I have tried the many solutions posted without success.
The flash screen gets as far as 'starting'
Using arduino_debug I get this, see attached.
looks like some sort of loop that runs for about a second and then both debug and flash screen go away.
Any help would be appreciated.
tried various IDE's currently with 1.8.3 as this was proposed as a solution if 1.8.5 did not work.
Why in the world would you take a picture of text on your screen and then post that to the forum as a .pdf attachment? That's just wrong in so many ways! Post the complete text as text right here in a reply using code tags (</> button on the toolbar).
Winch:
That makes me think you didn't run arduino_debug from the command line.
Looking for library 'user32'
Adding paths from jna.library.path: null
Trying user32.dll
Found library 'user32' at user32.dll
DPI detection failed, fallback to 96 dpi
Looking for library 'shell32'
Trying shell32.dll
Found library 'shell32' at shell32.dll
Looking for library 'Ole32'
Trying Ole32.dll
Found library 'Ole32' at Ole32.dll
Loading configuration...
Initialising packages...
Preparing boards...
Starting...
It stalls there without any more code.
If I run the debug directly, after about a minute I get about a seconds worth of the code I sent as a picture, ( as the debug screen then disappears I could not think of any other way of recording it although I am sure there is a clever way of doing it).
This may of course not be connected with the problem and hopefully I just need to change some settings. I have an old IDE on another machine working with XP and just loaded 1.8.5 on a desktop with Win10 with no problem but would like it on my Win7 laptop.
Thanks.
That's very strange that you get different results from running arduino_debug.exe from the command line.
Winch's screenshot:
This is purely grasping at straws, but try running the Arduino IDE in portable mode by creating a folder named portable under the Arduino IDE installation folder:
