Where is "Arduino as ISP" for ATMega328?
It's been a while (and several IDE updates) since I programmed an ATMega328. I have IDE 2.2.1 and 1.8.13 and neither one has the old option of "Arduino as ISP for programming the ATMega328. I'm using an UNO with an AVR ISP Shield. I recently programmed a Tiny84 with this setup but it did have the "Arduino as ISP" option. I can't seem to find a "modern" set of instructions for doing this on the 328 so any help will be appreciated. The chips are 328P with no bootloader.
That I am aware of, there was never an IDE option of that name. Maybe one was introduced by a boards platform, sketch, or library you had installed. But it doesn't really make sense to have such specificity. The Arduino as ISP programmer can be used to program any of the classic AVR microcontrollers so there would not be a need or reason to have a version specifically for the ATmega328.
The procedure will be equivalent for the ATmega328P as for the ATtiny84.
There is an official tutorial for the Arduino as ISP here:
https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP
Maybe a bit higher quality instructions here:
You will need an "ISP programmer" in order to perform a "Burn Bootloader" operation. An ISP programmer is a piece of hardware that allows your computer to write directly to the flash memory of the primary microcontroller on the Arduino board.
If you don't have an ISP programmer, you can use a spare Arduino board as a DIY programmer (known as an "Arduino as ISP"). I'll provide instructions you can follow to do that:
Burning Bootloader with "Arduino as ISP" Programmer
A. Prepare "Arduino as ISP" programmer
Although the "Arduino as ISP" only works for programming targets of the AVR architecture, you can use some boards of other architectures (e.g., "AVR", "SAMD", "megaAVR") as an "Arduino as ISP" programmer.
I will refer to the board which will used as an "Arduino as ISP" as the "programmer board" from here on. The board you are burning the bootloader to will be referred to as the "target board".
  1. Disconnect the USB cable of the Arduino boards from your computer.
  2. Make the following connections between the pins on the "programmer board" and the "target board".
    Programmer Target
    CIPO (AKA "MISO") CIPO
    VCC 5V (VCC on 3.3 V boards)
    SCK SCK
    COPI (AKA "MOSI") COPI
    10 RESET
    GND GND
    The documentation for the boards you are using will identify the location of these pins. If you are using an official Arduino board, check the pinout diagram on the documentation page for the board.
  3. Connect the "programmer board" to your computer with a USB cable.
  4. Select File > Examples > 11.ArduinoISP > Arduino ISP from the Arduino IDE menus.
  5. Select your "programmer board" from Arduino IDE's Tools > Board menu.
  6. Select the port of your "programmer board" from Arduino IDE's Tools > Port menu.
  7. Select Sketch > Upload from the Arduino IDE menus.
  8. Wait for the upload to finish.
You are now ready to burn the bootloader using your "Arduino as ISP" programmer.
B. Burn Bootloader
Instructions for burning the bootloader:
It is not possible to do this via "Arduino Web Editor". You will need to use Arduino IDE or Arduino CLI.
  1. Select the "target board" from the Tools > Board menu, and any other custom Tools menus (e.g., Tools > Processor).
  2. Select the appropriate programmer from the Tools > Programmer menu in Arduino IDE.
    This is dependent on which board you are using as the "programmer board":
    • If it is an ATmega32U4-based board (e.g., Leonardo, Micro, Pro Micro): Select "Arduino as ISP (ATmega32U4)" from the menu.
    • If it is not an ATmega32U4-based board: Select "Arduino as ISP" from the menu.
  3. Select Tools > Burn Bootloader from the Arduino IDE menus.
  4. Wait for the process to finish successfully.
  5. Disconnect the USB cable of the "programmer board" from your computer.
  6. Disconnect the "programmer board" from the "target board".
Tools/Programmer but select an AVR board first.
Regards
I guess I didn't make myself clear. Here is the setup I used in older version of the IDE:
ATMega328 Board Settings in Arduino IDE
I'm programming a bare chip, not a board. The only option I see to select the ATMega328 is one with the Minicore. I need the option that lets me select the bare chip with no bootloader, just like I do for the Tiny84 and Tiny85 chips.
You can do the very same in the new IDE.
Use that one.
If you haven't already, install MiniCore by following the instructions in the documentation:
https://github.com/MCUdude/MiniCore#boards-manager-installation
After that, select Tools > Board > MiniCore > ATmega328 from the Arduino IDE menus.
The Tools > Bootloader menu will appear after you select a MiniCore board from the Tools > Board menu.
That just brings me back to my original issue: No option for "Use Arduino as ISP" in the programmer selection. I did figure out that if I use my 1.8.13 IDE that it still has an option for "no bootloader" and doesn't automatically select a minicore programmer. If I leave the programmer unchecked then I can upload to my chip. I still have to "Burn Bootloader" every time before uploading but all it appears to do is to set the fuses for the settings I've selected (e.g.: clock source). I haven't tried uploading using my 2.2.1 IDE yet because of the forced programmer selection and the lack of a "no bootloader" selection.
EDIT: I tried 2.2.1 and did find that it has the "no bootloader" option but it does not work to program the ATMega328 because it forces a selection of one of the four programmers that I don't have.
Temp
I use the official IDE 1.8.19, which has two options for "Use Arduino is ISP" (one option for using the 32U4).
I installed 1.8.19 and it does not show that programmer option for the bare ATMega328 chip.
Might be in one of the board packages. I did not do anything specific to acquire or enable those two options. Try setting "Arduino Uno" as the target processor.
Yes, I know that option shows up if I select other boards or even the Tiny processor chips but that doesn't help me with the 328.
Why not?
