Hello everyone. I have 2 motors 500W , 24V (Max Current: 26A) each. These are my motors
So, my question is what battery/batteries should I choose so that I can move these 2 motors?
I found these 2 batteries on Amazon,but I don't know if it's suitable for my motors.
Any ideas , suggestions or links?
Rule of thumb apparently for lead acid batteries max. discharge current is the same number as the capacity rating of the battery. For this one that's 10Ah, so rule of thumb would be 10A current draw max, which is far less than a single one of your motors. To make matters worse, the datasheet specifies the actual capacity at a constant current draw of 6A as only 6Ah (so 60% of its nominal capacity); go figure how little is left if you discharge almost ten times as fast. Best case scenario is that the battery won't last long between charges and will have a short service life. Worst case scenario is rather more explosive.
Nope.I have used these kind of robots in the past.Now I want to experience big robots using stronger motors like I reference ,sensors like ultrasonic ,GPS etc.
My problem is that I don't know what batteries should I choose to drive these motors(500W 24V)
Any links would be appreciated (I don't want very expensive batteries)
How can anyone recommend a battery if they dont know how much power it needs to deliver (in current), for how long and of course what are the weight limits, how big\heavy is the robot etc.
Hello again guys.After a lot of search on internet I found this battery
Is it a good choice so that I can run my 2 motors (normal and high speed)?or may I have to search a little bit more?
