5.08mm pin connector for stripboard
I bought those two pin 5.08mm pitch for connecting to a stripboard but I discovered that the pin itself are two large and won't feet my stripboard (tayda electronics).
Is there any other 5.08mm connectors that feets stripboards? I would like to connect 12 or so two wires motors and I prefer not use screw drivers terminals
Thanks
Drill the holes on the stripboard slightly bigger; it's what I used to do.
No idea.
How much mm you drill? 1mm? 1.5mm? 2mm?
Big enough so that the pins go through
1.4mm will be big enough to fit all of those screw terminals.
