Waveshare ESP32-S3 Touch LCD 4 (similar to Guition ESP32-S3 4 inch)
These two displays might actually be so similar to not notice a difference.
Following advice on another forum, I have managed to get a simple panel test example compiled without errors. Mainly this was due to needing an old esp32_io_expander library.
Anyway...
The program loads and I can see the backlight turns on. I can actually flash this on and off, so I know the pinout for that is good.
The touch panel seems to work as the example prints out the x,y coords correctly (multi-touch too).
But there is nothing on the screen! What I know about this RGB type of panel is not much, however.
There is a .h file that is required to be edited to reflect the panel/board in use - ESP_Panel_Board_Custom.h
 * SPDX-FileCopyrightText: 2023-2024 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
#pragma once
// *INDENT-OFF*
/* Set to 1 if using a custom board */
#define ESP_PANEL_USE_CUSTOM_BOARD       (1)         // 0/1
#if ESP_PANEL_USE_CUSTOM_BOARD
//////////////////////////// Please update the following macros to configure the LCD panel /////////////////////////////
/* Set to 1 when using an LCD panel */
#define ESP_PANEL_USE_LCD           (1)     // 0/1
#if ESP_PANEL_USE_LCD
 * LCD Controller Name. Choose one of the following:
 *      - EK9716B
 *      - GC9A01, GC9B71, GC9503
 *      - ILI9341
 *      - JD9365
 *      - NV3022B
 *      - SH8601
 *      - SPD2010
 *      - ST7262, ST7701, ST7789, ST7796, ST77916, ST77922
#define ESP_PANEL_LCD_NAME          ST7701
/* LCD resolution in pixels */
#define ESP_PANEL_LCD_WIDTH         (480)
#define ESP_PANEL_LCD_HEIGHT        (480)
/* LCD Bus Settings */
 * If set to 1, the bus will skip to initialize the corresponding host. Users need to initialize the host in advance.
 * It is useful if other devices use the same host. Please ensure that the host is initialized only once.
 * Set to 1 if only the RGB interface is used without the 3-wire SPI interface,
#define ESP_PANEL_LCD_BUS_SKIP_INIT_HOST    (0)     // 0/1
 * LCD Bus Type. Choose one of the following:
 *      - ESP_PANEL_BUS_TYPE_I2C (not ready)
 *      - ESP_PANEL_BUS_TYPE_SPI
 *      - ESP_PANEL_BUS_TYPE_QSPI
 *      - ESP_PANEL_BUS_TYPE_I80 (not ready)
 *      - ESP_PANEL_BUS_TYPE_RGB (only supported for ESP32-S3)
#define ESP_PANEL_LCD_BUS_TYPE      (ESP_PANEL_BUS_TYPE_RGB)
 * LCD Bus Parameters.
 * Please refer to https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/api-reference/peripherals/lcd.html and
 * https://docs.espressif.com/projects/esp-iot-solution/en/latest/display/lcd/index.html for more details.
