I hope I didn´t miss any previous posts about the XL6009 step-up, but couldn´t find anything that suits my problem:
I´m trying boost 2xAA batteries in series to achieve a 12V output for running a solenoid. So far so good, 12V are easy to set up. The problem is, that the solenoid doesn´t make any attempts to move. Hence, I measured the amperage and got a number around 20mA (while 300mA are needed). If I got it right, input and output follow the rule:
The XL6009 allows an efficiency of up to 0.94. If I want to get 300mA Output, I need to supply a minimum of 1200mA Input. The batteries should easily be capable of delivering this amount. Even if the efficieny is pretty bad, there shouldn´t be any problem.
The datasheet of the chip states a minimum input voltage of 3.6volt.
The (unspecified) AA batteries could sag to 1volt under load.
If the chip would work on 2volt, the batteries would have to supply ~2Amp.
Only some types can, for a short time.
Leo..
Adding another AA to supply 4.5V? But than I run into trouble with the power supply of my Arduino Pro Mini 3v3, which I don`t want to run from RAW input for power saving reasons. Furthermore I´ll have problems with space.
But uhm, 3 AA's in series might still drop under load. The 300mA (and probably higher on inrush...) is already 800mA in the low side (not counting losses and assuming the full 4,5V). But under a load like that the voltage is likely to drop which results in increased current etc. I don't think a small pack of AA's can deliver enough power at once.... A lithium battery is better at that. Or if you need a small pulse you can charge some caps and discharge them at once through the solenoid.
septillion:
And a 3,3V Arduino works just fine @ 4,5V.
The (official) ProMini has a solder jumper to separate the output of the regulator and the power LED from VCC.
Maybe wise to cut that link if you use a higher that 3.3volt supply. That could also reduce current draw by ~0.5mA.
Leo..
The datasheet I found says a minimum of 5V for the input side.
That solenoid wants nearly 4W, its not a trivial load, I'd ask if there's not a lower power alternative
or whether you can use capacitor boosting? What on-time and duty-cycle are you needing?
Maybe a capacitor is an option, just need the solenoid to snap back once (.5 - 1s). Another solenoid is hard to get, because of the desired dimensions. Searched a long time to find at least one that fits.
