When I enter a digit on the project keyboard, it is overwritten and does not break the line to be displayed on the screen
Good morning, I'm having a problem with my Arduino project because
the code doesn't do what's shown in the video
I took it from, even though it's the same code and the same project with the same components.
The video I took the project from is
in Spanish, but you can find it in English.
El código es el siguiente:
/*Thanks. Remember to visit my Youtube channel
I've used a i2c LCD screen module and 9g servo motor.
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,20,4);
#include <Servo.h>
#include <Keypad.h>
//Variables
int mot_min = 90; //min servo angle (set yours)
int mot_max = 180; //Max servo angle (set yours)
int character = 0;
int activated =0;
char Str[16] = {' ', ' ', ' ', ' ', ' ', ' ', '-', '', '', '*', ' ', ' ', ' ', ' ', ' ', ' '};
//Pins
Servo myservo;
int buzzer=11; //pin for the buzzer beep
int external = 12; //pin to inside open
int internal = 13; //pin to inside close
//Keypad config
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','4','7','*'},
{'2','5','8','0'},
{'3','6','9','#'},
{'A','B','C','D'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
myservo.attach(10); //attach the servo to pin D10
pinMode(buzzer,OUTPUT);
pinMode(external,INPUT);
pinMode(internal,INPUT);
//Init the screen and print the first text
lcd.init();
lcd.backlight();
lcd.clear();
lcd.print(" PASSWORD");
lcd.setCursor(0,1);
lcd.print(" -*** ");
//put the servo in the close position first
myservo.write(mot_min);
void loop(){
///////////////EMERGENCY OPEN/CLOSE/////////
if (digitalRead(external))
myservo.write(mot_max);
lcd.clear();
lcd.setCursor(2,0);
lcd.print("INSIDE OPEN");
activated = 2;
analogWrite(buzzer,240);
delay(250);
analogWrite(buzzer,200);
delay(250);
analogWrite(buzzer,180);
delay(250);
analogWrite(buzzer,250);
delay(250);
analogWrite(buzzer,LOW);
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print("WELLCOME");
  lcd.setCursor(2,1);
  lcd.print("ELECTRONOOBS");
  lcd.clear();
  lcd.setCursor(3,0);
  lcd.print("DOOR  OPEN");
  lcd.setCursor(2,1);
if (digitalRead(internal))
activated = 0;
character=0;
Str[6]= '-';
Str[7]= '';
Str[8]= '
Str[9]= '*';
Str[10]= ' ';
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
///////////////KEYPAD OPEN/CLOSE////////////
char customKey = customKeypad.getKey(); //this function reads the presed key
if (customKey){
if (character ==0)
Serial.println(customKey);
Str[6]= customKey;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
if (character ==1)
Str[7]= customKey;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
if (character ==2)
Str[8]= customKey;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
if (character ==3)
Str[9]= customKey;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
if (character ==4)
Str[10]= customKey;
activated=1;
character=character+1;
if (activated == 1)
/Change your password below!!!
Change each of Str[6], Str[7], Str[8], Str[9]
if(Str[10]='A' && character==5 && Str[6]=='3' && Str[7]=='0' && Str[8]=='0' && Str[9]=='7' )
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print("ACCEPTED");
  activated = 2;
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.setCursor(2,1);
  lcd.clear();
  lcd.setCursor(3,0);
  lcd.setCursor(2,1);
  lcd.clear();
  lcd.setCursor(1,0);
  lcd.print("PASSWORD ERROR");
  lcd.setCursor(3,1);
  lcd.print("TRY  AGAIN");
  analogWrite(buzzer,150);
  delay(3000);
  character=0;
  Str[6]= '-';
  Str[7]= '*';
  Str[8]= '*';
  Str[9]= '*';
  Str[10]= ' ';
  activated = 0;
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print("PASSWORD");
  lcd.setCursor(0,1);
  lcd.print(Str);
if (activated == 2)
if(customKey == 'B' )
activated = 0;
character=0;
Str[6]= '-';
Str[7]= '';
Str[8]= '
Str[9]= '*';
Str[10]= ' ';
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(Str);
This is the schematic of the project in Arduino.
When I run the code to make the project functional and display the password screen so that the password can be entered on the Mitral keyboard, below the password there are asterisks that hide the characters and cover the password. I want to know why when I enter the password it is overwritten in the same position without making a line break to enter the second digit of the password, and even if I press enter, it does not allow me to enter at least an incorrect password.
  • Using delay(. . .) like this will completely make things unresponsive.
  • Study millis( ) based TIMERs and State Machine programming.
  • Never connect inductive loads (ex: servos) to the Arduino 5v pin.
Please correct your post and add code tags around your code.
There is a small pencil image below your existing posts.
  • click on this pencil ➜ that will let you edit your post.
  • Select the part of the text that corresponds to the code
  • Click on the <code/> icon in the toolbar to indicate that it is code
  • click image Save Edit
(Also make sure to properly indent the code in the IDE before copying and pasting it here. This can be done by pressing ctrlT on a PC or cmdT on a Mac)
No thank You. You use Your time and provide a direct link!
welcome to the arduino-forum.
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
best regards Stefan