#if ESP_PANEL_LCD_BUS_TYPE == ESP_PANEL_BUS_TYPE_SPI
    #define ESP_PANEL_LCD_BUS_HOST_ID           (1)     // Typically set to 1
    #define ESP_PANEL_LCD_SPI_IO_CS             (39)
#if !ESP_PANEL_LCD_BUS_SKIP_INIT_HOST
    #define ESP_PANEL_LCD_SPI_IO_SCK            (48)
    #define ESP_PANEL_LCD_SPI_IO_MOSI           (47)
    #define ESP_PANEL_LCD_SPI_IO_MISO           (-1)    // -1 if not used
#endif
    #define ESP_PANEL_LCD_SPI_IO_DC             (18)
    #define ESP_PANEL_LCD_SPI_MODE              (0)     // 0/1/2/3, typically set to 0
    #define ESP_PANEL_LCD_SPI_CLK_HZ            (40 * 1000 * 1000)
                                                        // Should be an integer divisor of 80M, typically set to 40M
    #define ESP_PANEL_LCD_SPI_TRANS_QUEUE_SZ    (10)    // Typically set to 10
    #define ESP_PANEL_LCD_SPI_CMD_BITS          (8)     // Typically set to 8
    #define ESP_PANEL_LCD_SPI_PARAM_BITS        (8)     // Typically set to 8
#elif ESP_PANEL_LCD_BUS_TYPE == ESP_PANEL_BUS_TYPE_QSPI
    #define ESP_PANEL_LCD_SPI_IO_CS             (5)
    #define ESP_PANEL_LCD_SPI_IO_SCK            (9)
    #define ESP_PANEL_LCD_SPI_IO_DATA0          (10)
    #define ESP_PANEL_LCD_SPI_IO_DATA1          (11)
    #define ESP_PANEL_LCD_SPI_IO_DATA2          (12)
    #define ESP_PANEL_LCD_SPI_IO_DATA3          (13)
#endif
    #define ESP_PANEL_LCD_SPI_CMD_BITS          (32)    // Typically set to 32
#elif ESP_PANEL_LCD_BUS_TYPE == ESP_PANEL_BUS_TYPE_RGB
    #define ESP_PANEL_LCD_RGB_CLK_HZ            (16 * 1000 * 1000)
    #define ESP_PANEL_LCD_RGB_HPW               (10)
    #define ESP_PANEL_LCD_RGB_HBP               (10)
    #define ESP_PANEL_LCD_RGB_HFP               (20)
    #define ESP_PANEL_LCD_RGB_VPW               (10)
    #define ESP_PANEL_LCD_RGB_VBP               (10)
    #define ESP_PANEL_LCD_RGB_VFP               (10)
    #define ESP_PANEL_LCD_RGB_PCLK_ACTIVE_NEG   (0)     // 0: rising edge, 1: falling edge
                                                        // | 8-bit RGB888 | 16-bit RGB565 |
    #define ESP_PANEL_LCD_RGB_DATA_WIDTH        (16)    // |      8       |      16       |
    #define ESP_PANEL_LCD_RGB_PIXEL_BITS        (16)    // |      24      |      16       |
    #define ESP_PANEL_LCD_RGB_BOUNCE_BUF_SIZE   (0)     // Bounce buffer size in bytes. This function is used to avoid screen drift.
                                                        // To enable the bounce buffer, set it to a non-zero value. Typically set to `ESP_PANEL_LCD_WIDTH * 10`
                                                        // The size of the Bounce Buffer must satisfy `width_of_lcd * height_of_lcd = size_of_buffer * N`,
                                                        // where N is an even number.
    #define ESP_PANEL_LCD_RGB_IO_HSYNC          (16)
    #define ESP_PANEL_LCD_RGB_IO_VSYNC          (17)
    #define ESP_PANEL_LCD_RGB_IO_DE             (18)    // -1 if not used
    #define ESP_PANEL_LCD_RGB_IO_PCLK           (21)
    #define ESP_PANEL_LCD_RGB_IO_DISP           (-1)    // -1 if not used
                                                        // | RGB565 | RGB666 | RGB888 |
    #define ESP_PANEL_LCD_RGB_IO_DATA0          (4)     // |   B0   |  B0-1  |   B0-3 |
    #define ESP_PANEL_LCD_RGB_IO_DATA1          (5)     // |   B1   |  B2    |   B4   |
