2.42" OLED SSD1309 with U8GLIB
I just cannot make this work with any lib in I2C mode. Not sure if OLED is even working. This is the dsplay:
http://www.befr.ebay.be/itm/181943860429
I have a working code which runs similar oled but with SSD1306. With first line on and SSD1306, it works. Second line on, with SSD1309 doesn't. I have soldered R15 and R13 which are supposed to turn on I2C, but I am not even sure if library supports SSD1309 in I2C mode.
//U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);
U8GLIB_SSD1309_128X64 u8g(U8G_I2C_OPT_NONE);
Has anyone maybe made this OLED work in I2C mode?
Maybe the question should be - is there any lib that works with SSD1309 in I2C mode?
Have the same OLED in white colour. Tested in its default SPI mode with R17 jumper using U8glib SSD1306 128X64 driver.
The SPI connections are not marked properly. Only I2C SDA\SCL are.
After referring few other OLED pin combinations this is how made the connection.
OLED ARDUINO UNO
GND GND VCC 5v SCL 13 (SCK) SDA 11 (MOSI) RES 8 DC 9 CS 10 (SS)
u8glib constructor
U8GLIB_SSD1306_128X64 u8g( 13, 11, 10, 9, 8 );
or
U8GLIB_SSD1309_128X64 u8g( 13, 11, 10, 9, 8 );
8 (reset pin) is not mentioned is available SSD1309 list. SSD1309 is compatible with SSD1306 driver
|500x245
For comparison this display is more than twice the size of a 1.3" SH1106 OLED which is kept in the center.
penjoseph: Have the same OLED in white colour. Tested in its default SPI mode with R17 jumper using U8glib SSD1306 128X64 driver.
OLED ARDUINO UNO
u8glib constructor
or
|500x245
My problem is with i2c, not with spi. Can't use spi mode due to pin number limitation.
I2C should work fine. You remove R17. Solder links on R13, R15.
Make sure that you connect RES and DC. DC selects I2C address 0x3C or 0x3D. Specify the RES pin in the constructor.
If you are tight for GPIO pins, just add pullup to RES pin. (there might already be pullups on the pcb for RES, DC. Test with a DMM)
Seriously. If you have a problem, you should describe it properly.
David.
david_prentice: I2C should work fine. You remove R17. Solder links on R13, R15.
David.
I have already removed R17 and soldered two resistors at R13 and R15. I have now shorted DC and RES, and pulled them up with 10K to VCC. Still nothing on I2C scanner. I have two displays (not connected at the same time), neither recognized on I2C bus. MCP23008 on the same bus is responding just fine.
Weird thing is, if I keep some pressure on the middle of the board, intermittently I get a response from 0x3D. Because of this, I ordered second OLED, which behaves the same way.
I certainly would not "short" DC or RES. You either pullup to 3.3V or pulldown to 0V with resistors. Then the pins are still usable for program control if you want to.
R13, R15 should be 0R. But anything less than about 470R should be ok.
Early SSD1306 displays did not connect LCD_D1 to SDA pin when configured for I2C. I presume that that is what R13 is for. You can trace the pcb. My eyesight does not want to do it for you.
You have several posts under your belt. I would have expected you to use more accurate descriptions e.g. values for R13, R15. What is "short"?
David.
david_prentice: I certainly would not "short" DC or RES. You either pullup to 3.3V or pulldown to 0V with resistors. Then the pins are still usable for program control if you want to.
David.
Thanks, we are getting somewhere. I assumed that R13 and R15 should be the same value as R17. Now I have replaced both with 0R. I also pulled RES with 10K up to Vcc, and I am getting response from 0x3C. Should it be pulled with lower value?
Nothing yet on the screen though. At some point I got something, but not sure which combination of params was it.
U8GLIB is too slow over I2C so I was hoping that SSD1306Ascii could be made to work with it.
I2C is not unreasonable. I would use Adafruit_SSD1306 library first. But I am sure that u8g would be fine too.
First step is to check DC. Does it have an existing 10k pulldown on the pcb? It is essential that DC has a stable value. Otherwise it will not know whether it is 0x3C or 0x3D.
