i wish to build a mini water pump that can be switched on/off by a smart phone (wireless)
i did some research on esp modules, how to make a mini water pump.
please i need guidance on how to go about the process.
Since you mentioned switching on/off, I guess your pump will need an electric motor of some sort. I have small motor/pump combination for my bird waterer. If I added a relay, I could switch it on/off. Is this what you have in mind?
To simplify, you can break your design into different problems that can be solved independently:
Control Locally: Create an application that turns a pump on/off
Communicate: Add an wireless interface for the Smartphone
Control Remotely: Add an wireless interface for the Smartphone
Resolve the control problem which is where you'll have to do most of your thinking. Here is a post where someone is working on code to turn a pump on/off, so don't worry... there are resources out there to help you.
Now make your board communicate. Here is a tutorial for an add-on board (TapNLink) that can be used to communicate with Bluetooth between your Arduino and your smartphone.
The good thing about this add-on is that you can add it after you develop the part in Step 1 which controls the motor/pump.
Then, you'll see from the TapNLink add-on board tutorial, that when you configure TapNLink to communicate with your Arduino, it will automatically create an app for you.
In this case steps, 2 and 3 are practically done for you. Very easy.
Let me know if you try this. Really interested in knowing if it works for you.
Easiest on the pump side: ESP-01 + relay module, those modules come ready made, just stick in your pre-programmed ESP-01 and wire it up (5V / USB power supply; pump wires to the appropriate relay contacts).
Have it connect to WiFi so it can receive commands that way. Blynk is a good way to communicate the moment you're connected to the Internet.
