WConstant error using NewSoftSerial Library
Hello,
I keep getting this error and I don't know what to do. Can someone please help me? I've been trying to figure this out for days. I would really appreciate the help: WConstants.h: No such file or directory
#include "WConstants.h"
This is the code:
#include <NewSoftSerial.h>
/-----( Import needed libraries )-----/
#include <SoftwareSerial.h>
/-----( Declare Constants and Pin Numbers )-----/
#define SSerialRX 10 //Serial Receive pin
#define SSerialTX 11 //Serial Transmit pin
#define SSerialTxControl 3 //RS485 Direction control
#define RS485Transmit HIGH
#define RS485Receive LOW
#define Pin13LED 13
/-----( Declare objects )-----/
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
/-----( Declare Variables )-----/
int byteReceived;
int byteSend;
void setup() /****** SETUP: RUNS ONCE ******/
// Start the built-in serial port, probably to Serial Monitor
Serial.println("Hello World");
Serial.println("Goodnight Moon");
pinMode(Pin13LED, OUTPUT);
pinMode(SSerialTxControl, OUTPUT);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
// Start the software serial port, to another device
RS485Serial.begin(4800); // set the data rate
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
digitalWrite(Pin13LED, HIGH); // Show activity
if (Serial.available())
byteReceived = Serial.read();
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
RS485Serial.write(byteReceived); // Send byte to Remote Arduino
digitalWrite(Pin13LED, LOW); // Show activity
delay(10);
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit
if (RS485Serial.available()) //Look for data from other Arduino
byteReceived = RS485Serial.read(); // Read received byte
Serial.write(byteReceived); // Show on Serial Monitor
delay(10);
}//--(end main loop )---
/-----( Declare User-written Functions )-----/
//NONE
//( THE END )**
Starting with Arduino 1.0 (December, 2011), NewSoftSerial has replaced the old SoftwareSerial library as the officially supported software serial library. This means that if you have the IDE version 1.0 or later, you should not download this library. To port your code to 1.x, simply change all NewSoftSerial references to SoftwareSerial.
'New' is never sensible to put in a name for a module, everything ends up being legacy some day.
MarkT:
Except for Ian Dury's "New Boots and Panties", which has never been surpassed. 8)
