I'm having weird characters on my LCD Display that I wanted to use for debugging LDR Values. Here's what it looks like in Serial Monitor:
[left]ldr_value [0-???]:
110
ldr_adjusted [0-1023]:
321
ldr:
40
light_level:
15[/left]
Here's a picture of what it looks like on the LCD:
And this is the code I'm using:
#include <FastLED.h>
#include <RCSwitch.h>
// Adafruits RTClib from https://github.com/adafruit/RTClib
#include <Wire.h>
#include "RTClib.h"
LiquidCrystal_I2C lcd(0x3F, 16, 2);
RTC_DS3231 RTC;
RCSwitch mySwitch = RCSwitch(); // send wireless Data
String inString = "";
DateTime now;
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
#define NUM_LEDS 60
#define LED_TYPE WS2812B
#define DATA_PIN 6
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
// Filter averaging factor - higher value means more sluggish response to changes in ambient brightness
#define FILTER_LEN 8
// Brightness level initial value
int level=15;
// Brightness correction for Leds
unsigned char bright[] = {0, 2, 4, 7, 11, 18, 30, 40, 50, 65, 80, 96, 125, 160, 200, 255};
mySwitch.enableTransmit(10); // Der Sender wird an Pin 10 angeschlossen
// init RTClib
Wire.begin();
RTC.begin();
// Following line sets the RTC to the date & time this sketch was compiled
// every time I upload to the arduino, it resets this time. After initial
// setup, this line needs to be removed.
//RTC.adjust(DateTime(__DATE__, __TIME__)); last: 8:24
// LCD Display
lcd.init(); //Im Setup wird der LCD gestartet
lcd.backlight();
// Setup FastLED Lib
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds,NUM_LEDS).setCorrection(TypicalLEDStrip);
// setup measurement for LDR
digitalWrite(A0, HIGH); // set pullup on analog pin 0
pinMode(A1, OUTPUT);
digitalWrite(A1, LOW);
Serial.begin(57600); //was 57600
unsigned int ldr=0;
void doLDR() {
unsigned int ldr_value = analogRead(0); //reads the LDR values
//Adjust for LDR variations.
//dark = 1023
//light = 0
//If your LDR for example reaches a max analogRead value of 350 instead of 1023 for 100% dark.
unsigned int ldr_adjusted=map(ldr_value,0,350,0,1023); //was map(ldr_value,0,700,0,1023);
//the level for the original LDR by Freenove
// was 400
//set max limit (to avoid potential 'divide-by-zero's).
if (ldr_adjusted >= 1023) ldr_adjusted = 1023; //was 1023
//ldr follows ldr_adjusted, but is averaged so that values only change gradually
ldr = ((unsigned long)(FILTER_LEN-1)*ldr+ldr_adjusted)/FILTER_LEN;
unsigned int light_level=15; // was 15
//translate [0-1023] to [15-0]
//light_level = (1024-ldr)>>6;
light_level=map(ldr,0,1023,15,0);
if (light_level >= 15) light_level = 15; // was (light_level >= 15)
if (light_level <= 1) light_level = 1;
//DEBUG SPI
Serial.println("ldr_value [0-???]:");
Serial.println(ldr_value);
Serial.println("ldr_adjusted [0-1023]:");
Serial.println(ldr_adjusted);
Serial.println("ldr:");
Serial.println(ldr);
Serial.println("light_level:");
Serial.println(light_level);
//DEBUG LCD-LDR BEGINN
lcd.setCursor(0, 0);
lcd.print(ldr_value);
lcd.println(" ");
lcd.println(ldr_adjusted);
// lcd.println("LDR:");
// lcd.println(ldr);
// lcd.println(" ");
// lcd.println(light_level);
//DEBUG LCD-LDR END
//level=2;
level = light_level;
DateTime old;
// get time
DateTime now = RTC.now();
/* // Begin LCD Time
lcd.setCursor(0, 1);
lcd.print(now.hour());
lcd.print(":");
lcd.print(now.minute());
lcd.print(" ");
// lcd.print(now.second());
lcd.print(now.day());
lcd.print('.');
lcd.print(now.month());
lcd.print('.');
lcd.print(now.year());
// lcd.print(" Uhr");
// END LCD
// send serial Data
if (mySwitch.available()) {
int value = mySwitch.getReceivedValue();
if (value == 0) {
Serial.println("Unknown encoding");
Serial.println( mySwitch.getReceivedValue() );
mySwitch.resetAvailable();
// Read serial input:
while (Serial.available() > 0) {
int inChar = Serial.read();
if (isDigit(inChar)) {
inString += (char)inChar;
if (inChar == '#') {
long code = inString.toInt();
mySwitch.send(code, 24);
Serial.println(code);
inString = "";
// send serial Data
// DEBUG RTC
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
if (now.second()!=old.second()) {
old = now;
doLDR();
// clear LED array
memset(leds, 0, NUM_LEDS * 3);
if(level == 1){
// this is the night mode
// set LED background
for (int i=0; i<NUM_LEDS; i++) {
leds[i].r = bright[level];
leds[i].g = (bright[level]+1)/2;
leds[i].b = 0;
leds[((59+hourpos)%60)%60].g = bright[level/2];
leds[(hourpos)%60].g = bright[level];
leds[((hourpos+1))%60].g = bright[level/2];
// update LEDs
//FastLED.setBrightness(100);
FastLED.show();
FastLED.delay(500);
// wait some time
//delay(500);
How can they be removed? I can't fit everything on the display, these are stealing my lcd real estate