    #define ESP_PANEL_LCD_RGB_IO_DATA2          (6)     // |   B2   |  B3    |   B5   |
    #define ESP_PANEL_LCD_RGB_IO_DATA3          (7)     // |   B3   |  B4    |   B6   |
    #define ESP_PANEL_LCD_RGB_IO_DATA4          (15)    // |   B4   |  B5    |   B7   |
    #define ESP_PANEL_LCD_RGB_IO_DATA5          (8)     // |   G0   |  G0    |   G0-2 |
    #define ESP_PANEL_LCD_RGB_IO_DATA6          (20)    // |   G1   |  G1    |   G3   |
    #define ESP_PANEL_LCD_RGB_IO_DATA7          (3)     // |   G2   |  G2    |   G4   |
#if ESP_PANEL_LCD_RGB_DATA_WIDTH > 8
    #define ESP_PANEL_LCD_RGB_IO_DATA8          (46)    // |   G3   |  G3    |   G5   |
    #define ESP_PANEL_LCD_RGB_IO_DATA9          (9)     // |   G4   |  G4    |   G6   |
    #define ESP_PANEL_LCD_RGB_IO_DATA10         (10)    // |   G5   |  G5    |   G7   |
    #define ESP_PANEL_LCD_RGB_IO_DATA11         (11)    // |   R0   |  R0-1  |   R0-3 |
    #define ESP_PANEL_LCD_RGB_IO_DATA12         (12)    // |   R1   |  R2    |   R4   |
    #define ESP_PANEL_LCD_RGB_IO_DATA13         (13)    // |   R2   |  R3    |   R5   |
    #define ESP_PANEL_LCD_RGB_IO_DATA14         (14)    // |   R3   |  R4    |   R6   |
    #define ESP_PANEL_LCD_RGB_IO_DATA15         (0)      // |   R4   |  R5    |   R7   |
#endif
    #define ESP_PANEL_LCD_3WIRE_SPI_IO_CS               (39)
    #define ESP_PANEL_LCD_3WIRE_SPI_IO_SCK              (48)
    #define ESP_PANEL_LCD_3WIRE_SPI_IO_SDA              (47)
    #define ESP_PANEL_LCD_3WIRE_SPI_CS_USE_EXPNADER     (0)     // 0/1
    #define ESP_PANEL_LCD_3WIRE_SPI_SCL_USE_EXPNADER    (0)     // 0/1
    #define ESP_PANEL_LCD_3WIRE_SPI_SDA_USE_EXPNADER    (0)     // 0/1
    #define ESP_PANEL_LCD_3WIRE_SPI_SCL_ACTIVE_EDGE     (0)     // 0: rising edge, 1: falling edge
    #define ESP_PANEL_LCD_FLAGS_AUTO_DEL_PANEL_IO       (0)     // Delete the panel IO instance automatically if set to 1.
        // If the 3-wire SPI pins are sharing other pins of the RGB interface to save GPIOs,
        // Please set it to 1 to release the panel IO and its pins (except CS signal).
    #define ESP_PANEL_LCD_FLAGS_MIRROR_BY_CMD           (!ESP_PANEL_LCD_FLAGS_AUTO_DEL_PANEL_IO)
        // The `mirror()` function will be implemented by LCD command if set to 1.
#endif
#elif ESP_PANEL_LCD_BUS_TYPE == ESP_PANEL_BUS_TYPE_MIPI_DSI
    #define ESP_PANEL_LCD_MIPI_DSI_LANE_NUM         (2)     // ESP32-P4 supports 1 or 2 lanes
    #define ESP_PANEL_LCD_MIPI_DSI_LANE_RATE_MBPS   (1000)  // Single lane bit rate, should consult the LCD supplier or check the
                                                            // LCD drive IC datasheet for the supported lane rate.
                                                            // ESP32-P4 supports max 1500Mbps
    #define ESP_PANEL_LCD_MIPI_DSI_PHY_LDO_ID       (3)     // -1 if not used
    #define ESP_PANEL_LCD_MIPI_DPI_CLK_MHZ          (52)
    #define ESP_PANEL_LCD_MIPI_DPI_PIXEL_BITS       (ESP_PANEL_LCD_RGB565_COLOR_BITS_16)
    #define ESP_PANEL_LCD_MIPI_DSI_HPW              (10)
    #define ESP_PANEL_LCD_MIPI_DSI_HBP              (160)
    #define ESP_PANEL_LCD_MIPI_DSI_HFP              (160)
    #define ESP_PANEL_LCD_MIPI_DSI_VPW              (1)
    #define ESP_PANEL_LCD_MIPI_DSI_VBP              (23)
    #define ESP_PANEL_LCD_MIPI_DSI_VFP              (12)
#else
#error "The function is not ready and will be implemented in the future."
