Jetzt weiß ich was der Fehler ist.
Bestellt hatte ich WS2812b, beim auspacken aber nicht darauf geschaut ob es auch diese sind.
Hab gerade mal die Verpackung rausgesucht und festgestellt das es RGBW5 sind.
Hab das mal mit dem Sketch gestestet:
// Modified strandtest sketch to support also RGBW strips like SK6812 based:
// http://www.szledcolor.com/download/SK6812RGBW.pdf
// Should be used with Adafruit NeoPixel version 1.0.3
// Hacked by G. Knauf 2015-12-06
#include "Color_Definitions.h"
#ifdef __AVR__
#include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#ifdef __AVR_ATtiny85__
#define NEO_PIN 0 // NeoPixel DATA
#undef LED_BUILTIN
//#define LED_BUILTIN 0 // LED on Model B
#define LED_BUILTIN 1 // LED on Model A
#else
#define NEO_PIN 6 // NeoPixel DATA
#endif
// What type of NeoPixel strip is attached to the Arduino?
#define NEO_PTYPE NEO_GRBW // f.e. SK6812
//#define NEO_PTYPE NEO_GRB // most NeoPixel products
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 60
#define BRIGHTNESS 64 // set max brightness
#define IWAIT 2000
#define SWAIT 20
#define LWAIT 50
#define HWAIT 1500
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_GRBW Pixels are wired for GRBW bitstream (f.e. SK6812)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_PTYPE + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
// NOTE: RGBW LEDs draw up to 80mA with all colors + white at full brightness!
// That means that a 60-pixel strip can draw up to 60x 80 = 4800mA, so you
// should use a 5A power supply; for a 144-pixel strip its max 11520mA = 12A!
// This is for Trinket 5V 16MHz
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
// End of trinket special code
#endif
#ifdef LED_BUILTIN
// Turn the onboard LED off by making the voltage LOW
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
strip.begin();
strip.setBrightness(BRIGHTNESS); // set brightness
strip.show(); // Initialize all pixels to 'off'
#ifdef IWAIT
delay(IWAIT);
#endif
// Some example procedures showing how to display to the pixels:
colorWipe(RED, SWAIT);
colorWipeReverse(DARKRED, SWAIT);
colorWipe(GREEN, SWAIT);
colorWipeReverse(DARKGREEN, SWAIT);
colorWipe(MAGENTA, SWAIT);
colorWipeReverse(DARKMAGENTA, SWAIT);
colorWipe(BLUE, SWAIT);
colorWipeReverse(DARKBLUE, SWAIT);
colorWipe(TURQUOISE, SWAIT);
colorWipeReverse(DARKTURQUOISE, SWAIT);
#if (((NEO_PTYPE & 0xC0) >> 2) != (NEO_PTYPE & 0x30)) // check for RGBW type
colorWipe(WHITE_LED, SWAIT); // use the real White LEDs
colorWipeReverse(DIMWHITE_LED, SWAIT); // use the real White LEDs
#else
colorWipe(WHITE, SWAIT); // use composed White from RGB
colorWipeReverse(DIMGRAY, SWAIT); // use composed White from RGB
#endif
delay(HWAIT);
colorWipeReverse(BLACK, LWAIT);
delay(HWAIT);
// Send a theater pixel chase in...
theaterChase(WHITE_LED, LWAIT); // use the real White LEDs
#else
theaterChase(WHITE, LWAIT); // use composed White from RGB
#endif
// theaterChase(GRAY, LWAIT); // White
theaterChase(MAROON, LWAIT); // Red
theaterChase(NAVY, LWAIT); // Blue
theaterChase(LIME, LWAIT); // Green
theaterChase(PURPLE, LWAIT); // Purple
rainbow(LWAIT);
rainbowCycle(SWAIT);
theaterChaseRainbow(LWAIT);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint16_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Fill the dots one after the other with a color backward
void colorWipeReverse(uint32_t c, uint16_t wait) {
for(uint16_t i=strip.numPixels(); i>0; i--) {
strip.setPixelColor(i-1, c);
strip.show();
delay(wait);
void rainbow(uint16_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint16_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint16_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (int i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint16_t wait) {
for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Und der Funktioniert prima.
Sorry Leute, wenn man nicht genau hin sieht wird einem einfach was anderes geliefert als man bestellt hat.
Danke für euer Hilfe, den das hat mich auf die Idee gebracht da mal nachzuschauen.
Gruß Levi
