i have wheastone bridge having one strain gauge and three resistors, the strain gauge attached to beam fixed from both ends and force applied at middle of beam , i have made circuit and tested it , work good , now i want to connect this circuit with hx711 module
so that i can read stress , strain in beam from arduino , please guide me how can i connect the circuit to hx711
i wrote a code to read voltage from strain gauge and display on serial monitor but its not working
#include "HX711.h"
HX711 scale;
const int loadCellDoutPin = 2; // Data Out pin (DO)
const int loadCellSckPin = 3; // Clock pin (CLK)
float vRef = 4; // External voltage reference 2.5V to Aref pin
float ampGain = 128.0; // Amplifier gain for HX711
float offset = 0.0; // Initial offset of Wheatstone bridge, if any.
Serial.begin(115200); // Begin serial transmission at 115200 bps.
scale.begin(loadCellDoutPin, loadCellSckPin);
scale.set_scale(); // Initialize scale factor, calibration_factor can be used if needed.
pinMode(A0, INPUT); // Set unused analog pin in input mode.
establishContact(); // Call the function that loops itself till it gets a response from the computer.
if (Serial.available() > 0) {
char inByte = Serial.read(); // Store the data sent from the computer
long rawReading = scale.get_units(10); // Get a weight reading in raw units
// Convert raw ADC output (0 - 8388607 for HX711) to voltage (0 - 2.5)
float sgVoltage = (rawReading / 8388607.0) * vRef / ampGain - offset;
// Write values separated with a comma
Serial.print(vRef);
Serial.print(",");
Serial.println(sgVoltage); // Adds a return ("\n") at the end
Serial.flush(); // Wait till serial transmission is complete
void establishContact() {
while (Serial.available() <= 0) { // Till serial becomes available with a response from the computer
Serial.println("A"); // Send an initial ASCII value.
delay(100);
from randomn nerd tutorials, I believe this sample code from the library
Use this code to get calibration value
// Calibrating the load cell
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 2;
const int LOADCELL_SCK_PIN = 3;
HX711 scale;
Serial.begin(57600);
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
if (scale.is_ready()) {
scale.set_scale();
Serial.println("Tare... remove any weights from the scale.");
delay(5000);
scale.tare();
Serial.println("Tare done...");
Serial.print("Place a known weight on the scale...");
delay(5000);
long reading = scale.get_units(10);
Serial.print("Result: ");
Serial.println(reading);
else {
Serial.println("HX711 not found.");
//calibration factor will be the (reading)/(known weight)
calibration factor = (reading)/(known weight)
after you get calibration value use this code
* MIT License
* (c) 2018 Bogdan Necula
#include <Arduino.h>
#include "HX711.h"
HX711 scale;
Serial.println("HX711 Demo");
Serial.println("Initializing the scale");
Serial.println("Before setting up the scale:");
Serial.print("read: \t\t");
Serial.println(scale.read()); // print a raw reading from the ADC
Serial.print("read average: \t\t");
Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("get value: \t\t");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print("get units: \t\t");
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
scale.set_scale(-459.542);
//scale.set_scale(-471.497); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.println("After setting up the scale:");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
// by the SCALE parameter set with set_scale
Serial.println("Readings:");
Serial.print("one reading:\t");
Serial.print(scale.get_units(), 1);
Serial.print("\t| average:\t");
Serial.println(scale.get_units(10), 5);
delay(5000);
