.HEIGHT - 143) / 2, 192, 143, false, false, true);
    delay(5000);
#endif
void drawBitmaps7c800x480()
  if ((display.epd2.panel == GxEPD2::GDEY073D46) || (display.epd2.panel == GxEPD2::ACeP730))
    display.epd2.drawDemoBitmap(Bitmap7c800x480, 0, 0, 0, 800, 480, 0, false, true); // special format
    delay(5000);
#endif
void drawBitmaps7c300x180()
    display.drawNative(WS_Bitmap7c300x180, 0, (display.epd2.WIDTH - 300) / 2, (display.epd2.HEIGHT - 180) / 2, 300, 180, false, false, true);
    delay(5000);
#endif
void draw7colors()
  uint16_t h = display.height() / 7;
  do
    display.fillRect(0, 0, display.width(), h, GxEPD_BLACK);
    display.fillRect(0, h, display.width(), h, GxEPD_WHITE);
    display.fillRect(0, 2 * h, display.width(), h, GxEPD_GREEN);
    display.fillRect(0, 3 * h, display.width(), h, GxEPD_BLUE);
    display.fillRect(0, 4 * h, display.width(), h, GxEPD_RED);
    display.fillRect(0, 5 * h, display.width(), h, GxEPD_YELLOW);
    display.fillRect(0, 6 * h, display.width(), h, GxEPD_ORANGE);
void draw7colorlines()
  uint16_t h = 2;
  do
    uint16_t y = 0;
    do
      display.fillRect(0, y, display.width(), h, GxEPD_BLACK); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_WHITE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_GREEN); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_BLUE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_RED); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_YELLOW); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_ORANGE); y += h;
    while ((y + 12 * h) < uint16_t(display.height()));
    //display.drawPixel(0, y, GxEPD_BLACK); display.drawPixel(10, y, GxEPD_GREEN);
    //display.drawPixel(20, y, GxEPD_BLUE); display.drawPixel(30, y, GxEPD_RED);
    //display.drawPixel(40, y, GxEPD_YELLOW); display.drawPixel(50, y, GxEPD_ORANGE);
    display.fillRect(0, y, 2, 2, GxEPD_BLACK); display.fillRect(10, y, 2, 2, GxEPD_GREEN);
    display.fillRect(20, y, 2, 2, GxEPD_BLUE); display.fillRect(30, y, 2, 2, GxEPD_RED);
    display.fillRect(40, y, 2, 2, GxEPD_YELLOW); display.fillRect(50, y, 2, 2, GxEPD_ORANGE);
void drawGraphics()
  do
    display.drawRect(display.width() / 8, display.height() / 8, display.width() * 3 / 4, display.height() * 3 / 4, GxEPD_BLACK);
    display.drawLine(display.width() / 8, display.height() / 8, display.width() * 7 / 8, display.height() * 7 / 8, GxEPD_BLACK);
    display.drawLine(display.width() / 8, display.height() * 7 / 8, display.width() * 7 / 8, display.height() / 8, GxEPD_BLACK);
    display.drawCircle(display.width() / 2, display.height() / 2, display.height() / 4, GxEPD_BLACK);
    display.drawPixel(display.width() / 4, display.height() / 2 , GxEPD_BLACK);
    display.drawPixel(display.width() * 3 / 4, display.height() / 2 , GxEPD_BLACK);
