Hello there.
I'm facing some issues with my Arduino Wi-Fi shield. Basically, I'm using my Arduino R3 with Arduino Wi-Fi shield and running the script below, getting the message "Wi-Fi shield not present".
Before I buy another Wi-Fi shield, I'm wondering what kind of other troubleshooting should I run. All the libs used in this simple example are updated, and the cables are in a good state and working.
I also ran another script to use only de SD card, which failed at the end on all tries.
Using my Ethernet Shield, the SD card script worked successfully, which leads me to believe that my Wi-Fi shield might be busted or needs some firmware reset or something like it.
If you have experienced this kind of issue, please help me to fix it.
This example prints the WiFi shield's MAC address, and
scans for available WiFi networks using the WiFi shield.
Every ten seconds, it scans again. It doesn't actually
connect to any network, so no encryption scheme is specified.
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 21 Junn 2012
by Tom Igoe and Jaymes Dec
#include <SPI.h>
#include <WiFi101.h>
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// Print WiFi MAC address:
printMacAddress();
// scan for existing networks:
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
listNetworks();
void printMacAddress() {
// the MAC address of your WiFi shield
byte mac[6];
// print your MAC address:
WiFi.macAddress(mac);
Serial.print("MAC: ");
printMacAddress(mac);
void listNetworks() {
// scan for nearby networks:
Serial.println("** Scan Networks **");
int numSsid = WiFi.scanNetworks();
if (numSsid == -1)
Serial.println("Couldn't get a wifi connection");
while (true);
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found:
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
Serial.flush();
void printEncryptionType(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
SD Card issue
SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
Serial.println("example.txt doesn't exist.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
// delete the file:
Serial.println("Removing example.txt...");
SD.remove("example.txt");
// nothing happens after setup finishes.