#endif /* ESP_PANEL_LCD_BUS_TYPE */
 * LCD Vendor Initialization Commands.
 * Vendor specific initialization can be different between manufacturers, should consult the LCD supplier for
 * initialization sequence code. Please uncomment and change the following macro definitions. Otherwise, the LCD driver
 * will use the default initialization sequence code.
 * There are two formats for the sequence code:
 *   1. Raw data: {command, (uint8_t []){ data0, data1, ... }, data_size, delay_ms}
 *   2. Formatter: ESP_PANEL_LCD_CMD_WITH_8BIT_PARAM(delay_ms, command, { data0, data1, ... }) and
 *                ESP_PANEL_LCD_CMD_WITH_NONE_PARAM(delay_ms, command)
#define ESP_PANEL_LCD_VENDOR_INIT_CMD()                                        \
        {0xFF, (uint8_t []){0x77, 0x01, 0x00, 0x00, 0x10}, 5, 0},              \
        {0xC0, (uint8_t []){0x3B, 0x00}, 2, 0},                                \
        {0xC1, (uint8_t []){0x0D, 0x02}, 2, 0},                                \
        {0x29, (uint8_t []){0x00}, 0, 120},                                    \
        or        \
        ESP_PANEL_LCD_CMD_WITH_8BIT_PARAM(0, 0xFF, {0x77, 0x01, 0x00, 0x00, 0x10}), \
        ESP_PANEL_LCD_CMD_WITH_8BIT_PARAM(0, 0xC0, {0x3B, 0x00}),                   \
        ESP_PANEL_LCD_CMD_WITH_8BIT_PARAM(0, 0xC1, {0x0D, 0x02}),                   \
        ESP_PANEL_LCD_CMD_WITH_NONE_PARAM(120, 0x29),                               \
/* LCD Color Settings */
/* LCD color depth in bits */
#define ESP_PANEL_LCD_COLOR_BITS    (16)        // 8/16/18/24
 * LCD RGB Element Order. Choose one of the following:
 *      - 0: RGB
 *      - 1: BGR
#define ESP_PANEL_LCD_BGR_ORDER     (0)         // 0/1
#define ESP_PANEL_LCD_INEVRT_COLOR  (0)         // 0/1
/* LCD Transformation Flags */
#define ESP_PANEL_LCD_SWAP_XY       (0)         // 0/1
#define ESP_PANEL_LCD_MIRROR_X      (0)         // 0/1
#define ESP_PANEL_LCD_MIRROR_Y      (0)         // 0/1
/* LCD Other Settings */
/* Reset pin */
#define ESP_PANEL_LCD_IO_RST          (-1)      // IO num of RESET pin, set to -1 if not use
#define ESP_PANEL_LCD_RST_LEVEL       (0)       // Active level. 0: low level, 1: high level
#endif /* ESP_PANEL_USE_LCD */
//////////////////////////// Please update the following macros to configure the touch panel ///////////////////////////
/* Set to 1 when using an touch panel */
#define ESP_PANEL_USE_TOUCH         (1)         // 0/1
#if ESP_PANEL_USE_TOUCH
 * Touch controller name. Choose one of the following:
 *      - CST816S
 *      - FT5x06
 *      - GT911, GT1151
 *      - ST1633, ST7123
 *      - TT21100
 *      - XPT2046
#define ESP_PANEL_TOUCH_NAME        GT911
/* Touch resolution in pixels */
#define ESP_PANEL_TOUCH_H_RES       (ESP_PANEL_LCD_WIDTH)   // Typically set to the same value as the width of LCD
#define ESP_PANEL_TOUCH_V_RES       (ESP_PANEL_LCD_HEIGHT)  // Typically set to the same value as the height of LCD
/* Touch Panel Bus Settings */
#define ESP_PANEL_TOUCH_BUS_SKIP_INIT_HOST      (0)     // 0/1
 * Touch panel bus type. Choose one of the following:
#define ESP_PANEL_TOUCH_BUS_TYPE            (ESP_PANEL_BUS_TYPE_I2C)
/* Touch panel bus parameters */
#if ESP_PANEL_TOUCH_BUS_TYPE == ESP_PANEL_BUS_TYPE_I2C
    #define ESP_PANEL_TOUCH_BUS_HOST_ID     (0)     // Typically set to 0
    #define ESP_PANEL_TOUCH_I2C_ADDRESS     (0)     // Typically set to 0 to use the default address.
                                                    // - For touchs with only one address, set to 0
                                                    // - For touchs with multiple addresses, set to 0 or the address
                                                    //   Like GT911, there are two addresses: 0x5D(default) and 0x14
#if !ESP_PANEL_TOUCH_BUS_SKIP_INIT_HOST
    #define ESP_PANEL_TOUCH_I2C_CLK_HZ      (400 * 1000)
                                                    // Typically set to 400K
    #define ESP_PANEL_TOUCH_I2C_SCL_PULLUP  (1)     // 0/1
    #define ESP_PANEL_TOUCH_I2C_SDA_PULLUP  (1)     // 0/1
    #define ESP_PANEL_TOUCH_I2C_IO_SCL      (45)
    #define ESP_PANEL_TOUCH_I2C_IO_SDA      (19)
#endif
#elif ESP_PANEL_TOUCH_BUS_TYPE == ESP_PANEL_BUS_TYPE_SPI
    #define ESP_PANEL_TOUCH_BUS_HOST_ID         (1)     // Typically set to 1
    #define ESP_PANEL_TOUCH_SPI_IO_CS           (5)
    #define ESP_PANEL_TOUCH_SPI_IO_SCK          (7)
    #define ESP_PANEL_TOUCH_SPI_IO_MOSI         (6)
    #define ESP_PANEL_TOUCH_SPI_IO_MISO         (9)
#endif
    #define ESP_PANEL_TOUCH_SPI_CLK_HZ          (1 * 1000 * 1000)
                                                        // Should be an integer divisor of 80M, typically set to 1M
#else
#endif /* ESP_PANEL_TOUCH_BUS_TYPE */
/* Touch Transformation Flags */
#define ESP_PANEL_TOUCH_SWAP_XY         (0)         // 0/1
#define ESP_PANEL_TOUCH_MIRROR_X        (0)         // 0/1
#define ESP_PANEL_TOUCH_MIRROR_Y        (0)         // 0/1
/* Touch Other Settings */
/* Reset pin */
#define ESP_PANEL_TOUCH_IO_RST          (-1)        // IO num of RESET pin, set to -1 if not use
                                                    // For GT911, the RST pin is also used to configure the I2C address
#define ESP_PANEL_TOUCH_RST_LEVEL       (0)         // Active level. 0: low level, 1: high level
/* Interrupt pin */
#define ESP_PANEL_TOUCH_IO_INT          (-1)        // IO num of INT pin, set to -1 if not use
                                                    // For GT911, the INT pin is also used to configure the I2C address
#define ESP_PANEL_TOUCH_INT_LEVEL       (0)         // Active level. 0: low level, 1: high level
#endif /* ESP_PANEL_USE_TOUCH */
///////////////////////////// Please update the following macros to configure the backlight ////////////////////////////
#define ESP_PANEL_USE_BACKLIGHT         (1)         // 0/1
#if ESP_PANEL_USE_BACKLIGHT
/* Backlight pin */
#define ESP_PANEL_BACKLIGHT_IO          (38)        // IO num of backlight pin
#define ESP_PANEL_BACKLIGHT_ON_LEVEL    (1)         // 0: low level, 1: high level
/* Set to 1 if you want to turn off the backlight after initializing the panel; otherwise, set it to turn on */
#define ESP_PANEL_BACKLIGHT_IDLE_OFF    (0)         // 0: on, 1: off
/* Set to 1 if use PWM for brightness control */
#define ESP_PANEL_LCD_BL_USE_PWM        (1)         // 0/1
#endif /* ESP_PANEL_USE_BACKLIGHT */
///////////////////////////// Please update the following macros to configure the IO expander //////////////////////////
/* Set to 0 if not using IO Expander */
#define ESP_PANEL_USE_EXPANDER          (0)         // 0/1
