I’m trying to get a nice pattern on my WS2812B LED strip. This LED strip is 5m and have 300 LEDs. It is in use as a garden light. What I want to make sounds pretty simple but I can’t figure out how to do this.
My idea:
- the whole LED Strip must have a soft orange “back color”
- there must be some 8 white light spots from +- 15 LEDs
- this white light spots must be very slowly and smoothly moving across this LED strip.
I have found some code from Andrew Tuline and I have narrow this code down to the part what I need.
Now I have Blue very slowly moving LEDs and the remaining LEDs are black. This slowly moving is exactly what I need. But the moving LEDs must be white and the rmainig Black LEDs must be soft (night) orange.
This is how it looks till now:
I’m using on my table a test strip with 144 LEDs
Is there someone here in this forum who can help me with this?
Here is my code till so far:
/* three_sin demo
By: Andrew Tuline
Date: March, 2015
3 sine waves, one for each colour. I didn't take this far.
10-09-2016
WAVE for LED Strip.
#include "FastLED.h" // FastLED library. Preferably the latest copy of FastLED 2.1.
#if FASTLED_VERSION < 3001000
#error "Requires FastLED 3.1 or later; check github for latest code."
#endif
// Fixed definitions cannot change on the fly.
#define LED_DT 4 // Serial data pin for WS2812B or WS2801
#define COLOR_ORDER GRB // Are they RGB, GRB or what??
#define LED_TYPE WS2812B // What kind of strip are you using?
#define NUM_LEDS 144 // Number of LED's
// Initialize changeable global variables.
uint8_t max_bright = 64; // Overall brightness definition. It can be changed on the fly.
//struct CRGB leds[NUM_LEDS]; // Initialize our LED array.
// Initialize global variables for sequences
uint8_t thisdelay = 50; // A delay value for the sequence(s)
int wave1 = 0;
uint8_t inc1 = -500; //-2 // Phase shift. Keep it low, as this is the speed at which the waves move.
uint8_t lvl1 = 80; // Any result below this value is displayed as 0.
uint8_t mul1 = 20; // Frequency, thus the distance between waves
uint8_t mul2 = 25;
uint8_t mul3 = 22;
Serial.begin(57600);
FastLED.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS); // Use this for WS2812B
FastLED.setBrightness(max_bright);
set_max_power_in_volts_and_milliamps(5, 500); // FastLED Power management set at 5V, 500mA
} // setup()
void loop () {
ChangeMe();
EVERY_N_MILLISECONDS(thisdelay) { // FastLED based non-blocking delay to update/display the sequence.
one_sin(); // Improved method of using non-blocking delay
show_at_max_brightness_for_power();
} // loop()
void one_sin() {
wave1 += inc1;
for (int k = 0; k < NUM_LEDS; k++) {
leds[k].b = qsub8(sin8(mul3 * k + wave1 / 128), lvl1); // A fixed frequency, variable phase sine wave with lowered level
// fill_solid( leds, NUM_LEDS, CHSV(32, 0, 75)); // Filled Background. Orange
// uint8_t hsvval = qsub8(sin8(mul3*k + wave3/128), lvl3);
// leds[k] = CHSV(hsvval, 255, 150);
} // one_sin()
void ChangeMe() {
uint8_t secondHand = (millis() / 1000) % 30; // Increase this and add more options below if you want a longer demo.
static uint8_t lastSecond = 99; // Static variable, means it's only defined once. This is our 'debounce' variable.
if (lastSecond != secondHand) { // You can change variables, but remember to set them back in the next demo, or they will stay as is.
lastSecond = secondHand;
switch (secondHand) {
case 10: mul1 = 5; mul2 = 8; mul3 = 7; break;
case 30: break;
} // ChangeMe()
