Does anyone of you tried by using conductive glue(or by using tape to mount) to mount the components, and normal(iron) soldering?
What is the difference between these three ways of soldering? (I am waiting for components for soldering and haven't soldered yet , so I just want discuss with you guys first).
For instance, I want measure the resistance of a 0 ohm resistor. What the result will be for these 3 ways?
BTW could you please tell me where can I find the reference(About glue mounting, tape mounting and normal soldering) to read? I couldn't find any reference about these...
I've never heard of tape-solder either. I might have seen something like solder-ribbon that you wrap-around free-hanging wires before heating with a soldering-iron or torch. Something like that might be appropriate if you are an auto mechanic???
I used conductive glue once to re-attach terminals to the rear-window defroster on my car... For some reason the solder wouldn't "stick". It's a fairly high-current application and the glue worked, so I assume the resistance was low, at least with that fairly-large surface area to work with. (I was worried about resistance before I tried it, but I really didn't want to buy a new rear window.)
With surface mount, you may want to try solder paste and a hot plate. But, I've never tried that myself... I try to avoid surface-mount as much as possible at home. At work we have a surface mount rework station that uses a pre-heater, a hot-air solder pencil, and solder paste... Too costly for me at home, and it doesn't work that well with fine-pitch parts. For board assembly, and for rework on fine-pitch surface-mount parts at work, we send the out board to our board-assembly house. (Again, the setup costs for a board-asssembly contractor are way too high for hobbyists. It only pays-off if you are building maybe 100 boards.)
The fact that you cannot find information about these methods on the internet should answer your question. Do you REALLY think that something that actually WORKED would not be all over the internet?
hello man,
I might say it wrong.
it should be like I use the tape/glue to mount the component on the circuit