As a general rule, a 128x64 monochrome is always going to be fast. There is only 1kB of data to repaint the whole screen.
David.
Just wanted to add to this. I have the same OLED and cannot get it to work over I2C. It works perfectly on SPI using this construct when wired as shown above:
U8GLIB_SH1106_128X64 u8g( 13, 11, 10, 9, 8 );
When using the SSD1309 or SSD1306 driver the display is shifted and does not work correctly. I removed the resistor from R17 and added a solder jumper on R13 and R15 as detailed.
If somebody has this working on I2C with U8GLIB I'd like to know what magik you invoked.
Did you try U8g2?
Oliver
olikraus: Did you try U8g2?
Oliver
Oliver, no I did not. Two reasons.
  1. The 3D printer firmware I want to use this display with only has driver configurations for U8GLIB not "2".
  2. I do not see a constructor for SH1106 I2C for the "hello world" example for U8G2.
Thank you.
Mr._Swarf:
  1. The 3D printer firmware I want to use this display with only has driver configurations for U8GLIB not “2”.
ok, agree. I did try to support reprap/marlin people to mirgrate to u8g2, but still this transition has not yet happend.
Mr._Swarf:
2. I do not see a constructor for SH1106 I2C for the “hello world” example for U8G2.
The examples only contain a small number of possible constructors. The constructor for SH1106 I2C is also there (see the link in the example).
Oliver
Just wanted to post on here that these displays do work in I2C mode at address 0X3C
I had to solder a 10K resistor between pins Vcc and RES (I just soldered it on the Display side of the connector) and remove the R17 resistor and jumper R13 and R15, but other than that it just worked…I’m using the U8G2 liobrary and using constructor:
for U8G2
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display (SPI I2c IIc Ebay boards)
or for U8Glib
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI
Sample sketches attached for U8G2 and U8glib
OLED_049_Mono.ino (16.6 KB)
HelloWorld_U8GLib.ino (12.9 KB)
This is helpful. My testing did not include a 10k resistor soldered as you detail. I'm hoping to have some time to try this later in the week!
I'll be happy to report my efforts once I have time.
Thank you!
If anyone else has a problem to get this display to work with I2C I posted my own wiring on my blog: 2.42" I2C wiring
So I bought one of those (2.4" display) :
|500x500
I already have a project that works well with the U8X8_SSD1306_128X64 library and 0.96" displays.
Removed R4 , jumped R3, R5
So far: I added the usual I2C Pullups and connected to an Arduino configures for the before mentioned 0.96" also tried to pullup RES (2k2) , pull up/down the DC (for address selection)
no success. So I compiled it with RES support, and tried with , and without an 3k3 pullup for RES (to bring it up before arduino boots)
what else can I try ?
|500x500
no success. So I compiled it with RES support,(connected RES) and then tried with , and without an additional 3k3 pullup for RES (to bring it up before arduino boots)
Thread is a little old, but for reference:
The above 2.42" Oled with the jumpers set for I2C operation work when the reset PIN is connected to the reset pin of the Arduino.
Used SH1109 driver in U8Gxx Lib and also dedicated SH1109 Libs
I2C:
R3 & R5 jumpered
R4 removed.
Also tested with ESP32. Just make sure to use “stickbreakers” updated wire - to avoid hangups.
Greets
Mike
@ 68gt500
Thanks, I've managed get it working, my config is slightly different:
My board is black one: Diymore 2,42" 128x64 OLED Display Module with I2C and SPI support
  • I2C: R4 smd resistor (4.6 kOhm) moved to R3
  • R5 jumpered
  • Reset pin connected to ESP8266 reset pin
  • driver settings: U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
In my case display didn't respond (I thought it could be already dead) until I've connected reset pin to ESP8266 reset pin. If I disconnect it while it is working the screen turns off. Also, somewhere was mentioned that instead of connecting reset pin to reset you could connect display reset pin to GND via resistor (10 kOhm or greater) and than to some digital pin of your board, so get reset pin low on startup and manually set pin high before lcd init cal)
Not sure what is better for R5: shortcut or resistor (4.6 kOhm similar to others), but shortcut works ok and it is easier to make.
