I am seeking assistance in controlling a 3-phase BLDC motor with a nominal current of 1.4A and a peak of 2-2.5A at 24V. I attempted to control it using a TMC6200 breakout board, but unfortunately, I was unsuccessful.
Could you recommend a breakout board capable of effectively controlling this BLDC motor? Ideally, the configuration should be straightforward, utilizing only PWM control. I've encountered difficulties with SPI mode or standalone operation.
I prioritize the quality of the driver over its price. My primary concern is achieving smooth movement. Any suggestions you have would be greatly appreciated.
You do not give any information that will allow suggestions. Any smooth movement is entirely a function of your software, not the breakout board.
What board failed?
You probably made one or more mistakes. For help, post a link to the breakout board, the motor and the motor power supply, along with a wiring diagram and description of what went wrong.
