I want to do this circuit but with out the MLX 90614, but will the circuit and code work?
I will upload the circuit and code
I guess you will need to tell us what it it supposed to do, first. Does it need to work 100% or is there some intermediate work that is ok?
Fire fighting robot, Sorry i didn't mention earlier.
I am making it for a science project so i need it to perform good
I can't upload the code it is saying ( the file you are trying to upload is not authorized
You don't need to "upload". In the IDE, press ctrl-T, then ctrl-shft-C, then, in a new message in this thread, press ctrl-V.
That should insert your code, complete, in code tags for easy inspection and proper formatting.
You show a lot of connected pieces. Exactly what do you expect from each piece and what are you getting right now that makes you ask about the project?
This is my first time using arduino and code so I don't know much about this stuff.
I wanted to know if I could do this circuit without the mlx because I could not get the mlx
I am using phone not pc😅
Should i use 5v or 12v water pump
What type of power supply do you have for either one? How much water flow do you need?
