cg420za
February 17, 2021, 10:30am
1
Good day ladies and gents. I trust everyone is well...
My name is Marc and I'm a total noob at coding. I've been struggling to get my project up and running because of my inability to code. So I'm here to pick your brains. Hopefully you can point me in the right direction.
A little bit of information, I currently have 6 Sonoff switches wired to various items in my grow tent. It controls fans and lights. Everything is set on a schedule. The problem with my current set up is that it takes up too many wifi connections on my router.
I had this idea to make a power strip that will only use 1 or 2 wifi connections at most. I want to be able to control it remotely and have the DHT22 reading values and triggering the switches if certain environmental triggers are met. I already know how everything will be wired, just waiting on my mate to print the box everything will be housed in. But the coding side gets me down.
The hardware I'll be using is a NodeMCU-32S, DHT22 temp and humidity sensor and an 8 channel relay board.
My question is, how hard would it be to code something like this? I've managed to get the relay board to work, but not the DHT22 at the same time.
Please post your best effort and describe the problems
Please follow the advice on posting code given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
cg420za
February 17, 2021, 11:17am
3
// Import required libraries
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
// Set to true to define Relay as Normally Open (NO)
#define RELAY_NO true
// Set number of relays
#define NUM_RELAYS 8
// Assign each GPIO to a relay
int relayGPIOs[NUM_RELAYS] = {22, 23, 21, 19, 18, 5, 17, 16};
// Replace with your network credentials
const char* ssid = "Chatz back";
const char* password = "watchyourback";
const char* PARAM_INPUT_1 = "relay";
const char* PARAM_INPUT_2 = "state";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<style>
html {font-family: Arial; display: inline-block; text-align: center;}
h2 {font-size: 3.0rem;}
p {font-size: 3.0rem;}
body {max-width: 600px; margin:0px auto; padding-bottom: 25px;}
.switch {position: relative; display: inline-block; width: 120px; height: 68px}
.switch input {display: none}
.slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px}
.slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px}
input:checked+.slider {background-color: #2196F3}
input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)}
</style>
</head>
<body>
<h2>ESP Web Server</h2>
%BUTTONPLACEHOLDER%
<script>function toggleCheckbox(element) {
var xhr = new XMLHttpRequest();
if(element.checked){ xhr.open("GET", "/update?relay="+element.id+"&state=1", true); }
else { xhr.open("GET", "/update?relay="+element.id+"&state=0", true); }
xhr.send();
}</script>
</body>
</html>
)rawliteral";
// Replaces placeholder with button section in your web page
String processor(const String& var){
//Serial.println(var);
if(var == "BUTTONPLACEHOLDER"){
String buttons ="";
for(int i=1; i<=NUM_RELAYS; i++){
String relayStateValue = relayState(i);
buttons+= "<h4>Relay #" + String(i) + " - GPIO " + relayGPIOs[i-1] + "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(i) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
return buttons;
return String();
String relayState(int numRelay){
if(RELAY_NO){
if(digitalRead(relayGPIOs[numRelay-1])){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
// Serial port for debugging purposes
// Set all relays to off when the program starts - if set to Normally Open (NO), the relay is off when you set the relay to HIGH
pinMode(relayGPIOs[i-1], OUTPUT);
if(RELAY_NO){
digitalWrite(relayGPIOs[i-1], HIGH);
else{
digitalWrite(relayGPIOs[i-1], LOW);
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Print ESP32 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
// Send a GET request to <ESP_IP>/update?relay=<inputMessage>&state=<inputMessage2>
server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
String inputMessage;
String inputParam;
String inputMessage2;
String inputParam2;
// GET input1 value on <ESP_IP>/update?relay=<inputMessage>
if (request->hasParam(PARAM_INPUT_1) & request->hasParam(PARAM_INPUT_2)) {
inputMessage = request->getParam(PARAM_INPUT_1)->value();
inputParam = PARAM_INPUT_1;
inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
inputParam2 = PARAM_INPUT_2;
if(RELAY_NO){
Serial.print("NO ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], !inputMessage2.toInt());
else{
Serial.print("NC ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], inputMessage2.toInt());
else {
inputMessage = "No message sent";
inputParam = "none";
Serial.println(inputMessage + inputMessage2);
request->send(200, "text/plain", "OK");
// Start server
server.begin();
This was some code I found online and edited it to run the relay. How and where would i inject the code for the DHT22?
