Hello,
i want to driving some hdd motors on a wall - and slowly.
Actually i using 12 A ESC from SimonK but i didn‘t get it slow enough.
Some disks have 4 wire pins and i only using 3 wire esc, so maybe it would driving better with 4 wires.
Anybody knows which esc is the best or what should i do, to driving hdds slowly?
I already looking for 4 wire esc but i think 30A is too much.
You can't drive motors arbitrarilt slowly with standard ESCs, they rely on back EMF for commutation and slow
speed means the back EMF signal fades into the switching noise.
Since HDD motors are usually 4-wire Y connected, it might be simpler to drive them unipolar, as if a 3-phase
stepper. 3 channels from an ULN2003 or ULN2803 might be suitable if the current isn't too great.
Webfeger:
Hello,
Yes, I can imagine, ESCs for sensorless brushless motors cannot go slowly!
Regards, Webfeger
4-wire is easy, just use 3 channels from a driver such as a ULN2803, the common wire goes to V+.
Sequence 100, 010, 001, or for more slowly, 110, 010, 011, 001, 101, 100
You should measure the winding resistance and check what current level is involved and ensure any
driver you use can handle that current comfortably.
Note the ULN2803/ULN2003 are good choices as they have free-wheel diodes built in which are required
always when driving motors and other inductive loads. Other more modern MOSFET based drivers
are available, remember to ensure there are free-wheel diodes.
