240v ac coil PCB mount relay or SSR
Just wondering if any one knows of a 240v ac coil PCB mount relay or SSR I have looked but can't seem to find one.
Thanks,
Simon
I am not sure how you looked for them but I got several on the first try using "220V SSR pcb mount" as the search term. Since you are putting it on a PCB I am assuming you probably need something like a 5V DC in and 220VAC out. Again you missed specifying the amps you are trying to switch so for your homework try these two links.
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiB59_r44HmAhWNhsAKHeEYBEEYABAMGgJpbQ&ohost=www.google.com&cid=CAASEuRo4uKCjoUNju6Mi2cC_3dkDg&sig=AOD64_0nAuS6TwQ8FpUUPXGgQ74yt2wl0w&ctype=5&q=&ved=2ahUKEwin1dbr44HmAhVPM6wKHXsWAvsQ9aACegQIDBAx&adurl=
This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
simonnomis:
Are you looking for a relay that is switched using 240V AC, or a relay that switches a 240V AC load?
I'm guessing the first (though it doesn't make much sense to me) as the second is dead easy to find.
240V AC coil relays definitely exist - PCB mounted may be hard to find as I just can't think of an application where that would make sense.
Your printed circuit board layout will have to be carefully designed to allow for the 340 volt peak to peak voltage.
Paul
