I have two portable "installations" of the Arduino-IDE on my laptop
Arduino 1.8.13 and 1.8.16
the 1.8.16 shows an error-message
error downloading https://downloads.arduino.cc/library_index.json
thank you J-M-L the correct URL is
https://downloads.arduino.cc/**libraries**/library_index.json
while the 1.8.13-version can download it.
I'm not aware of having changed something in my 1.8.16-version.
what can cause this error ? What do I have to check to fix it?
best regards Stefan
J-M-L
November 21, 2021, 12:36pm
2
the file linked ( https://downloads.arduino.cc/library_index.json ) contains this
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>File Not Found</title>
</head>
<body>
<pre>
_ _ _ _ _
| | | | | | | | (_)
__| | _____ ___ __ | | ___ __ _ __| |___ __ _ _ __ __| |_ _ _ _ __ ___ ___ ___
/ _` |/ _ \ \ /\ / | '_ \| |/ _ \ / _` |/ _` / __| / _` | '__/ _` | | | | | '_ \ / _ \ / __/ __|
| (_| | (_) \ V V /| | | | | (_) | (_| | (_| \__ \_ | (_| | | | (_| | |_| | | | | | (_) | | (_| (__
\__,_|\___/ \_/\_/ |_| |_|_|\___/ \__,_|\__,_|___(_) \__,_|_| \__,_|\__,_|_|_| |_|\___/ (_\___\___|
</pre>
</body>
</html>
it does not look like JSON at all... (or there is some smart redirect when not accessed from the IDE)
fascinating! (as Mr. Spock would say)
But why the heck does it work with my Arduino 1.8.13-portable and a freshly installed Arduino 1.8.16-portable version?
I mean in the 1.8.13-portable and the new 1.8.16-portable I click on manage libraries and downloading works?!
best regards Stefan
J-M-L
November 21, 2021, 12:41pm
4
there might be some wizardry done on the HTTP side and some smart redirect when not accessed from the IDE.
if you have a way to inspect traffic, then look at what the IDE is really doing
J-M-L
November 21, 2021, 12:42pm
5
BTW, was already discussed in the past (but no clear solution)
I keep getting this error, any thoughts how to fix it?
Error downloading https://downloads.arduino.cc/libraries/library_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/…
J-M-L
November 21, 2021, 12:44pm
6
@J-M-L thank you for pointing out that.
My fault of wrong re-typing the path in my initial posting here is a screenshot
which I should have posted immetiately.
As you can see the URL is correct. Anyway with my old 1.8.16-portable version I get this error
best regards Stefan
I'm trying to narrow down the problem through copying the subfolders from the old 1.8.16-portable to the new 1.8.16-portable
After copying all subfolders of "portable" the new installed 1.8.16-portable can still donwload this library_index.json.
though the boards are not all there.
I guess I have to run the board-manager again?
Or do I have to copy some other folders which are above the "portable"-folder??
best regards Stefan
J-M-L
November 21, 2021, 1:00pm
9
I'm not a windows user... Might be permissions issues or the like.
StefanL38:
1.8.13 and 1.8.16
Hi
What links are there in your IDE at:
Files --->> Preferences --->> Additional Boards Manager URLs:
in both IDEs ( 1.8.13 and 1.8.16)?
RV - mineirin
They are the same
13: https://dl.espressif.com/dl/package_esp32_index.json , http://arduino.esp8266.com/stable/package_esp8266com_index.json , https://files.seeedstudio.com/arduino/package_seeeduino_boards_index.json
16: https://dl.espressif.com/dl/package_esp32_index.json , http://arduino.esp8266.com/stable/package_esp8266com_index.json , https://files.seeedstudio.com/arduino/package_seeeduino_boards_index.json
Well after copying all the package_seeeduino_boards_index.json package-index.json-files
ESPs and Seeduino XIAO works again. Only Teensy does not appear.
What is not yet working is the color of the opened tabs
Where can I adjust the color of the tabs at the top of the IDE-window?
This is a completely different problem than the initial problem I started the thread with.
So here is a link to this tab-text-color-problem-thread
Hello everybody,
first of all: @ the whole Arduino-Developper-Team:
a big
thank you
for your work. Most of it is really good.
It turned out to be a windows-"BUG". Slap my hand to the forehead.
Windows was re-arranging my desktop-shortcuts and this made me click on the wrong shortcut (of the old Arduino 1.8.16-portable. This means I was starting an IDE where I did NOT change the theme.txt / and the default.xml-file.
As a consequence I will change the Icon-Picture and the text of the old ver…
best regards Stefan
system
Closed
May 20, 2022, 2:01pm
12
