Will this work? (2 power supplies to 4 motors)
I have four 24v stepper motors that I want to power. Can I buy two 12v wall adapters and just connect their outputs in series to produce 24 volts, then connect the motors (in parallel) to that?
The power supplies are rated at 2.0A each, and the amp rating of the stepper motors are apparently secret since I can't find it documented. I suspect they are around 0.5 amps each.
Thanks.
Tim
Yes, sure, you can connect two power supplies in series.
