I'm trying to get my 1.69 inch waveshare screens to work on the XIAO Rp2040 board. The screen uses the ST7789 driver but when connecting it as shown in the image it does not work. I understand that this is for the NRF52840 board. I would like to know if someone can help me with the connections or a test code so I can use it but on the Xiao RP2040.
The ST7789 Library that I use is this one.
#ifndef __ST7789V2_H__
#define __ST7789V2_H__
#include <Arduino.h>
#include "stdio.h"
#include "fonts.h"
#include <SPI.h>
#if defined(ARDUINO_SEEED_XIAO_NRF52840_SENSE) || defined(ARDUINO_SEEED_XIAO_NRF52840)
#include <avr/dtostrf.h>
#endif
#define RST_PIN D0
#define DC_PIN D3
#define BL_PIN D6
#define CS_PIN D1
#define LCD_WIDTH 240 //LCD width
#define LCD_HEIGHT 280 //LCD height
#define DEV_DEBUG 1
#if DEV_DEBUG
#define Debug(__info,...) printf("Debug : " __info,##__VA_ARGS__)
#else
#define DEBUG(__info,...)
#endif
* The size of the point
typedef enum {
DOT_PIXEL_1X1 = 1, // 1 x 1
DOT_PIXEL_2X2 , // 2 X 2
DOT_PIXEL_3X3 , // 3 X 3
DOT_PIXEL_4X4 , // 4 X 4
DOT_PIXEL_5X5 , // 5 X 5
DOT_PIXEL_6X6 , // 6 X 6
DOT_PIXEL_7X7 , // 7 X 7
DOT_PIXEL_8X8 , // 8 X 8
} DOT_PIXEL;
#define DOT_PIXEL_DFT DOT_PIXEL_1X1 //Default dot pilex
* Point size fill style
typedef enum {
DOT_FILL_AROUND = 1, // dot pixel 1 x 1
DOT_FILL_RIGHTUP , // dot pixel 2 X 2
} DOT_STYLE;
#define DOT_STYLE_DFT DOT_FILL_AROUND //Default dot pilex
* Line style, solid or dashed
typedef enum {
LINE_STYLE_SOLID = 0,
LINE_STYLE_DOTTED,
} LINE_STYLE;
* Whether the graphic is filled
typedef enum {
DRAW_FILL_EMPTY = 0,
DRAW_FILL_FULL,
} DRAW_FILL;
* image color
#define WHITE 0xFFFF
#define BLACK 0x0000
#define BLUE 0x001F
#define BRED 0XF81F
#define GRED 0XFFE0
#define GBLUE 0X07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define GREEN 0x07E0
#define CYAN 0x7FFF
#define YELLOW 0xFFE0
#define BROWN 0XBC40
#define BRRED 0XFC07
#define GRAY 0X8430
#define DARKBLUE 0X01CF
#define LIGHTBLUE 0X7D7C
#define GRAYBLUE 0X5458
#define LIGHTGREEN 0X841F
#define LGRAY 0XC618
#define LGRAYBLUE 0XA651
#define LBBLUE 0X2B12
* Display rotate
#define ROTATE_0 0
#define ROTATE_90 90
#define ROTATE_180 180
#define ROTATE_270 270
#define MIRROR_NONE 0x00
#define MIRROR_HORIZONTAL 0x01
#define MIRROR_VERTICAL 0x02
#define MIRROR_ORIGIN 0x03
class st7789v2{
protected:
uint8_t spi_cs, spi_dc, spi_rst, spi_bl;
uint16_t ROTA = ROTATE_0, MIRR = MIRROR_NONE;
private:
void WriteReg(uint8_t data);
void WriteData_Byte(uint8_t data);
void WriteData_Word(uint16_t data);
void DrawChar(int16_t Xpoint, int16_t Ypoint, const char Acsii_Char, sFONT* Font, int16_t Color_Background, int16_t Color_Foreground);
public:
// bool horizontal = false;
uint8_t mirror = MIRROR_NONE;
void Init(uint8_t cs = CS_PIN, uint8_t dc = DC_PIN, uint8_t rst = RST_PIN, uint8_t bl = BL_PIN);
void SetBacklight(uint16_t Value);
void Reset(void);
void SetCursor(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend);
void Clear(uint16_t Color);
void ClearWindow(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend, uint16_t color);
void SetWindowColor(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend, uint16_t Color);
void SetUWORD(uint16_t x, uint16_t y, uint16_t Color);
void SetRotate(uint16_t Rotate);
void SetMirroring(uint8_t mirror);
void SetPixel(uint16_t Xpoint, uint16_t Ypoint, uint16_t Color);
void DrawPoint( uint16_t Xpoint, uint16_t Ypoint, uint16_t Color, DOT_PIXEL Dot_Pixel, DOT_STYLE Dot_FillWay);
void DrawLine(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend, uint16_t Color, DOT_PIXEL Line_width, LINE_STYLE Line_Style);
void DrawRectangle(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend, uint16_t Color, DOT_PIXEL Line_width, DRAW_FILL Filled);
void DrawCircle(uint16_t X_Center, uint16_t Y_Center, uint16_t Radius, uint16_t Color, DOT_PIXEL Line_width, DRAW_FILL Draw_Fill);
void DrawString_EN(int16_t Xstart, int16_t Ystart, const char * pString, sFONT* Font, int16_t Color_Background, int16_t Color_Foreground);
void DrawNum(int16_t Xpoint, int16_t Ypoint, int32_t Nummber, sFONT* Font, int16_t Color_Background, int16_t Color_Foreground);
void DrawFloatNum(int16_t Xpoint, int16_t Ypoint, double Nummber, int8_t Decimal_Point, sFONT* Font, int16_t Color_Background, int16_t Color_Foreground);
void DrawImage(const unsigned char *image, int16_t xStart, int16_t yStart, int16_t W_Image, int16_t H_Image);
#endif
