hey guyz i wan to make single sided PcB for arduino uno... i have searched it on google and i found only this
but this is a serial programmer... i want usb programmer...
does anybody here has USB version of this single sided board??
wakam:
hey guyz i wan to make single sided PcB for arduino uno... i have searched it on google and i found only thishttp://arduino.cc/en/Main/ArduinoBoardSerialSingleSided3
Depends on what you want.. Do you want the USB on-board or as an external device?? In-case of external then here is a link: http://vonkonow.com/wordpress/2012/10/nanino-the-diy-friendly-arduino/
In-case you want an internal, you got to specify the USB chip.. Do you want a FTDI, or atmega8u2/16u2 like the uno???
Yes, i want on board USB like arduino uno. and also atmega8u2/atmega16u2.
In short i want to replicate arduino uno board,on single sided pcb using THT(Through hole technology).
I'm sorry to say this bro, but, there isn't any DIP/through hole package for the atmega8u2/16u2.. And I really don't know of any chip in DIP package that does USB Serial conversion... You can maybe make something like this guy: Single Sided USB - ALL DIP no ft232rl - Development - Arduino Forum
He's uses an atmega8 as the USB to serial chip..
//Basel
And what about this? (I do not know anything about it, I found it by accident)
K5CZ:
And what about this? (I do not know anything about it, I found it by accident)http://vonkonow.com/wordpress/2012/10/nanino-the-diy-friendly-arduino/
This needs an external USB to Serial adapter in-order to program it.. So no USB on-board...
//Basel
Edit: found answer:
Metaboard is best used with USBaspLoader
And USBaspLoader is V-USB V-USB - A Firmware-Only USB Driver for Atmel AVR Microcontrollers
Interesting. Have you tried this?
I have posted many V-USB articles and have my own license, but the link appears to deviate from the V-USB Port, until it mentions RancidBacon's Arduino port which is a V-USB'ish library port. Very confusing. Guess I need to drop the zip and see what is happening behind the scenes.
Edit: more Metaboard w/328
Bootloader: https://sites.google.com/site/a52egv/metaboard
Problem with burning usbasp-bootloader to ATMEGA8 with Arduino - Microcontrollers - Arduino Forum
Ray
If you want a through-hole USB-Serial chip, the only one I could come up with when I looked in the past is this Microcontroller:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en533924
Trouble is you have to be able to program PIC devices to get it to work. The firmware for the PIC along with a windows driver can be found here and a schematic of how it can be wired up here (Eagle 6 schematic which includes the PIC18F14K50 as a USB-serial device).
I like this module for thru hole USB/Serial.
Here it is in a socket, so it can be removed after serial downloading.
http://www.crossroadsfencing.com/BobuinoRev17/
Another option is the PIC32MX250F128B
You can buy it with preinstalled USB-bootloader for $ 3.75
http://www.microchipdirect.com/ProductSearch.aspx?Keywords=TCHIP-USB-MX250F128B
It is very easy to get going, just plug the USB-cable to the chip (almost XD )
http://chipkit.net/chipkit-bb32/
And you can use MPIDE to program it, very Arduino-like
MPIDE is a fork of the Arduino IDE
I have put it on a stripboard, the black wire on the left is the USB-cable
