I plan to run my Arduino Nano from my laptop, which only has one USB port. I intend to buy a USB hub which could split to have about 4 USB ports, and then use one of them for a web cam and the other for my Arduino.
The USB port on my laptop is likely going to limit the current at 500mA. And if I were to split the ports with a USB hub, would there still have enough current to power both the web cam and Arduino? Would the current be divided into 250mA for each port?
Do uou mean one that I can insert batteries into the hub? Most of the hubs I see in stores are just ordinary ones with only a male USB head split to 4 female ports. Would those ordinary ones divide the current causing arduino to have insufficient power?
Do you mean one that I can insert batteries into the hub?
Usually they have a "wall wart" power supply like an ethernet hub (or switch or router). I've never seen a battery powered one. And at 500mA, the batteries wouldn't last long.
[u]Here[/u] is the 1st powered hub I found when I googled.
