Write at high speed on a SD card
Hello,
I am using an Arduino Nano BLE Sense to collect datas from several sensors. My final goal is to make possible that these datas are saved at different sampling frequency (4 Hz, 32 Hz or 64 Hz depending on the data) on a SD card and are sent by BLE. I am currently working on the part of the program to save on SD card. Here is the basic program for recording one data.
#include <Arduino_HTS221.h> // temperature sensor
#include <SPI.h>
#include <SD.h>
File myFile_T;
float tSensor=0;
float t=0;//time initialisation
const float f_temp=20; //sampling rate of temperature (Hz)
const float delta_temp=1/f_temp*1000; //period between 2 saving (ms)
float last_t_temp =0;
  HTS.begin(); //initialisation of the temperature sensor
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("delta_temp \t");
  Serial.println(delta_temp);
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  t=millis();
  //Serial.println(t-last_t_temp);
  if ((t-last_t_temp)>delta_temp){
    Serial.print(t);
    Serial.print("\t");
    Serial.print(last_t_temp);
    Serial.print("\t");
    Serial.print(t-last_t_temp);
    Serial.print("\t");
    tSensor=HTS.readTemperature();
    Serial.println(tSensor);
   // open the temperature file and write inside
    myFile_T = SD.open("temp.txt", FILE_WRITE);
    if (myFile_T) {   // if the file opened okay, write to it:
      Serial.print("Writing to test.txt...");
      myFile_T.print(t);
      myFile_T.print("\t");
      myFile_T.println(tSensor);
      myFile_T.close();// close the file:
      Serial.println("done.");
      // if the file didn't open, print an error:
      Serial.println("error opening temp.txt");
    last_t_temp=t;
//delay (1000);
I have changed sampling rate to check until which value I can go. It seems that it is difficult to go higher than 20 Hz. To overcome that, I tried keep the file opened (so the file is never closed). However, this method leads to empty files. Does anyone would have a solution?
#include <SPI.h>
#include <SD.h>
File myFile_T;
float tSensor=0;
float t=0;//initialisation du temps
const float f_temp=4; //fréquence d'enregistrement de la température (en Hz)
const float delta_temp=1/f_temp*1000; //écart entre 2 enregistrements de température (en ms)
  while (!Serial) {
  if (!SD.begin(4)) {
    while (1);
  Serial.println("file opened");
  t=millis();
    Serial.print(t);
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\t");
      myFile_T.print(t);
//      myFile_T.close();// close the file:
//      Serial.println("done.");
//    } else {
//      // if the file didn't open, print an error:
//      Serial.println("error opening temp.txt");
    last_t_temp=t;
//delay (1000);
I use the SdFat ExFatLogger to store data off an Adafruit LSM6DS33 3-axis Accelerometer and 3-axis gyroscope. I can log at 250Hz sample rate using a Mega2650 and a seeed SD shield. You should be OK for performance and memory with the Nano BLE M4 is you choose to go this route.
generate preformatted string und send it to file.
Thanks for the reply, I will check this library
Hello, would it be possible to see your code? Indeed using SDFat library I can reach a delay of 53 ms between 2 measurements writing (eg around 20Hz) but I don't manage to go faster
SdFat SD;
#define SD_CS_PIN SS
File myFile_T;
float tSensor=0;
const float f_temp=32; //fréquence d'enregistrement de la température (en Hz)
  while (!Serial) {
  //if (!SD.begin(4)) {
  if (!SD.begin(SD_CS_PIN)) {
    while (1);
  t=millis();
    Serial.print(t);
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\t");
      Serial.print("Writing to temp.txt...");
      myFile_T.print(t);
    last_t_temp=t;
//delay (1000);
Just get ExFatLogger.ino from here
My code only incorporated the Adafruit LSM6DS33 sensor into the EFL.ino You need to modify>
// Replace logRecord(), printRecord(), and ExFatLogger.h for your sensors.
starting about line 86
