Wiring a button with 4 wires to Arduino
I need help wiring a button that's has 4 wires. I want to use a breadboard and resistors and wire at least 3 of these buttons. Here is the link for them:
STARELO 5pcs 12mm Momentary led Push Button Switch Black Shell with pre-Wiring, IP65 Waterproof Push Button Switch,1NO 1 Normally,Self-resetting with LED(Blue). https://a.co/d/6AN4Cx2
When pressed, I want it to run the code.
Help would be appreciated.
It's just a separate LED and a separate switch.
The LED pins are marked with (+) and (-),
The switch is the two "NO" pins.
Post the code that you need help with.
Leo..
