#include <LoRa_E220.h>
#include <Blynk.h>
#include<SPI.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#define DESTINATION_ADDL 3
LoRa_E220 e220ttl(D3, D4, D5, D7, D6);
//TEMPLATE MENYAMBUNGKAN APLIKASI DAN ESP8266//
#define BLYNK_TEMPLATE_ID "TMPLa1jBSJmW"
#define BLYNK_TEMPLATE_NAME "Aplikasi Kontroler"
#define BLYNK_AUTH_TOKEN "KEhBiA71LJ4pXGYhnyYmp554umY1zf8e"
// Kredensial Wi-Fi
char ssid[] = "T2";
char pass[] = "N0#geming#boz";
char auth[] = BLYNK_AUTH_TOKEN;
BlynkTimer timer;
//define ESP8266 NodeMCU GPIO pins
//SoftwareSerial loraSerial(12, 14); // RX, TX
#define pSwitch_1 10 //SD3
#define pSwitch_2 0 //D3
#define pSwitch_3 14 //D5
#define pSwitch_4 3 //RX
#define wifiLed 16 //D0
#define sLED 2 //D4
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
int wifiFlag = 0;
int i;
String incomingString;
boolean state;
String command;
struct Perintah
char type[5];
char command[8];
int VPIN_BUTTON_1;
int VPIN_BUTTON_2;
int VPIN_BUTTON_3;
struct Perintah perintah = {"", "", 0, 0, 0};
void getFeedback(String excpt_str){
i = 0;
incomingString = "";
state = true;
digitalWrite(sLED, LOW);
Blynk.virtualWrite(VPIN_BUTTON_5, "Waiting for Feedback...");
//Serial.print("Waiting for feedback");
while(1){
if(Serial.available()>0){
incomingString = Serial.readString();
Serial.println(incomingString);
if(incomingString.indexOf(excpt_str) > 0) {
state = true; break;
if (i > 70) {
state = false; break;
delay(50);
digitalWrite(sLED, !digitalRead(sLED));
i++;
if(state){
digitalWrite(sLED, HIGH);
Blynk.virtualWrite(VPIN_BUTTON_5, "Feedback Received.");
//Serial.println("Received");
else{
Blynk.virtualWrite(VPIN_BUTTON_5, "Feedback Not Received.");
//Serial.println("Not Received");
// Startup all pins and UART
e220ttl.begin();
Serial.println("Hi, Saya akan mengirimkan perintah untuk mengaktifkan aktuator!");
struct Perintah command = {""}
// Saat tombol ditekan - mengalihkan status
Blynk.virtualWrite(VPIN_BUTTON_1,0) {
if(param.asInt() == 1){
command = "2,R1";
Serial.println(command);
getFeedback("FR1");
delay(10);
command = "";
Blynk.virtualWrite(VPIN_BUTTON_2,0) {
command = "2,R2";
getFeedback("FR2");
delay(10);
command = "";
Blynk.virtualWriteE(VPIN_BUTTON_3,0) {
command = "2,R3";
getFeedback("FR3");
delay(10);
command = "";
void checkBlynkStatus()
{ // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
digitalWrite(wifiLed, HIGH); //Turn off WiFi LED
if (isconnected == true) {
wifiFlag = 0;
digitalWrite(wifiLed, LOW); //Turn on WiFi LED
pinMode(wifiLed, OUTPUT);
pinMode(sLED, OUTPUT);
pinMode(pSwitch_1, INPUT_PULLUP);
pinMode(pSwitch_2, INPUT_PULLUP);
pinMode(pSwitch_3, INPUT_PULLUP);
digitalWrite(sLED, HIGH); //Turn on Status LED
Blynk.begin(auth, ssid, pass);
timer.setInterval(3000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
delay(1500);
Blynk.virtualWrite(VPIN_BUTTON_5, "Ready...");
if (Serial.available()){
Serial.write(Serial.read());
Blynk.run();
//manual_control();
timer.run(); // Initiates SimpleTimer
// Send message
ResponseStatus rs = e220ttl.sendFixedMessage(0, DESTINATION_ADDL, 23, &command, sizeof(Perintah));
// Check If there is some problem of succesfully send
Serial.println(rs.getResponseDescription());
// If something available
if (e220ttl.available()>1) {
// read the String message
#ifdef ENABLE_RSSI
ResponseStructContainer rsc = e220ttl.receiveMessageRSSI(sizeof(Perintah));
#else
ResponseStructContainer rsc = e220ttl.receiveMessage(sizeof(Perintah));
#endif
// Is something goes wrong print error
if (rsc.status.code!=1){
Serial.println(rsc.status.getResponseDescription());
}else{
// Print the data received
struct Perintah message = *(Perintah*) rsc.data;
Serial.println(message.type);
Serial.println(message.command);
Serial.println(message.V1);
Serial.println(message.V2);
Serial.println(message.V3);
#ifdef ENABLE_RSSI
Serial.print("RSSI: "); Serial.println(rsc.rssi, DEC);
#endif
if (Serial.available()) {
struct Perintah command = {" "};
command.V1 = Serial.parseInt();
command.V2 = Serial.parseInt();
command.V3 = Serial.parseInt();
// Send message
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" to see how we can help.
Addition to the formatting the code, please explain what the problem you have with it. If there are a compile errors, please insert them in full using the code tags.
upload a schematic showing the wiring in particular how you power the Ebyte E220 LoRa and other devices
I assume you are using LoRa P2P communication have you tested the E220 in a seperate program?
does the program compile and run? if so upload a copy of the Serial Monitor output - it is always worth adding extra Serial.println() statements to display variable values at key points in the program execution
Very generalised question. So much generalised that the very generalised answer is:
Yes.
.... ---- .... --- ..... so what? ....-------.......--------.........-------......
We can help you in more detail if you take the effort to the instructions
that you can read here
best regards Stefan
here is my code
BLYNK_LORA_COMMAND.ino (5.3 KB)
You should really read this !
the output shows
"Compilation error: too many initializers for 'Perintah'"
Still only very poor information:
You are trying to be quick by quick and short postings. All that happens is that you are slowing things down, because all that happends is asking back that you provide the information that you thought leave it away to be quicker
you mean like this? sorry, sorry I'm a newbie user
#include <Blynk.h>
#include<SPI.h>
// Kredensial Wi-Fi
char ssid[] = "T2";
BlynkTimer timer;
#define sLED 2 //D4
int wifiFlag = 0;
int i;
boolean state;
char command[8];
struct Perintah
char type[5];
char command[8];
int VPIN_BUTTON_1[8];
int VPIN_BUTTON_2[8];
int VPIN_BUTTON_3[8];
} perintah = {"", "", "", "", "", ""};
i = 0;
state = true;
while(1){
if (i > 70) {
delay(50);
i++;
if(state){
else{
e220ttl.begin();
BLYNK_WRITE(VPIN_BUTTON_1) {
command = "2,R1";
getFeedback("FR1");
delay(10);
command = "";
BLYNK_WRITE(VPIN_BUTTON_2) {
command = "2,R2";
getFeedback("FR2");
delay(10);
command = "";
BLYNK_WRITE(VPIN_BUTTON_3) {
command = "2,R3";
getFeedback("FR3");
delay(10);
command = "";
wifiFlag = 1;
wifiFlag = 0;
delay(1500);
Blynk.run();
//manual_control();
// Send message
#ifdef ENABLE_RSSI
#else
#endif
}else{
Serial.println(message.VPIN_BUTTON_1);
#ifdef ENABLE_RSSI
#endif
command.VPIN_BUTTON_1 = Serial.parseInt();
// Send message
the structure has five members and you have six initialisers
try
struct Perintah
char type[5];
char command[8];
} perintah = {"", "",{0},{0},{0}};
as perintah is global it initial values will be set to 0 by default anyway
I suspct you have many errors reported by the compiler - upload the complete compiler error report??
You should use keyword struct
only when you want to defene a new type.
Do not use this keyword when you define a new variable of previsly defined type Perintah
as in line above.
implement a simple program to test structure initialisation, e.g. using a NodeMCU ESP8266
struct Perintah
char type[5];
char command[8];
struct Perintah test = {"tst1","test2",{1,2,3},{7,8,9},{10,1,12}};
Serial.println(test.command);
Serial.println(test.VPIN_BUTTON_1[0]);
Serial.println(test.VPIN_BUTTON_2[2]);
Serial.println(test.VPIN_BUTTON_2[6]);
Serial.println(test.VPIN_BUTTON_3[2]++);
delay(2000);
serial monitor displays
test2
test2
1
9
0
12
13
14
15
