Wiring multiple 4-20mA signals to arduino uno
Hi, @avogadrosmole
With everything disconnected from the sensor, measure the resistance between;
Temp output positive and PH output positive terminals.
Then
Temp output negative and PH output negative terminals.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
PS. I suspect the two positives are connected together.
Yes, I do
You were correct. With everything disconnected I got a O.L between the two negative terminals but a 0.4 ohm reading between the two positive terminals.
Thanks, I was thinking along the same lines. I have not found din rail mountable DPDT relays that have a 5V coil rating. I used two relays instead to get the job done.
I've attached a wiring schematic for what I did. I realized after making this, I should only need one 220 ohm resistor that can be connected between the two relay com wire connections... oh well, this still works.
I used the following code to get accurate signals from both outputs:
int g_relayPin = 11;
int sen_relayPin = 9;
int sense_pin = 5;
float vPow = 5;
String pH_str = "P,";
String Temp_str = "T,";
String term = ",";
  pinMode(sen_relayPin, OUTPUT);
  pinMode(g_relayPin, OUTPUT);
  float pH = (analogRead(sense_pin) * vPow)/1024.0;
  Serial.print(pH_str);
  Serial.print(pH);
  Serial.println(term);
  digitalWrite(sen_relayPin, HIGH);
  digitalWrite(g_relayPin, HIGH);
  float Temp = (analogRead(sense_pin) * vPow)/1024.0;
  Serial.print(Temp_str);
  Serial.print(Temp);
  digitalWrite(sen_relayPin, LOW);
  digitalWrite(g_relayPin, LOW);
