Hello, I am looking to make an automatic fume extractor fan, but looking for a sensor that can pick up the heat from the solder tip from around 1-2ft would an IR sensor do this? I looked into a flame sensor but that seems to work with just flame, not other hot items.
Consider thermal sensors, like the MLX90614, or the Grid Eye thermal imager.
thanks ordered a MXL to try out!
Hi CoffeeOutlaw
Alternately, consider a current sensor in the mains lead supplying the soldering iron, could easily be built into a plug socket (at least for UK sockets), and if it was a twin socket you could have the extractor fan plugged into the second socket controlled by a solid state relay.
Just a thought .. .
Best Regards
picclock