Because that programmer option does NOT show up when I select the ATMega328 stand alone chip. Apparently if I do not select any programmer, then it must default to looking for an Arduino surrogate programmer. That is not the case in IDE 2.2.1. There it automatically selects one of the four programmers in the list, none of which I have.
Select the Uno and Arduino as ISP instead, and program your ATmega328.
If you're willing to use arduino-cli, this should do the trick and match the options you had selected:
arduino-cli -tv upload -b MiniCore:avr:328:BOD=2v7,bootloader=no_bootloader,clock=8MHz_internal,LTO=Os,variant=modelP -i <sketch.hex> -P arduinoasisp -p /dev/ttyACM0
Untested, so no 100% guarantee that I don't have a minor syntax error or two in there.
What happens if you don't do a "Burn Bootloader" before uploading? It definitely should not be necessary.
That is correct. This is why you must do a "Burn Bootloader" operation once with a fresh chip, and again after changing relevant settings (e.g., the Tools > Clock menu) in Arduino IDE, even when you aren't actually using a bootloader. But there is no reason you should have to do a "Burn Bootloader" more often than that.
Thanks for the clarification. I understand the problem now.
Older versions of Arduino IDE made all the programmers of all platforms available from the Tools > Programmer menu. Since the "Arduino AVR Boards" platform contained an "Arduino as ISP" definition, there was no need for MiniCore to also contain a definition for that programmer. Starting from Arduino IDE 1.8.13, Arduino IDE was changed to only show the programmers from the platform of the currently selected board.
After that change, all the necessary programmers were added to MiniCore:
But you are using an outdated version of MiniCore from before that was done.
So the problem will be solved by updating your installation of MiniCore. I'll provide instructions you can follow to do that:
  1. Click the following link to open the platform's installation instructions in your web browser:
  2. Copy the "Boards Manager URL" that is provided in those instructions.
  3. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  4. Check to see whether the URL you copied from the platform's installation instructions is already present in the "Additional Boards Manager URLs" field of the "Preferences" dialog.
  5. If the URL is not present, add it to the "Additional Boards Manager URLs" field.
    If there are other URLs in the field, separate them with commas (,).
  6. Click the "OK" button on the "Preferences" dialog.
  7. You will now see a "Downloading index: ..." notification at the bottom right corner of the IDE window. Wait for that notification to close.
  8. Select Tools > Board > Boards Manager from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  9. Scroll down through the list of boards platforms until you see the "MiniCore" entry.
  10. Click the "UPDATE" button at the bottom of the entry.
  11. Wait for the update to finish.
After that, you should see
I updated Minicore to version 3.0 but the problem remains. Only the four programmer options shown in my previous post are listed. Yes, the "burn bootloader" is required each time, not just on an unprogrammed chip. Otherwise the upload does not work. I have a note about that from the last time I programmed an ATMega328.
I believe the reason is a bug in Arduino IDE 2.x that causes the Tools > Programmer menu to not be updated. I'll provide instructions you can follow to force the IDE to update the menu:
  1. Select File > Quit (or Arduino > Quit Arduino for macOS users) from the Arduino IDE menus if it is running.
  2. Delete the following folder to force Arduino IDE to update the Tools > Programmer menu data:
    • Windows:
      C:\Users\<username>\AppData\Roaming\arduino-ide\
      (where <username> is your Windows username)
      :red_exclamation_mark: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
    • Linux:
      /home/<username>/.config/arduino-ide/
      (where <username> is your Linux username)
      :red_exclamation_mark: The .config folder may be hidden by default in your file manager and terminal.
    • macOS:
      /Users/<username>/Library/Application Support/arduino-ide/
      (where <username> is your macOS username)
      :red_exclamation_mark: The Library folder is hidden by default. You can make it visible by pressing the Command+Shift+. keyboard shortcut.
    :warning: Please be very careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
You should now see the expected list of programmers under the Tools > Programmer menu.
Please let me know if you have any questions or problems while following those instructions.
I did as you directed and got some good news and some really bad news. First, I have noticed that there are two options in the board selection of IDE 2.2.1 for the ATMega328 (see picture). If I select the first option, I get the same results as before - just the four programmer choices. If I select the second option I finally get the full list of programmer choices. That's the good news. The really bad news is that now the IDE no longer works with my ArduinoISP programmer (see second picture). Unfortunately, that is now also the case for IDE 1.8.19 which had been working for me so I am now completely without any method to program my chips. My Arduino UNO ISP is programmed with the IDE Example software for using an Arduino as an ISP. Is there some other version I should load instead?
It might happen if you manually installed MiniCore. If so, you will see both a "MiniCore" and a "MiniCore (in Sketchbook)" item in the Tools > Port menu.
The alternative "Select Other Board and Port" user interface you are using to select the board doesn't currently indicate when a board comes from a manually installed platform. For this reason I recommend you to use the Tools > Board and Tools > Port menus instead as long as you have this confusing environment of a double installation of the platform on your system.
There is work in progress to add an indication of the board coming from a manually installed platform to the "Select Other Board and Port" dialog: https://github.com/arduino/arduino-ide/pull/2281
I'm going to ask you to post the full verbose output from a "Burn Bootloader" operation.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
  2. Check the box next to Show verbose output during: ☐ upload in the "Preferences" dialog.
    This preference applies to "Burn Bootloader" operations in addition to uploads.
  3. Click the "OK" button.
  4. Attempt a "Burn Bootloader" operation, just the same as you did before.
  5. Wait for the "Burn Bootloader" operation to fail.
  6. You will see a "Error while burning the bootloader: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button in that notification.
  7. Open a forum reply here by clicking the "Reply" button.
  8. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  9. Press Ctrl+V (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  10. Move the cursor outside of the code tags before you add any additional text to your reply.
  11. Click the "Reply" button to post the output.
