I hope I didn´t miss any previous posts about the XL6009 step-up, but couldn´t find anything that suits my problem:
I´m trying boost 2x Lithium ion batteries in series to achieve a 32V output 1100ma. I measured the amperage and got 500mA .
I'm using Samsung 18650 25R batteries, they are capable of providing 20a each, while xl6009 is only drawing 1amp from each battery.
So what am I missing?
The load is 35w.
Xl6009 draws 3a at 12v when connected to dc adaptor.thats 36w
Xl6009 draws only 2A at 8v when connected to lithium ion batteries. That's only 16W
That would require a 32V / 7.4V = 4.3x step up and a current of about 5Amp from the batteries, which is beyond the switching capacity of an XL6009.
Leo..
The adapter does two things, it gives you more current capability and you are boosting the voltage a lower percent.
That is 35 watts or 2.7 amps from the adapter. I expect with that load and the impedance of the batteries, connections, etc you are getting less volts and need more current.
Best to get bigger or more batteries.
I read the spec sheet. Isn't the 4amp limit is for max output current?
Even if we assume it's for input, 8v 4amp would be 32w. It should be drawing 32w from batteries not 15w.
8v is within the operating limit of 5-32v. It works with 12v adaptor, it's draws 3 amps, that's 36w.
Only with batteries it draws less amps if the load is 35w, then it should be drawing 4amps with 8v source
No, the 4A is the limit for the internal switch.
And that switch isn't 'on' all the time in boost mode.
So input (battery) current must be kept well below 4A.
Can't you use three LiPo batteries in series.
Leo..
