But the Problem is: the SMD-Type resistors heights are like paper. I thought these SMD-Resistors are solid and hight enough in order to solder them properly. But they are like paper. My question is:
which ones have a solid dimension to solder them properly ?
It is apparent you have no experience with SMD technology. Those resistors are some of the mid size ones. Be glad you did not get something in the 0402 range they are a lot smaller.
For soldering them I use either a reflow oven or a hot air gun designed for this. I sometimes use my iron with an appropriate sized tip. There are some interesting tutorials/videos on hot air and reflow soldering watching them will help.
If you want SMD resistors big enough to hand-solder, you may try using the 2512 1W size, but I doubt it will save you any money. The 2020 1/2W resistors are another option.
I solder 1206 types with ease using a pair of tweezers and a bit of solder paste and a soldering iron, (and a magnifying glass) can't quite see which size these ones you bought are.
None of them, because SMD is not designed for hand soldering.
However, the largest size 1206 is quite easy to solder by hand with some magnification and a little practice. The most useful tool I have found is a 10x binocular microscope, and I now can do 0603 but I still generally go for 0805.
I was going to suggest 0805 (easy to hand solder under a 3x magnification glass), but then I saw you have bigger size already. Those are easy to hand solder - provided you have a decent soldering iron with small tip. Of course you're expected to solder them on a PCB, not attach leads to them or so.
I've once done 0402 by hand. The 8x microscope was pretty essential to see what I was doing. Very fiddly.
