I am trying to repair an old PCB and it has a 15v rail on it that currently is sitting at 14.7v
The LM2676-ADJ regulator appears to need a voltage divider on the feedback pin to set the output voltage.
Trouble is, the original regulator isn't made anymore... so I used this replacement which I think might possibly be the problem (I thought it matched).
LM2574HVM-ADJ/NOPB
The output is set by a voltage divider (I think)
In this case, it is 1k and 11.3k.
But, the voltage out is actually 14.7v, so I wondered if these resistors were out of tolerace or something (apparently it used to be a perfect 15v).
I swapped these resistor out for 0.1% tolerance resistors, but I get the same issue.
I tried a 12k (just out of interest) instead of the 11.3k and I got 15.48v out.
It appears this divider is very sensitive to the resistor values.
I then swapped the 1k and 11.3k for resistors off a different working board (same PSU) and got 14.9v. All resistors measure correct value on my bench multimeter.
Any ideas what else might be causing the drift or incorrect output?
I have no idea how to actually calculate the voltage divider. I will look into the datasheet now.
Use a 10k 10 rev fine adjustable trimpot instead of those two resistor.
Using 100x larger resistor in parallell will decreas the value of its resistor by 1 percent.
Very, very few solid state devices are currently being made. All were made in the millions on a one-time assembly and testing production line. All such devices can still be found and purchased. Google found many well known suppliers of such devices with your device still for sale.
You either did not want to buy or did not look.
It is supposed to be sensitive to the ratio of those resistors...
Just slightly adjust one of them to get the correct output voltage.
Or accept the deviation.
For things like audio amplification it won't matter.
The voltage divider ratio is designed with the 1.2volt to 1.25volt bandgap feedback voltage of the LM2676 in mind (1/(11.3+1) = 1.2195).
Because that internal bandgap has a bit of tolerance, your 15volt supply can be off a bit too.
I don't see how this should be a problem though.
Old analogue gear with 15volt rails can usually tolerate between 12volt and 18volt.
14.7volt is actually very close to 15volt and shouldn't give any problems.
Leo..
The problem is, the circuit further down the line does division calculations using this 15v rail.
This board belongs to a friend of mine, and is 12+ years old (the PCB, not him).
He wants to know why his readings are slightly off in his logging software.
I removed the 15v regulator and pumped in a clean 15v and his processor starting reading accurately again.
So, first off... poor design I would say.
I just replaced the regulator with one that is identical, but has a higher current ability. Just out of interest.
Same voltage.
So I just changed the 11.3k to an 11.5k and got 15.04v. So this looks like a winner.
I could cut the trace on the PCB so that I can test the regulator unloaded (there is no other way to achieve that test). But I don't want to mess up his PCB.
The math says 1k and 11.3k should equal an output of 15v, but hey ho.
I also replaced the 10nf capacitor that connects to the boost pin, as apparently that can influence the output, but that seems fine.
Then there must be a calibration feature, as not all 15V power rails will be exactly 15.00Vdc
You should do some Ohms Law and work out what value a 2 resistors and a low value trim potentiometer will be to make the output adjustable over a small range to cal 15Vdc.
Trouble is, how do you add a trim pot to a 0603 footprint. I am not making new boards, so anything I do is a bodge extra.
The way would be to make it something like an 8k with a 5k trim I would think
Bad downstream design then.
Power supply chips usually have a ± 0.5volt specification, which includes temp and load variations. And the noise of a switching supply.
If you need a more stable voltage, the it must be followed by a second analogue reference voltage stage.
Leo..
And what is the voltage after an hour of operation (where temperatur increased from ambient to 20 degC above ambient?). And at hogh and low load?
You really cannot expect a voltage regulator to be within 0.1V...
You reach that accuracy, but that requires compensation curcuits and proper calibration.
