I've been looking aroung for some answer but couldn't find anything helpful.
The situation is :
I have 12V coming from my electric panel. The - is connected to the lock, and the + goes through an emergency button then goes to the lock.
I want to put an arduino between the emergency button and the lock.
I've tried several things, starting with transistor. With a BC139 (or 140 can't remember) I succeeded in lowering the power going to the lock but not cutting it (why ? don't know...)
Wire coming from - of electric panel to the COM relay
Wire comming from emergency button to NO relay
9V power supply to arduino Uno :
VIN of arduino to VCC relay
GND of arduino to GND relay
D9 of arduino to IN relay
My issue is : The diode on the relay blink with the HIGH, LOW I send, but no sound in the relay.
Interesting point : When I disconnet GND I hear the clipping sound, and if I connect GND back again.
(More) interesting point : The diode goes from really bright to lower but not off when the VIN is connected to VCC and goes on and off normaly if 5V from arduino is connected to VCC.
That link shows a pic of the relay but not the pin markings. What does that jumper do? My guess is that it's trying to energise the relay with the Arduino power which is probably not enough, and the relay coil needs its own power.
Can you post a pic of the relay from another angle to show the markings?
You also need 12V on the relay coils, not the 9v which you will be getting from the Arduino Vin pin.
I'm betting the pins we can't see are marked JD-VCC or RY-VCC?
edit... turns out there isn't a JD-VCC pin and jumper
If so, you should wire it like shown here, with that jumper off, and 12V to the JD-VCC connection (not 5V as in diagram, for a different relay). Then all the Arduino's doing is driving the LED in the opto via (Arduino) VCC to IN1/2. Don't connect the Arduin ground to the relay board, only the relay coil power + to JD-VCC and - to the relay board ground.
Everything I said was based on the assumption that there was a JD-VCC pin, and a jumper on it. But that was wrong assumption and I have no idea what that jumper there is for, so can't advise on how it should be connected.
If there are maker's details on your board (the module, not Songle the relay maker) you should try find out more about the connections from them.
