Can you please help me, I did all those points still, there is only a white screen, nothing comes up after that. use your same code. Made all the changes as you have mentioned
which host microcontroller and display are you using? if possible give links to web pages
is anything else connected, e.g. sensors, relays, etc
which program are you using?
what is the Serial output?
I am trying to use LovyanGFX with the same setup, the pin configurations are as mentioned- MOSI- PIN11, MISO-PIN 12, LED- 3.3V, SCK-PIN 10, CS- PIN 4, DC-PIN 15, RESET- PIN9, VCC-3.3V,GND-GND. now here is the serial output- Text 11890
Pixels 303599
Lines 345496
Horiz/Vert Lines 13119
Rectangles (outline) 8606
Rectangles (filled) 328Benchmark Time (microseconds)
HaD pushColor 524606
Screen fill 31720
Text 11847
Pixels 303595
Lines 345477
Horiz/Vert Lines 13107
Rectangles (outline) 8575
Rectangles (filled) 328825
Circles (filled) 46258
Circles (outline) 30449
Triangles (outline) 20136
Triangles (filled) 114555
Rounded rects (outline) 14930
Rounded rects (filled) 332397
Done!
No, the IDE has nothing to do with it. Lot's of people have trouble with this device, it is complex.
You have to post ALL the code, including h files, in code tags. I don't chase links. You also have to make a hand-drawn wiring diagram, then take a picture or pictures of it that the other old guys and I can see. Until you do the help you get will be very slow, if at all.
Try using the library pictured and the sample graphicstest
My ESP32-s3 board's 3.3v pins are giving readings like 3.8 or 3.7 is it causing the problem? the 5 v reading in multimeter is coming as 4.8/4.7 which is good i think. i am plugging this via USB only. Kindly reply