#if ESP_PANEL_USE_EXPANDER
 * IO expander name. Choose one of the following:
 *      - CH422G
 *      - HT8574
 *      - TCA95xx_8bit
 *      - TCA95xx_16bit
#define ESP_PANEL_EXPANDER_NAME         TCA95xx_8bit
/* IO expander Settings */
 * If set to 1, the driver will skip to initialize the corresponding host. Users need to initialize the host in advance.
#define ESP_PANEL_EXPANDER_SKIP_INIT_HOST       (0)     // 0/1
/* IO expander parameters */
#define ESP_PANEL_EXPANDER_HOST_ID              (0)     // Typically set to 0
#define ESP_PANEL_EXPANDER_I2C_ADDRESS          (0x20)  // The actual I2C address. Even for the same model of IC,
                                                        // the I2C address may be different, and confirmation based on
                                                        // the actual hardware connection is required
#if !ESP_PANEL_EXPANDER_SKIP_INIT_HOST
    #define ESP_PANEL_EXPANDER_I2C_CLK_HZ       (400 * 1000)
    #define ESP_PANEL_EXPANDER_I2C_SCL_PULLUP   (1)     // 0/1
    #define ESP_PANEL_EXPANDER_I2C_SDA_PULLUP   (1)     // 0/1
    #define ESP_PANEL_EXPANDER_I2C_IO_SCL       (18)
    #define ESP_PANEL_EXPANDER_I2C_IO_SDA       (8)
#endif
#endif /* ESP_PANEL_USE_EXPANDER */
///////////////////////////// Please utilize the following macros to execute any additional code if required. //////////
// #define ESP_PANEL_BEGIN_START_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_EXPANDER_START_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_EXPANDER_END_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_LCD_START_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_LCD_END_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_TOUCH_START_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_TOUCH_END_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_BACKLIGHT_START_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_BACKLIGHT_END_FUNCTION( panel )
// #define ESP_PANEL_BEGIN_END_FUNCTION( panel )
/////////////////////////////////////////////// File Version ///////////////////////////////////////////////////////////
 * Do not change the following versions, they are used to check if the configurations in this file are compatible with
 * the current version of `ESP_Panel_Board_Custom.h` in the library. The detailed rules are as follows:
 *   1. If the major version is not consistent, then the configurations in this file are incompatible with the library
 *      and must be replaced with the file from the library.
 *   2. If the minor version is not consistent, this file might be missing some new configurations, which will be set to
 *      default values. It is recommended to replace it with the file from the library.
 *   3. Even if the patch version is not consistent, it will not affect normal functionality.
#define ESP_PANEL_BOARD_CUSTOM_FILE_VERSION_MAJOR 0
#define ESP_PANEL_BOARD_CUSTOM_FILE_VERSION_MINOR 3
#define ESP_PANEL_BOARD_CUSTOM_FILE_VERSION_PATCH 1
#endif /* ESP_PANEL_USE_CUSTOM_BOARD */
// *INDENT-OFF*
This is the pinout from the schematic for the Guition board. At least I understand it to be correct.
What else could be wrong?
